Computer STartup Problem
Less than two years ago I bought all the parts for my PC and put them together. Everything went well, except for one problem: When I start my PC from it being completely dead, the fans will spin, the lights will come on for about 1-2 seconds, then it will shut off. It will do this over and over until I do one thing; Unplug it and take out the 5 volt battery then reinsert it and start all over. That is the only way that I can get it to start up without shutting down almost immediately. On a side note, when I restart my computer, it will immediately go to the Bios screen (I think) where I have to press F1 to continue or delete to enter setup.
This was the most frustrating problem I had when I first got my computer. At that time I tried everything including; RMAing the motherboard, switching out the 5 volt batter, switching out the power supply, taking each component that wasn't necessary for startup and seeing if it was that). I really don't know what to do and it is the greatest annoyance(especially when the power goes out multiple times). Any help is greatly appreciated.
My specs(in case that is important): NZXT Lexa case, Asus M2N SLI Deluxe, AMD X2 4200+, Western Digital Hard Drive, Corsair 2gigabytes of memory.
  • 981 Answers
That is an impressive wait. You must be an OR LP to have tolerated that battery manipulation; hopefully the surgeons aren't up nights over the 3 lost insulated forceps.... It sounds as though the system is dissatisfied with the CPU fan speed or another power/cooling interface component (CPU over 90 centigrade, chipset over 95 centigrade, the power supply fan running, etc.) and thus shutting down immediately to protect itself. Do all those things check out, particularly in the BIOS power/cooling section? How about fan and power connections on your videocard being right and jumpered accommodatingly?
That is, you could connect tach fans on any spare 3-4 pin headers and see if favor comes your way. The system will spin them slowly once it boots and you enable automatic CPU/fan control (and power savings) settings.
Posted on May 11, 2008
I have the Mr Coffee Keurig model BVMC-KG5. It has only been used probably used less than 15 times. Now the water just drips out. Cleaned it per instructions which did not help. The machine was bought from...
It depends where the water just "drips out". It could be a leaking hose, or it could be the parts weren't put back together properly after you cleaned it. More information would be helpful.
Download Mr Coffee BVMC KG5 Manual
Feb 01, 2014 | Saeco Odea Go
I bought a dell latitude but it was password protected and i dont have it any suggestion
I'd put Linux on it.
UBUNTU link
That computer is about 5 years old. Linux works very well with old computers.
Takes up less space, uses less processor power to run, and comes with free versions of pretty much everything.
I don't even think a current version of windows will install on a 5 year old Dell. So you'd be stuck with out of date anti-virus and no updates.
Boot off the Ubuntu disk and just wipe windows.
TickMagnet
Aug 20, 2011 | Dell Latitude D520 - Celeron Intel Celeron...
I have a 96 nissan sentra with a manual transmission. I changed the clutch in it and have everything back together except the shift linkage system (the shift lever, shift control rod and support rod). I...
Well that's some pinch you have there..
There are apparently some manuals available in the net, I saw some while browsing for performance parts. However, I do not remember the sites. They are rare so do your best! I'm just not sure if there is a diagram there. Best option is, just call a mechanic to fix it for you while in the comfort of your own home. Every expert will say that you must put everything back the way you found the parts, so next time try to label them or arrange them on the floor in the order that they should be put back. That was what I was doing with my AUV before. So there, just a couple of advice. Good luck!
Jan 10, 2011 | 1996 Nissan Sentra
I had my Crosman 357 for about 15 years or so. I never used it at all until a couple weeks ago and it worked great for a few days and I liked it so much I bought more "clips", ammo and CO2 for it and then...
Well I recently bought a crosman like a month ago, I worked great, I also use CO2, then i started using it again, and all of a sudden all of the CO2 started seeping out of the barrel and CO2 area, cartridge after cartridge, so i said screw it and took it apart, and found the area that deals with the CO2 and tightened everything up. I couldn't put it back together, so i looked for the schematics and finally got it back together, then i tested it out and it works fine now. Good luck.
Oct 25, 2010 | Crosman Optics
The buttons on the front stopped working, no display
It is still under warrantee if under a year. Contact your dealer who you bought it from-it should be repaired or replaced free of charge.
Oct 03, 2009 | Microwave Ovens
Startup repair won't run
"Unmountable boot volume" this problem is your hard disk partition which is failure to recognize & identify the operating system running on the hard disk. Reformat your hard disk and put another operating system to run again your computer.
Jul 27, 2009 | Computers & Internet
VIZIO VO42LF says no signal when connect to PC after power on/off
Could be a sensitivity problem, have you tried to switch tv modes back and forth, sometimes if you do that it will save you from restarting the computer. I had a tv about 10 years ago that had a sensitivity issue, went to see about fixing it, unfortunately, the tv brand was no longer in the country and user service parts were not available.
Apr 11, 2017 | V, Inc. Vizio P4 Plasma Television
Hp pavilion m7330n motherboard issue
The system in question requires motherboard model ms-7184 and can be found on ebay for less than $100.  If your repair guy used a different motherboard you will get the issues described and need to reinstall the OS.  It is impracticle to put any more than $200 in most desktop computers more than 2 years old, your repair guy should have advised you of this straight off.  Find a new person to take your equipment.
Jun 27, 2008 | HP Pavilion Media Center TV m7330n...
Computer boots and thenm shuts downs even in bios mode
Have you tried checking if u got a floppy or cd inside?
If no, you should check the boot order, in setup.
But like 3 month's ago, a friend bought a laptop, and happened the same.
The problem was the bios.
So i went to bios setup and reset it to default.. Should work.
When a system is overclocked or some of the timings/options are set wrong this will happen. It may not apply to your situation but its worth a shot since thats most likely the case. You will find the default option in BIOS "EXIT" menu
Thanks,
Best Regards
MudiW
May 25, 2008 | Toshiba A15-S1292 Notebook
Lcd display
have you tried new batterys?
Dec 21, 2007 | Lands Phones
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
