Question about CTL Nexus NX3200 Television
Nexus tv Mt Nexus tv just cuts off. I have to then unplug it, then plug it back into the wall.
  • 14 Answers
That is normally an issue with the control board.  You can contact Nexus Support at 800-642-3087 ext 235 and they can take care of getting you a new one.
Posted on Mar 30, 2009
My Nexus NX32031 won't power on. None of the caps are bulging. .
Probably power supply failure, even with no evidence of bulging caps.
Aug 13, 2014 | Nexus NX32031 LCD TV
Nexus 7 won't turn on after charging
I found that if the Nexus 7 (or 10) is left on until the battery drains completely, then switches itself off, it doesn't switch on normally after a recharge. All you need to do is press the on button for several seconds and it will reboot. If that doesn't work then try a hard reset. Refer to user manual which should be in the file system.
May 19, 2014 | Google Nexus 7
My laptop is saying that the Nexus is unknown and will not connect.
I don't have a nexus but have had a similar problem with a cellphone. If you go into the settings you should look for a link to change the connection type, i.e. some products will connect as a storage media device allowing you to browse files or as a modem to allow you to share the 3G connection or in propriety mode where it will connect as a Nexus to the bundled software.
With the Blackberry Playbook you have to install specific drivers stored on the Playbook before it is even recognised correctly. Please check if you have installed the drivers correctly. They might come on a CD boxed with the Nexus or if you connect the Nexus you'll find a new drive and it will contain an exe to install drivers so the PC can recognise it. The later was the case with the Playbook. Alternatively try downloading new drivers from the support page for your particular Nexus model. Web downloads are almost always the latest version of drivers and the one shipped with your Nexus may not be properly compatible or flawed. Hope this helps.
Nov 15, 2013 | ASUS Google Nexus 7 Tablet
Nexus 7 wont turn on for longer than a second, then it says powering off.
Charge your nexus using the ASUS wall charger that came with your nexus.
Once you connect your Nexus to the wall, just push the power button once (do not hold). A battery animation should appear showing that the tablet is charging. Let it sit for a while, then power it up.
If you suspect it's a hardware problem and if you feel comfortable opening up your device, please let me know so I can give you a step by step walk through to figure out what exactly is going on with your device.
Apr 06, 2013 | Google Nexus 7
My nexus 7 is not turning on anymore. It's been charging for days. Any ideas?
The battery connector in the Nexus 7 (2012 model) is notoriously problematic. Sometimes dropping the device can cause issues that prevent the Nexus 7 from charging altogether. A hard reset may not work. Fortunately, it is quite easy to fix.
However this will void your warranty. Pop the back of the Nexus 7 case open by pushing a credit card or guitar pick or small screwdriver under the edge of the black plastic case. Start from the top and gently pry the case open, working your way around. The back of the case will come off quite easily. The battery occupies the bulk of the left-hand side of the unit, and a group of six wires come out of the top of the battery to a connector on the circuit board. Gently push the plug out of the socket connector, wait 15 seconds, and push it back in. Snap the case back on and plug in your charger. You should now see the battery charge image appear.
Mar 06, 2013 | Tablets & eReaders
How do I save photos in the asus nexus 7
Depending on what your question means I may be able to help. You are unlikely to be able to plug you camera in directly to your Nexus but with a USB card reader, a 'USB on the go' cable (available from Amazon) and Nexus Media Importer app you can view and copy stuff from your camera memory card. This works a treat. A standard USB cable won't work. Alternatively you can plug your nexus USB cable into your PC and manage your Nexus folders.
Dec 19, 2012 | ASUS Google Nexus 7 Tablet
I have a nexus 42 inch tv and lost sound. Not sure if my one year old pressed something on the remote because netflix, and DVD work fine
Tries tv and those cable or satellite boxes unplug,replug it back like about an hour later for those pay boxes to reboot and upgrade it softwares and for the tv to do a resetting itself back to factory setting,now go into the tv menu go to Audio setting tries resetting all back to the factory setting.By doing these steps.These steps,will help and have a great chances for ur tv to have it audio back for tv stations channels broadcasting reception.
Jun 24, 2011 | Nexus EX-4200 42 in. EDTV-Ready Plasma TV
Need Nexus TV remote code
And just for what it's worth... I have a Nexus 32" (Model # NX32031). Although the 10463 code DID NOT work, THE 10178 CODE WORKED GREAT!
Nov 12, 2008 | Televison & Video
CTL Nexus NX3200 Television Logo
241 people viewed this question
Top CTL Televison & Video Experts
Are you a CTL Televison and Video Expert? Answer questions, earn points and help others
