Good day! I would like to ask help to my cp because when i turn on the computer there is a beep which may take 2 seconds beep like tot.. tot.. continues beep. i try to remove memory, Video card but there is no changes still the computer is beeping.
2toy
  • 15 Answers
SOURCE: Cannot POST - 1 LONG BEEP !!
reset the CMOS, and then change again the video card.
Posted on Feb 24, 2008
rionxz
  • 48 Answers
SOURCE: Three "beeps" before startup, but no "answer" then...
Beep Codes:
click this link: http://www.intel.com/support/motherboards/desktop/sb/cs-010249.htm
Posted on Sep 24, 2008
  • 44 Answers
SOURCE: Computer doesn't start...it keeps beeping
The Beep pattern is the motherboard trying to tell you what the problem is, and the beeps differ accross different manufacturers. As you still have PC access, do an internet search for the <Manufacturer> beep codes, ie "ASUS beep codes" - alternatively this site may help. http://www.pchell.com/hardware/beepcodes.shtml.
Alternatively I would try reseating processor and removing all but one stick of memory (and reseat it) and unplugging all but graphics card to see if this "gets it going" - if so reintroduce one component at a time until you find which one causes the beeps.
Posted on Apr 30, 2009
joecomputer
  • 92 Answers
SOURCE: Single Beep on boot... repeats after 2-3 seconds, no video
This is a tough one. On some system bioses one beep means a problem with the RAM. On most it means a succesful POST. Are you getting any video? Have you tried booting to a boot disk? Have you tried a new hard drive? Have you tried to clear the CMOS? Good Luck!
Posted on Jun 27, 2009
  • 3 Answers
SOURCE: Turns on, no bios no screen, just beep.
Now the question is, when the computer first starts up and you hear the beep, that is where it will tell you what your problem is depending on the beep you get.
One Long and one Short Beep = Motherboard issue
One Long and Two Short Beeps = Video (Mono/CGA Display Circuitry) issue
One Long and Three Short Beeps = Video (EGA) Display Circuitry
Three Long Beeps = Keyboard error
One Beep, Blank or Incorrect Display = Video Display Circuitry
If it is the last one, then try doing the following.
1. Disconnect external devices = Unplug everything from the back of the computer and then restart it. If it starts up, then it is one of the peripherals that is plugged in. You will then need to turn off the computer and gradually plug each one in and turn the PC back on to see if the peripheral is the problem. If that isn't the problem, the proceed to #2.
2. Cable check = With the computer shut down, make sure all the cables within the PC are attached properly. Once you finish doing that, turn on the PC and that isn't the cause, continue on...
3. Disconnect all expansion cards = Sometimes another expansion card can become loose and cause various amounts of issues. Remove each expansion card (clean them if necessary of dust) and replace them. Turn on your PC. If it doesn't start move to the next step.
4. Disconnect all drives = disconnect the data cables from the CD-ROM, hard drive, and floppy drive from the motherboard (make sure to mark them so you remember where they plugged into). This will either remedy the situation or you will see an error when you reconnect each device one at a time to determine which device/cable is causing the issue.
5. Remove the RAM = Loose or bad RAM can cause PC's to not boot or boot incorrectly. Remove each stick and replace them one by one alone in each memory slot. If the PC boots up in each slot, then your golden, but if a slot is defective, then your motherboard is damaged in that slot. You can still use the other slots as long as you use the defective one. If a stick of RAM doesn't allow your computer to boot up, its quite possible that stick of RAM is defective and will need to be replaced. But make sure you try out all the other options before throwing away a stick merely because the PC doesn't boot. A faulty stick can be the problem, but if the problem lies elsewhere, you may be throwing away a good stick of memory thinking it may be bad.
6. Disconnect and reconnect the CPU = Most CPU's are easy to remove, but if you aren't familiar with it. Read your manual on how to remove the CPU. Once you remove it and re-seat the CPU, reboot your PC.
