Question about Ariston Technologies Dishwashers
Our Ariston LI645A dishwasher is not drying the dishes completely and whenever the cycle has finished, it always resorts back to the ECO cycle whereas we usually have it on the normal cycle? I have filled up the rinse aid but it does not seem to make a difference. The manual also says to put refined salt into the salt dispenser - i have not done that yet as was not sure exactly what `refined' salt is and where i can get it from. thanks
  • 11 Answers
To check on the source of the white powder (calcium?) soak some dishes in vinegar to see if this cleans them up nicely ... or if the 'white powder' is actually permanent etching. You may have very 'hard' water and will need to deal with that with a water softener or additives.
Read the following article for a better understanding and try the vinegar test . (also ensure you are using dishwasher specific salt to regenerate your integral softener... assuming you have one)
Posted on Nov 02, 2007
  • 5 Answers
SOURCE: Drying problem
As I had the same problem, I worked on my machine and found out the heater unit was not working (it is a brand new machine ! - remark : as I moved overseas, LG did not cover it with their warranty).
But back to what I did : I ran the check program (instructions can be found in the Service Manual) and verified it was sending voltage to the heater on step 36. So I checked the heater unit (in the bottom of the machine) and found it was burned or open. So I ordered a new heater assembly ($40 on eBay), replaced it myself and am completely happy with the results.
Remarks : the heater is powerful enough to heat cold water to the temperatures required (I don't have hot water in the faucet); it seems that the heater also produces heat for the drying cycle (my dishes were completely wet at the end of the cycle before, now they get completely dry). My only disappointment, mentioned by some in the forum, is that the outlet during the drying cycle is in the bottom of the door, so steam condensates into droplets on the kitchen floor. But now I get clean dishes, and this machine is amazingly silent and efficient. Good luck to you !
Posted on Mar 17, 2009
  • 677 Answers
SOURCE: Dishwasher rinse-aid dispenser not working
the film is caused by hard water. go to they have a product out for this exact problem. works amazing every time and is very affordable.
Posted on Jan 01, 2010
  • 105 Answers
SOURCE: Dishes not clean after cycle!
Is the water coming into the dishwasher and is the wash motor working or is the sump clogged up so the water cannot get thru.Depending on the purchase date of the dishwasher, if it is a under a year old call who ever you bought it from as it usually comes with a 1 year manufactures warranty.
Posted on Feb 06, 2010
SOURCE: I have a nardi dishwasher
nardi dishwaser water will not drain away after wash cycle.
Posted on Sep 08, 2010
My dishwasher suddenly won't wash hot on either the normal auto setting nor the eco one.
Do you find water left in the dishwasher bottom at cycle end???? It sound like your drain line is partially or completely blocked or possibly a bad drain pump depending on model. If it can't drain completely it can't refill with hot water. That will also explain an increase in the cycle time. Some dishwasher add time because it is trying to heat the water up. Its a loosing battle if the water isn't partially hot to begin with.
Apr 03, 2015 | Dishwashers
How to repair - no water is entering the dish waterr
Your dishwasher is equipped with a safety system which is able to detect any operating problems. These anomalies are reported by
one or two wash cycle indicator lights "E" will flash rapidly.
Any flashing combination of LED diodes (Intensive wash, Regular wash, Eco wash, Rapid wash, Soak and Crystal care) means different error code. Take a note of which lights are flashing?
If you have problem with fill water than following two LED should be flashing.24428775-0h3kxpflbez5mdeb5anq3st4-3-0.jpg
In this case could be:
  • Water valve disabled
  • Turbine disabled
  • Control board faulty
May 15, 2014 | Ariston Technologies LL65 Built-in...
Ariston L64 dishwasher first 2 lights flashing what does this mean please!
Ariston LI6401-Washed a load. Last light on R control panel (Eco Wash) is blinking rapidly and didn't dry the dished.Turned pwer off then on. Did same type of wash. New maching-This is about the 6th wash
Mar 16, 2011 | Ariston Technologies LI640S Dishwasher
Dishes not drying properly
You may have it set to an ECO wash (economy)witch may exclude drying cycle at the end to save power.
May 28, 2010 | Viking DFUD042 Built-in Dishwasher
Feb 06, 2010 | Dishwashers
Poor washing and drying
I have the same problem. Could you please let me know if you find a solution. I will do the same.
Jan 09, 2010 | Ariston Technologies LI640S Dishwasher
How do you get the washer to dry dishes? What
Check the operators' manual.Don't use the drying element as it's costly on the electric bill.When the washing cycle is complete leave the door partially open and let the water evaporate
Sep 28, 2009 | Bosch Integra® 500 SHX55M05UC Built-in...
I have an Ariston LL65 and the eco and rapid light are flashing
I have the same issue, so Dish-washer Ariston LL65 with Eco and Rapid light flashing. Can you help me to undestand the issue and solve it ? thank you, Regards.
Sep 01, 2009 | Ariston Technologies LL65 Built-in...
We bought a used Roper dishwasher not too long
I was having the same problem with a Roper dishwasher and the Palmolive Eco gel. After doing a little research, I found that the detergent I was using doesn't work well with hard water. I emptied the machine, then poured in 2 cups of white vinegar and ran it on a complete cycle. This cleaned out any hard water residue build up inside. I then begin using electrasol with jet dry tablets for detergent and filling the rinse agent reservoir with white vinegar. I have had no problems since.
As for the heated dry, is it really heating or are you just feeling the heat left over from the very hot water used in the washing and rinsing?
Jun 12, 2009 | Dishwashers
Dishwashers Logo
131 people viewed this question
Top Ariston Technologies Dishwashers Experts
Renee Knafel-Bullock
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
