Question about Funai CR202TT9 20" TV
The picture of my Funai 28D-3728 TV is a bit over colored in red. The color balance is correct (I mean no specific zones of screen where this effect is realized (e.g in the corners or in the center)) but the whole screen is overcolored in red. For me images containing white color seems a bit colored in red... Is there a way to manually adjust/compensate/eliminate this effect? Thanks a lot!
  • 901 Answers
This is not user adjustable.
The problem is in the R G B circuit. Thr Red gun circuit is totally on!
If this is transistor driven circuit replace the transistor. The component
mostly mounted on the small PCB on the picture tube neck.
Posted on Sep 04, 2010
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
The tv is at least 17 years old.The blinking red light blinks 5 times ,then the tv picture goes off . The voice is still on
Five blinks is the error code for an AKB (auto kine bias) error. What this means is that the set isn't able to balance the three color guns (red, green and blue) of the picture tube properly, and it's blanking out the screen.
To get the proper colors, the signals for the three colors need to be balanced, and Sony sets have circuitry to do this automatically. Other brands don't, and when they go out of balance you see a picture that starts to show tinting or colors that are off. As the picture tube ages, it gets harder to adjust the balance until finally the AKB circuit can't anymore, and poof, the picture goes away. With a 17-year-old tube, it's not surprising.
There isn't anything that can be done to fix the picture tube, it would need to be replaced. But the cost of the tube and the work required to get it set up after installation makes it completely uneconomical to repair this TV. A new picture tube is nearly $200. Then special tools are required to set the tube up (a process called convergence), so you'd need to find someone to put it in, and possibly pay to have the old one disposed of. A new 32-inch LCD set is around $350 now. Treat yourself to a new one.
Jan 01, 2011 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Red Tint on Screen
This is normal and is a color calibration issue.
For correct color, NEVER use the "WARM" setting. Why? Too red. You cannot get REALISTIC or ACCURATE color using the "Warm" setting.
Since we are speaking of Samsung, first avoid the "Flesh Tone" adjustment. When things are set correctly there is no need for this adjustment. It is a quick fix and not for the "discerning eye".
1. First, access the "Color Temperature" menu. From here select "Cool2" or the coolest temperature setting.
Note: For Samsung use "Cool2", or if not available, "Cool1". Samsung has inadvertently increased calibration confusion by issueing TVs that have just "Cool1", and TVs that have both "Cool1" and "Cool2" :0[
For other brands, use "Cool", or "High", or "+6500k". Anything lower artificially reddens the picture and compromises detail.
2. Now return to the color settings and reduce "Color" to between 30 and 40 (on a 100 scale). The sweet spot is just near the place where the color rapidly washes out.
3. To round out the color palette, move to the "Tint" adjustment and ADD a couple (3-5) clicks to the GREEN.
Adding the touch of green is what is needed to take out the last bit of "pink" and will make all the tones and all colors display properly.
I hope this helps!
To further increase the quality of your picture visit
http://www.wowvision.tv/main.htm
Highdefjeff :0]
Jun 15, 2010 | Samsung LN46C630 TV
Images on screen are very red. Tried adjusting everything in the menu but still every thing is like glowing red.
Color balance is labeled "Tint"
Color amount is labeled "Color"
Both are in the "picture" adjustments menu.
Either your tint is swung too far to red, or the color setting is wide open making normally pink faces look sunburned...likely it's a combination of the two; Too much red, and a bit too much color.
Going back to the "default factory setting" in "setup" will also drop all settings to center.
Mar 30, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Cannot converge colors on screen
This happens when convergence out ICs become defective.
Replace convergence ICs on D board to get correct picture. This qualified TV tech job.
Thanks.
Sep 06, 2009 | Sony KP-51WS500 51" Rear Projection...
Green pictures panasonic fz7
Check the WHITE BALANCE settings and the COLOR EFFECTS settings (marked as W. BALANCE and COL. EFFECTS when MENU is pressed).
When you got to the MENU setting, press up or down arrow until you reached either selection, press the left arrow, and you'll see several options under the selected function. In WHITE BALANCE, there's an option whether you'll be shooting under sunny or cloudy skies, tungsten or flourescent lighting, and an option to select Auto or Manually set White Balance. This affects the over all color tone as it compensates the color correction depending on your shooting conditions. Fluorescent lighting for example exhibits blue spectrum, thus setting White Balance to FLUORESCENT will add warm or yellow tones to the photo. Tungsten lighting and sunny conditions exhibits yellow lighting, and setting to the White Balance on this mode will add cool or bluish tone to the picture.
Same with COLOR EFFECTS: settings include WARM, COOL, SEPIA or BLACK AND WHITE (gray scale).
Chances are, you have accidentally set the WHITE BALANCE or COLOR EFFECTS to any of these. To see if this is the problem, try shooting under SIMPLE MODE (Marked with a HEART icon at the rotary dial on top right of the DMC-FZ7). If the problem goes away, then it is with the WHITE BALANCE and the COLOR EFFECTS settings. Try setting the COLOR EFFECTS to "OFF", and the WHITE BALANCE to "AUTO".
If all else fails, then you got a problem with the image sensor of your Panasonic DMC-FZ7 Digicam
MANNY DE GUZMAN, JR.
SoundMagik Home Studio
Manila, Philippines
Site Creator, TEENMODELS2007
http://teenmodels2007.wetpaint.com/
Sep 27, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
White Balance
What is White Balance? The human eye captures white as white, red as red and blue as blue, regardless of whether you are outside under the sun or inside under incandescent lighting. Although this is something that we take for granted, the human eye actually adapts to correct the changes in color under different light sources. In reality, when light sources vary, colors caught as the reflection of those light sources also vary. For instance, films for cameras that use film are designed to capture the most appropriate coloring outside under the sun. Thus when you take pictures under incandescent or fluorescent lighting without using a flash, the colors in the resulting picture may seem strange. Digital camera and digital camcorders are equipped with a handy feature called "White Balance" that corrects the changes in color under different light sources, just like the human eye. One of the white balance settings, "Auto White Balance" (AWB) automatically adjusts to correct the changes in color under different light sources. White Balance and Coloring The White Balance feature on Canon digital cameras and camcorders is set to "Auto White Balance" at the time of purchase. If you prefer different coloring, if you want to adjust the coloring more in detail, or if you want to change the coloring on purpose, we recommend that you change the white balance setting.
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
White Balance
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Funai CR202TT9 20" TV Logo
98 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