7. If after you have tried all the previous steps and your PC still doesn't boot, then it is most likely that your motherboard, CPU, RAM, or power supply is defective and must be replaced. If you are unfamiliar with fixing the problem (or have never built your own PC) you can opt to have someone repair it or you can start with the cheapest option of purchasing a single stick of new memory and see if the memory was indeed the original problem. If the PC still does not boot with new memory, then it is most likely your motherboard, CPU, or power supply that is dire straights.
Posted on Aug 28, 2009
What does TOT mean on display?
TOT Penalty means: If the radio transmits more than a set time, it will beep an T-O-T error tone and the radio will only receive a signal for the penalty time. (TX inhibited for this time).
Under the above mode, press Up/Down buttons to select On or Off and then press Mode button or PTT button to set Busy Channel Lock Out. The radio will then save selection and exit to receiving stand-by
mode.
To DISABLE... navigate the menu to "PENALTY" in the display... press mode button... then use UP or DOWN buttons to select mode... to disable select "OF" (which means off).
Good Luck.
Apr 26, 2014 | Midland M222P (22 Channels) 2-Way Radio
I have a motorola cp 110 walki talkie .red light comes on but no beep or commuunication
If you have no initialization beep when you turn the radio on, it is likely the radio is in need of repair. Immediate things which come to mind are a sticking PTT button, something stuck in audio accessory jack, or a bad speaker. You might check the radio using a second radio and see if you can transmit.
best regards.
Nov 08, 2011 | Motorola Walkie Talkie 2-Way Radio
We had a power outage for about 45 minutes a few days ago. Ever since then the Powerware 3110 has been beeping. I turned it off and left it plugged in overnight and when I turned it back on the beeping...
This could be several things, fortunately the device should actually be helping you to diagnose the issue. There are different beeps for different issues. They are as follows:
1 Beep Every 5 Seconds = Power Outage\Loose Plug Connection\Tripped Circuit Breaker\Power Cord Damage or Failure
2 Beeps Every 5 Seconds = Low Battery Alarm
3 Beeps Every 5 Seconds = Battery Needs Charging\Service\Replacement
3 Beeps Every 5 Minutes = The Battery is discharged and battery power is unavailable (If this continues battery replacement may be necessary)
1 Beep Ever 1/2 Second = Power Requirements exceed the UPS Capacity (remove some equipment to lighten the load on the unit)
Continuous Beep = Short Circuit / Input Voltage out of Range / UPS Fault (Likely replacement of entire unit)
That should help diagnose the actual issue. If it turns out the battery needs to be replaced they can be found online for around $20. A simple google search for Powerware 3110 Battery should return what you're after. Good luck!
May 05, 2011 | Powerware 3110 UPS System
How do you perform a full reset on a kenwood tk-370
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor Key Off = off 1 = Monitor momentary 2 = Monitor Lock 3 = Squelch off momentary 2. Scan Key Off = off Co = carrier operate To = Time operate 3. Dial Key Off = off On = enable 4. TA key TA = talkaround RV = Reverse Off 5. Lo Key On Off 6. Priority None 1 = fixed 2 = selected 7. Fixed Priority Channel Turn selector to channel 8. Look back time A Turn selector to time in seconds 9. Look back time B Turn selector to time in seconds 10. Revert Channel 1 = Selected 2 = Last Call 3 = Last used 4 = Selected + Talkback 5 = Priority 6 = Priority + Talkback 11. Tx Dwell time Turn selector to time in seconds 12. Drop out delay Turn selector to time in seconds 13. Time out timer Turn selector to time in seconds 14. Tot Pre-alert Turn selector to time in seconds 15. Tot Rekey time Turn selector to time in seconds 16. Tot reset time Turn selector to time in seconds 17. Squelch Level Turn selector to Squelch 18. Beep tone On Off 19. Signalling And Or 20. Battery Save On Off 21. Selectable