Question about Sony Televison & Video
Can only veiw picture in black & white with the tv. When watching DVD's they are in colour?
  • 236 Answers
SOURCE: TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Posted on Mar 03, 2007
Benimur
  • 6966 Answers
SOURCE: no colour on television
Hi, It is possible that the reason for the black & white as well as lines across the screen is weak, defective or wrong oriented antenna. If you are hooked up to cable, then it should not be a problem as you can call for service; if on the other hand you are using aerial antenna, you can try to: reorient or adjust the direction to where the antenna is pointed until the reception improves, check the lead in wire (cable or flat) for any breaks or shorts or loose connection, check/clean the connection of the antenna elements to the cable/flat wire, replace your aerial/cable as may be deemed fit and needed. A couple of questions pls if the above does not solve your problem: when receiving from aerial, is the picture full vertically? are you also having problem with sound? If yes, where was the TV bought and where is it being used now? If no, is the image snowy and some channels/stations are better than the others? Good luck and pls post back how things turn up or further information. kind regards.
Posted on Aug 12, 2007
The Wolf
  • 10 Answers
SOURCE: black & white picture on vcr & dvd playback
Check your VCR or DVD for correct region and standard. If I had a camcorder, VCR, or DVD player here in America on Pal standard or eupopean region the same thing would happen.In fact I accedently did that on an unknown switch on the camcorder.
Posted on Dec 05, 2007
rey jr
  • 149 Answers
SOURCE: tv picture going green
hi there, you have a color section or video section problem, check the crt board, there may be and open resistor or jumper, check those transistor driver too. check the small board at the back of the crt tube, do some test and see any cold solder. ty
Posted on Dec 29, 2007
jerryg50
  • 1689 Answers
SOURCE: lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Posted on Apr 12, 2008
My Plasma 42PD580DTA
I assume your DVD is coming up in colour when you plug it into a standard scart connector? Have you tried using a different S-Video cable because this sound symptomatic of a dodgy lead?
Check the SCART end of your lead for any bent or broken pins.
Failing that if the problem lies with the TV itself I'd really recommend having a pro look at it. Plasma's are expensive and opening it up if you don't know what you are doing is a bad idea.
Dec 02, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Dvd plays black and white tv is colour
be sure to check all your input/output connections & cables
Nov 26, 2013 | Digihome LCD TV
DVD Playback is only Black & White
Different areas use different colour systems. The most common types being PAL and NTSC. What I think you might have done is changed the colour type setting to one that is not compatible with your TV. If you have the manual look up the colour settings. If you haven't got the manual look around the main menu for them. If all else fails use the factory reset.
Mar 12, 2017 | Toshiba Bdx1200 Blu-ray Disc Player
Panasonic DVD Recorder DMR-EZ48VEB. Colour missing
I have a Panasonic DMR EH50 DVD recorder and have just discovered this evening that everything on it is displayed in Black & White (tuner, recordings, menu, dvds etc). Yesterday everything was working in full colour. I have checked all my leads and have no solution to this problem and also need help.
Jan 03, 2010 | Panasonic Televison & Video
We have a black and white picture on the TV, no colour
check for DVD/TV cable. Use a SCART 21 conductor cable (if possible with gold contacts), or HDMI Cable if Tv has HDMI Input
Nov 29, 2009 | Panasonic DVD-S35 DVD Player
FUNAI drvr-b778
Use a head cleaner to clean the heads on the vcr.
Jan 09, 2008 | Funai PY90VG DVD Player/VCR
Lg 32lc2r, only showing picture in black and white
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
Black & white picture on vcr & dvd playback
Dec 04, 2007 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
