Question about Electrolux Ovens
ELECTROLUX GALLERY MODEL EOB9730 - CANNOT GET TO OPERATE - IS 18MTHS OLD, BUT NEVER USED UNTIL NOW - NO MANUAL
Frigidaire Gallery 30'' Freestanding Electric Range We recently bought a house with this stove in it. however the oven door outside window part is off.....how can we re-attach it.
Hey Alice, I appreciate your post!
I understand that you need help reattaching part of your Frigidaire range. I have located a parts schematic and attached it for you. If you need any additional assistance please feel free to reconnect. Good luck! -Matt
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995639282.pdf
Dec 20, 2015 | Frigidaire Gallery 30 " Stainless Steel...
Frigidaire electrolux oven gallry series front right element won't turn off
What is the model number? Reset the unit by unplugging or turning the circuit breaker off and then retrying.
Aug 09, 2012 | Frigidaire Ovens
Wall oven wont heat up even when new element has been installed but everything else works
Check your circuit breaker for trips. You may have a bad thermostat.
May 24, 2012 | Electrolux Ovens
How do I clean my Electrolux Icon Oven?
Which Electrolux Icon Oven do you have?
For most ovens, with a use a cloth and hot soapy water (do not use an abrasive cleanser or an oven cleaner), clean the door and the frame of the oven outside of the gasket. Similarly, remove the heavy amounts of spilled food (get rid of sugary or highly acidic food spills particularly) in the oven. Take the oven racks and oven rack support, broiler pan and insert, utensils and any foil out of the oven. Then close the door. If you have a single oven, press Clean. If you have a double oven, select the oven to clean and then press Clean. Select the duration of the cleaning cycle (either by hours (2,3, or 4) or cleaning level (Lite, Medium or Heavy)). Some Electrolux ovens have buttons for the cleaning level otherwise use the up/down arrows. Then press Start. The door will lock and remain locked until the oven cools after the cleaning process. For a delayed cleaning cycle, make sure the time is correct on the clock and press End Time and enter the time you want the cycle to end and then Start.
Make sure the kitchen is well ventilated.
The manuals are available for most from the Electrolux site. Start at http://www.electroluxicon.com/ and search for your model. (Either search on the model at the top right or under Kitchen Appliances) If you find a page for that model, it will have a Specifications and Guides tab. The manual is in that tab as a pdf.
I hope this helps.
Feb 06, 2011 | Electrolux Ovens
Electrolux EOC68000X oven Demo mode only
If that model number EOC68000X is correct then in the manuals I have for that Model there is no Demo mode setting.If you can supply the PNC number then I will investigate further.Try relogging your call with this information.
Hope this helps.
Jun 06, 2010 | Ovens
How can i mend the grill and oven on my electric cooker?
If the rings work o/k then could be timer if it has one make sure it is set to manual and not auto.
Another thing it could be is a faulty selector switch, which selects the different functions.
Hope this helps.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Ovens
Electrolux Oven
if the fan inside the oven cavity is operating as well as the light, then the problem is probably the circular element is open circuit.
get back to me if you want - fairly easy to fit and not too expensive
Jun 23, 2008 | Electrolux Ovens
Ovens Logo
26 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
