Question about RCA Audio Players & Recorders
My old RCA-RP3753A CD clock radio is broken. I can't get the CD player to work. You put a cd player and it just spins and spins. I can't even put a laser CD cleaner in there. It won't read it to clean the lens. What to do besides throw it in a trash can??
SOURCE: PD-H300 not recognising CD's
FOLLOWING ON FROM MY REPORTED PROBLEM I WAS DETERMINED TO FIX IT.
I REMOVED THE OUTER CASE ( AFTER UNPLUGGING THE UNIT ) AND WET CLEANED THE LENS WITH METHATED SPIRIT. THAT CURED THE DISC RECOGNITION PROBLEM BUT THE MOTOR WAS NOT STARTING EVERY TIME.
VERY CAREFULLY I MANAGED TO GET A LITTLE WD40 ON THE MOTOR SHAFT AND HEY PRESTO IT NOW WORKS OK EVERY TIME.
HOPE THIS HELPS SOMEONE.
Posted on Jan 10, 2008
StuartB
  • 807 Answers
SOURCE: New laserunit won't work
You seem confident enought to take it apart, have you tried cleaning the runners that the laser runs backward and forward on.
Some times they collect dirt/dust and the laser can't move smoothly so it jerks and skips.
Posted on Mar 14, 2008
localwonder
  • 6784 Answers
SOURCE: CD player WILL NOT PLAY and does not recognize CD presence
HI. this is optical lens assembly failuer. the optical lens is burned out, in return, inducing the (no CD) message. simply replacing the optical lens assembly will fix this issue.
Posted on May 27, 2009
Testimonial: "have same problem..solution sounds great...the only thing now is where can one obtain the optical lense replacement..no help from radio vendor"
  • 4234 Answers
SOURCE: My Sony cd player spins but won't play. Cleaned
Those CD cleaners rarely work. They are nothing but small brushes on a plastic CD. Unless the problem is loose dust, they won't work. Try carefully opening up the unit and cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, post the model number and I'll provide the replacement optics part number and cost. Some units have replacement optics that cost less than $15. Dan
Posted on Jun 15, 2009
  • 133 Answers
SOURCE: MY CD PALYER DOES NOT WORK. ''DISC NOT FINALIZED'' IS DISPLAYED.
If your CD player has been working for many hours and cleaning the lens didn't help, then the next thing to do is changing the spindle motor (the one that spins the disc), since the brushes and the commutator get dirty/oxydized with many hours of performance.
The motor can also be cleaned, but it's kinda complicated and delicate to do it, so you might want to change it instead.
The same holds for the slide motor (the motor that changes the position of the laser pickup).
To clean the motor you need to desolder/remove it and open it up (you need to bend out the clamped parts on the motor housing to release the cover - also, mark the position of the cover so you can put it back in place in the same position as it was prior to opening it - some motors have an indentation so that the cover fits in place in only one position).
Then you need to remove the cover (this is a delicate procedure as you can easily damage the brushes).
You can clean the brushes and the commutator using a long pointed scalpel - gently scrub away the brownish/black residues on both the brushes and the commutator.
Now you need to put the motor back together, taking care not to damage the brushes when you put the cover back in place (kinda tricky but it can be done).
After closing it, see if it runs smoothly, you may want to try and run it on some 3 volts - it must run quite silently, with no more than a gentle humming sound.
If it runs ok, you should use a tiny flat screwdriver and a small hammer to bend the housing edge back onto the cover to fix it in place (basically, you need to rehammer back in the clamps that held the cover in place, this is also a bit tricky and delicate thing to do).
Now reinstall/resolder the motor back in place (motors on some brands/models can be worked without removing them).
Well, i've just told you how i repaired quite some CD drives which were virtually dead, i'm actually still using a yamaha which is more than 15 years old (i myself have been using it for at least 10 years now), i got it as a scrap piece, it returned to life after the above described procedure and it actually works perfectly up to date.
Anyway, i guess the easy way is to simply replace the motors (they need to have the same axis dimensions and mount holes as the original ones, also they need to run on the same voltage - things to keep in mind when you are looking for new motors).
Hope you can get it working...
good luck
3rq8 (Triarcuate)
Posted on Jul 24, 2009
How do you put a cd in
Kylie, if there is a CD tray press the eject button and put CD in tray, push tray in easy to load. If no CD tray insert CD into CD slot and push gently to load. Some have a lid on top that you simply open with your finger then load CD. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jensen JCR 310 AM FM Stereo Dual Alarm Clock Radio with CD Player
Christmas Presents 2013 RCA RP5605 AM FM CD Clock Radio
Magnavox alarm clock radio CD player
Problems With My GE General Electric 7 4901A CD Player AM FM Clock Radio
Jun 17, 2016 | Audio Players & Recorders
RCA Alarm clock with cd player, CD will not read discs
cd players have their laser fail often. How old is it? A three year run with a player is not bad.
Nov 24, 2013 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
RCA RP 3755 Clock radio: CD player will not spin
Hello
Check the voltage at the terminals of the sled motor. If it is found OK, replace the sled motor. Sled motor do spins the disc inside for any CD players. See the picture of its position.3_1_2012_3_05_08_pm.jpg
Feb 29, 2012 | RCA Audio Players & Recorders
CD player won't work
the laser might be dirty or you have a bad laser
when you try to play a cd does it even spin at all or does it do nothing
to clean a laser you take a q tip and very gently rub the small laser head then try to play a cd after
Jan 02, 2011 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
My cd player will not reaqd most of my cd's.spins then gives a no disc message.It is odd because it reads the odd cd ok.
could be that the brand of cd is not the same and it may also may be that the cd's are burnt at different speeds.try washing the bad cd's with liquid soap.
Feb 27, 2010 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
I have a RCA stero CD player/digitial radio. The CD player doesn't work. when it closes, it just clicks, but won't play a CD.
Replacing motor rubber band will fix this problem. Remove 5 external screws to have access inside the unit. TIP: You do not need to remove the front CD door. Good luck.
Dec 13, 2009 | RCA RP3755 Clock Radio
CD player stopped working on Sony ICF-CD831 PSYC Clock Radio/CD P
I've been able to prolong the life on mine by doing this:
Insert the disc, then spin it by hand and quickly close the door and hit play.
It's always worth using a laser cleaner first, as it may just be dirty and stops spinning because it cannot read the disc.
Apr 26, 2009 | Sony PSYC ICF-CD831 Clock Radio
Setting the time on my clock on radio Model # RP3755B
Well, I have an RCA clock radio/CD player and just figured it out. Press the "Time" button and hold it down while pressing the CD "Forward" button. Hope it works for you! Ron
Jul 03, 2008 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
CD Player doesn't work; says "disc"
i would say that your lense is dirty and yes cleaning it might help
Feb 04, 2008 | Bose Wave Radio
115 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