QT On Off 22. Clr to transpond On Off 23. Del/ Add On Off Pressing (Dial) allows programming of: DTMF 24. digit time Turn selector to time in milliseconds 25. inter digit time Turn selector to time in milliseconds 26. First digit time Turn selector to time in milliseconds 27. Rise time Turn selector to time in milliseconds 28. Rise time with QT Turn selector to time in milliseconds 29. PTT ID Off 1 = connect 2 = disconnect 3 = Both 30. Dial ID On Off 31. Connect ID 32. Disconnect ID 33. # of DTMF keys on Keypad 12 16 34. DTMF hold time On Off 35. Store & send On Off 36. D key assignment Turn selector to D or time in seconds for pause 37. Dtmf Signaling Off 1 = code squelch 2 = Selective Call 38. Intermediate Code OFF A B C D E F 39. Group Code OFF A B C D E F 40. Auto Reset time Turn selector for time in Seconds 41. Call Alert/ Transpond Off 1 = 2 = 3 4 5 42. Transpond On Off Pressing (TA) will allow you to program Frequencies Use selector to choose channel Press PTT Enter Rx frequency using: - the Selector Knob to change kHz; - the Selector Knob + (light) to change MHz. If no channel is Shown press the (LO) button. Press PTT Enter Rx CTCSS code Press PTT Enter Tx Frequency as above Press PTT Enter Tx CTCSS code Press PTT 1. Option Signal Off 1 = DTMF 2 = 2-Tone 2. PTT ID On Off 3. Add/ Del 4. Busy Tx 5. Clock frequency shift 6. Power Hi Low Repeat for the other channels (you've got a 32 channel radio, so it may take a while...) <end>
Sep 16, 2010 | Kenwood Radio TK 260 360 270 370 2100 3100...
I have a playstation 3 system that worked for 1 day & the next time i attempted to play it,it did nt go past the initial playstation intro screen.The screen is grey with the playstation wave symbol...
Ok, follow these steps to cure your problem. Warning, you will lose saved game data!!
Step 1. Turn the PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep when you press it, then beep 5 seconds later and then once more another 5 seconds later and turn off. Release the power button.
Step 3. Press and hold the power button. It will beep once when you press it, again 5 seconds later and then 2 quick beeps together. When you hear these 2 beeps release the power button
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this and then continue to the next step
Step 5. The options menu will display. Select option 5 "Restore PS3 System". The PS3 will re-install the software required and restart. Hopefully this will solve your problem
Hope this helps and thank you for using FixYa.
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
Need manual for kenwood tk-270 transceiver does any one no were i
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor KeyOff = off1 = Monitor momentary2 = Monitor Lock3 = Squelch off momentary 2. Scan KeyOff = offCo = carrier operateTo = Time operate 3. Dial KeyOff = offOn = enable 4. TA keyTA = talkaroundRV = ReverseOff 5. Lo KeyOnOff 6. PriorityNone1 = fixed2 = selected 7. Fixed Priority ChannelTurn selector to channel 8. Look back time ATurn selector to time in seconds 9. Look back time BTurn selector to time in seconds 10. Revert Channel1 = Selected2 = Last Call3 = Last used4 = Selected + Talkback5 = Priority6 = Priority + Talkback 11. Tx Dwell timeTurn selector to time in seconds 12. Drop out delayTurn selector to time in seconds 13. Time out timerTurn selector to time in seconds 14. Tot Pre-alertTurn selector to time in seconds 15. Tot Rekey timeTurn selector to time in seconds 16. Tot reset timeTurn selector to time in seconds
Apr 27, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
What are the hotkeys for a CP technologies cp ukv p02
You can hit scroll lock + scroll lock + 1 or 2 to switch between computers.
If you have any more questions I will try to help you.
Have a great day, Tim
Mar 24, 2009 | CP Technologies KVM CPTECK 2-PT BUILT IN...
3 beeps at start
hmmm...that's not good. works fine with no battery. I suspect your motherboard may be taking a vacation from working soon.
got backup for your HP?
Feb 12, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
