Question about Cameras
My camera samsung wb500 cannot be recognized by a computer. When plug it in to the computer via usb cord it is recognized by the pc. The light on the camera flickers but nothing happens. Thus I am not able to transfer pictures from the camera to the pc. I've tried different usb ports on two different computers and it was still the same, so the problem shouldn't be on the side of computer. Any suggestion what can be the problem?
  • 1,606 Answers
Cross your fingers and hope it is just the cable. The flashing light shows it made a momentary connection. The connectors get loose from use and abuse. They are not expensive to replace. If you can find a store or camera shop or have a friend with the same cable they should have one you can use to test. You don't need to transfer anything just plug it in and see if it connects normally. If it does then buy a new cable. If it doesn't then the problem can be the connection inside the camera or the usb interface inside the camera. Unfortunately those are not going to be a cheap repair. You would spend as much as a new camera. So unless you have warranty left it comes out of your pocket. A new replacement camera will usually be as cheap or cheaper than the repair cost.
Posted on Sep 04, 2010
  • 1 more comment
  • kite_tie Sep 04, 2010
    Thanks for a super quick response KingDWS. The cable might be the problem. After seeing your response I noticed that cable is rather loose and now also the light on the cable sometimes doesn't flash when the camera is connected to the pc. When I hold the cable tight there was a sign of connection and the pc recognized the camera but the connection got lost just after 2 seconds when the cable got loose. I hope the cable is the problem not something inside the camera.
    And one more thing. I use the same usb cable for recharging the battery - the cable is plugged into adapter and adapter is plugged in to the electric outlet. The battery was fully charged so the cable should be ok - at least in terms of connection between camera and electric outlet. But still it doesn't work when I plug it in to a computer, the camera is not recognized....now I'm really confused...
  • Dave King
    Dave King Sep 05, 2010
    There are 4 little contacts in that connector (I think and I'm not looking to count em ;-]) Two are going to supply power and two are usually data. So you can have one work and not the other. The cable is a cheap fix. If you have a dollar store or discount you can grab one for cheap. If its the camera end then its expensive. Unless its a higher end camera the repair is just too much. Especially these days when you can grab a $100 camera and it is better than a lot of the top end stuff just -34 years ago.
Pc wont recognize camera
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Mar 24, 2014 | Sanyo Cameras
Usb usb data transfer cable
Have you considered NOT connecting your camera to your computer?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Jul 07, 2013 | Samsung DigiMax Cameras
Samsung Camera wb500 usb device not recognized
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Apr 07, 2012 | Samsung HZ10W / WB500 Digital Camera
My pictures don't upload when I use the USB cord for my computer. The arrow light on the cord turns red, and it just doesn't load. /:
Have you install the camera driver ? You should have the CD installer bundled with the camera or you can download the driver software via Google. When the lamp still light red, it means the computer still in process recognizing the camera. More high memory card capacity usually will take longer time, just wait until the camera folder show up in Windows Explorer. Then you can download your picture.
If the answer helpful RATE please and thanks for using fixya
Jan 29, 2011 | Samsung SL600 Digital Camera
My camera samsung wb500 cannot be recognized by a computer. When plug it in to the computer via usb cord it is recognized by the pc. The light on the camera flickers but nothing happens. Thus I am not able...
I have the same problem with my WB500. From the start I haven't been able to charge it via the computer or down load photos. I solved the problem by buying a card reader and a separate battery charger. I tried to get the problem resolved by Samsung, but with no luck, so solved it my way instead
Sep 04, 2010 | Samsung HZ10W / WB500 Digital Camera
My Samsung WB500 will not connect to my computer any more. The computer is not recognising the device.
Do a restore on your computer to an earlier date that you know when it was recognized
Aug 23, 2010 | Samsung HZ10W / WB500 Digital Camera
How do I get my samsung WB500 to recognise pictures I have renamed
If you renamed them in your computer and then inserted the card into your camera, they won't show up. The computer uses a different system to write to the card.
Oct 15, 2009 | Samsung HZ10W / WB500 Digital Camera
My computer doesn't recognize my new cord for my camera
Try to check if the camera software and driver is properly installed in your computer.
Make sure that your camera is compatible with your computer operating system.
Are you sure you purchased a genuine Samsung USB cord? Because it would be much advisable to use Samsung USB cable.
Try to go to MyAccessoryMall.com and you may purchase the cable there.
Jan 03, 2009 | Samsung Digimax D53 Digital Camera
PC won't recognize
I don't know why they did this, but this camera requires the camera to be plugged into the AC adapter (via battery charger) in order to be able to transfer the data to the computer.
Nov 28, 2008 | Panasonic SDR-H60 HDD Camcorder
Usb cord not recognized...?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jul 22, 2008 | Fuji FinePix A330 Digital Camera
Cameras Logo
108 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
