Ive got a canon MX700 with an error code 5700 can you help.
    President:
  • 2,712 Answers
Generally, the 5700 error idicates a faulty paper sensor. But this error can crop up if the paper feeding mechanism is faulty/obstructed as well.
Ensure that there is no obstruction in the paper feeding mechanism. Look for bits of paper or debris between the rollers.
Or you can try a hard reset: Unplug adapter from printer, hold down the power button and replug.
Should that not work, you may want to consider getting it serviced.
To contact Canon for a product you currently own:
Email:
Click here for support via email.
spIve got a canon MX700 - spacer.gifclass=
Phone:
1-800-828-4040
Posted on May 11, 2008
  • Swilin Sampson
    Swilin Sampson May 11, 2008
    This is what the Canon website has to say: ( This is if you see the 5700 error on the LCD display):
    If the device is not functioning properly or to clear memory, reset it.
    1. On the operator panel, press and hold the button for one second. (The display will go blank.)
    2. Wait approximately ten seconds and then press the button again.
    3. Wait until the device has completed its cycling process before submitting another job request.
    Also try to disconnect and reconnect the USB cable at both ends to
    ensure there is a secure connection on the device side as well as the
    computer side. It may also be necessary to try a different USB port on
    the computer. Additionally, you may need to disconnect other USB
    devices, temporarily, in order to determine if a conflict exists.
    Try THIS link as well. In the "enter your question " box, type error 5700. Should be of some help...
    Genius:
  • 3,422 Answers
I believe the only solution to get this fixed is to get it repaired or replace it if it is still under warranty.
See if there's a slotted plastic piece with a spring under it that the bottom tray slides into had been pushed out and up into the paper feed mechanism. just pull it back down into place.
Goodluck,
Please don't forget to rate the solution
  • 828 Answers
Canon error code 5700 means your paper sensor is not working. To repair it is more costly than to replace it.
Error code 5700 turned off and unplugged. wont let me do anything
ASF sensor error or Error Code 5700
An error occurred in the ASF cam sensor.
Problems and Solutions:
Replace one of the following:
- ASF unit
- PE sensor board unit
- Logic board
This is hardware error and you need to show it service center. Following things you have to do.
- ASF unit
- Logic board
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 24, 2010 | Canon MX700 Office All-In-One InkJet...
Error 5700 impresora MX700
"Printer died after 1 1/2 years, error code 5700." on May 1, 2009 by danmc7777 (2 reviews)
Pros: This is a pretty decent product as far as ink jets go.
Nice to be able to use the feeder to scan multi-page documents and even cover two sides by running two passes and then the software interleaves the pages to make a seamless pdf file.
Cons: Ink jet technology. It worked very nicely for a year and then a few jets plugged up and wouldn't clear out even with cleaning.
Today the unit is dead, reporting error code 5700 and refusing to do anything after a paper jam.
Cartridges with chips.
Summary: I was pretty happy with this printer until one day it decided to grab about 30 sheets of paper at one time from the top feeder. This created a pretty major jam, and it reported the error code 5700. This jam must have stripped something in the gearing since now all it will do is report this error even after power cycling. Web search reveals that this is a serious fault that requires it to be sent in for repair. Yea, right. This unit is designed to be never disassembled since everything snaps together and opening it up is a major puzzle.
This is only reader review which i found in the web. this may tell you what is the error is all about..
Nov 10, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I am getting an error code of 5700 on my PIXA Canon MX700. Any ideas how to fix it? or do I have to get a new one?
Try out these things to clear the error:-
1) Reset your device
  • On the operator panel, press and hold the ON/OFF button for one second. (The display will go blank.) If pressing ON/OFF button does not shutoff the device then unplug the power cord.
  • Wait Approx. 10 Sec then press power button ON/OFF button again.
  • Wait until the device has completed its cycling process before submitting another job request.
or..
2) Remove Paper Jam if any
Else your device need service (repair)
Good luck
Rating the solution is highly appreciated
Mar 18, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Error code 5700.. already checked for jams, none, unpluging won't do it... none of the buttons respond... what else ??
Error 5700 is ASF sensor error.Check first the sheet feeder.If not have a jams the problem is in purge station.You can't fix it by yourself and your printer need repair.
Nov 04, 2009 | Canon PIXMA MX700 All-In-One InkJet...
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
I HAVE ERORR CODE 5700 ON MY CANNON MX700 , HOW TO FIX IT
5700 is a sheet feeder error, if there is not something caught inside like a ink pen, paper clip, or kids toy, you might need a new feed assembly. Not too expensive, but a shop repair only.
Aug 03, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Error 5700. Need pictures of dissassembly to repair?
Sorry to here that. I hope you went with a different Mfg.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 25, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Error 5700 displayed on copier screen
i forgot to mention that my printers a pixma MX700
Jan 06, 2008 | Canon PIXMA MX700 All-In-One InkJet...
244 people viewed this question
jasbo
jasbo
