Question about Samsung SM920NW 19 inch LCD Monitor
Monitor on and within few secong disply out - Samsung SM920NW 19 inch LCD Monitor
  • 11,361 Answers
Check the caps in the power supply first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 05, 2010
I have samsung sync master 920nw monitor . this monitor turn on after few minutes disply is going turn off ,but power butten LED working...I romove the PCB and changing All capacitor but no use ..same
The back light tubes are probably exhausted. They can be replaced, or you could try a CCFL to LED back light conversion. eBay.com has some kits for doing that.
Apr 23, 2014 | Samsung SyncMaster 920NW Monitor
Just monitor power on disply comes but after some seconds disply is gone
On Samsung 740 this is a very common problem with the high voltage impulse transformator in the invertor block. That needs to change.
May 16, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Grainy colors
i have had the same problem with the Gateway LCD Monitor and have found a solution, First go to your control panel Secong there will be a program appearance and theme there you will find something that says screen resolution click it and adjust the color scheme to 1152 by 864 pxels.
May 17, 2010 | Gateway FPD2275W LCD Monitor
Windows blue screen
it not a disply issue it's two most of the time having proble when u get bluee screen
1 is your winodws not working problem
2 hardisk problem
May 09, 2010 | Acer X203H bd Monitor
How can I set-up two monitors on a SONY VAIO PVC-RS 430G?
just folowing steps
1 go to contorl panel
2 Disply icone
3 on that page settings
4 u will find disply thare is 2 option
1 is 1.plug and play single monitor
2 will show that (defold monitor ) setect this option
u will be able to use 2 monitors
Apr 22, 2010 | Sony VAIO Digital Studio PCV-RS430G PC...
Viewsonic VA903b Flashing green light (slow)
Hi..there,
It's seems you got a busted backlight inverter problems... Need replaced with a new one. Happy Holidays!
Dec 03, 2008 | ViewSonic VA903B Monitor
Monitor disply movable horizontal lines.
yes you first check the supply at vertical ic 12v if present then replace that vertical ic if supply is not present then check the regulator ic in smps if faulty then replace it
Nov 20, 2008 | SAMTRON 55V 15" CRT Monitor
Monitor is on but disply id black
Having a similar problem.  When I turn my monitor on, the picture tries to come on, but then goes black.  After several times, I may get lucky and the picture will hold.  Is my monitor about ready to give up the ghost?  Mine is a few years old as well.
Jun 22, 2008 | ViewSonic VA520 15" Flat Panel LCD Monitor
No disply monitor
Hi, check all connection monitor power cord and push socket and tightened two screw reset computer .
Jan 31, 2008 | Computers & Internet
Samsung SM920NW 19 inch LCD Monitor Logo
24 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
