Question about Linksys WRT160N Wireless Router
When I run the set up wizard for my Linkksys WRT160N V3 router, I get the message "Cisco Setup Wizard requires that one wired network adapter be enabled. Error 314: Could Not Disable Wireless Adapter(s) Follow these steps: 1) Disable all your wireless network adapters (but do not disable your wired network adapters.) 2) Click Retry to try installing your router again" I've done all the above, but the message just comes again and the router refuses to install.
  • 550 Answers
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on Sep 04, 2010
Lost my installer cd for wrt160n v3
Many newer routers don't actually require an install CD to work.
Connect the ISP modem to the main network port. Now connect the computer to any other port. That's it. All done
This just refreshes your IP. In PC go to Start > Search (run in XP) and type cmd ENTER. In the command prompt type ipconfig /release ENTER. Then type ipconfig /renew ENTER.
Save this information: Linksys WRT160N Login via web browser at 192.168.1.1 User: (none / blank) Password: admin
Oct 13, 2012 | Cisco Linksys WRT160N ULTRA RANGEPLUS...
Setup ea4500 router
You must use your Cisco Connect CD Install, this runs a wizard, otherwise you need to know default IP address, administrator password and some other data.
Please check your prouct home page at: http://homesupport.cisco.com/en-us/support/routers/EA4500
Sep 17, 2012 | Linksys EA4500 Dual-Band N900 Router with...
I lost my installer cd for WRT160N V3.
Click the link below:
Linksys wrt160n
Click "Downloads"
Click the dropdown menu and choose version 3.0
Scrolldown and download the Setup Wizard that is right for you.
Rate my answer if this helped you.
Sep 08, 2011 | Linksys WRT160N Wireless Router
I need windows xp 64bit driver of wusb54gc v3
Cisco / Linksys provide a setup wizard on their site for XP user.
Link HERE to get to the download page.
Jul 30, 2011 | Linksys WUSB54GC 802.11g/b Wireless...
How do I set up a valet m20 router with a computer that runs windows xp 2000?
Welcome to FixYa!
If you still have the installation disc that came with the router, you can go ahead and run the disc and follow the instructions. The Cisco Connect Software will be installed when you run the supplied Setup CD or Easy Setup Key on a computer. Once Cisco Connect is installed, you can then use its features to easily manage and share your network resources.
QUICK TIP: Create a Desktop shortcut to launch Cisco Connect easier.
Windows XP
Step 1:
Click on the kb21465-001_en.png button and select All programs.
Step 2:
On the All Programs sub-menu, locate and select Cisco Connect. This should launch Cisco Connect and take you to its main screen.
NOTE: If you are unable to locate Cisco Connect, it may not be installed yet. Download the latest Cisco Connect setup wizard from the Cisco Support page. After downloading, click on the Cisco Connect icon to launch the installation wizard.
Hope this will help...Thank you for using Fixya...
Feb 28, 2011 | Computers & Internet
I dont have the cd to install the router
go to this website
http://homesupport.cisco.com/en-us/wireless/lbc/WRT160N
click the downloads tab
select the harware version of your router
download the setup wizard
connect the modem to the valet ( internet port )
connect the computer to the # 1 port of the valet
run the setup wizard
Sep 12, 2010 | Linksys WRT160N Wireless Router
I can't find the WEP for my linksys WRT160N
Start Internet Explorer.
Login to the web-server "inside" the router.
Run the "Wireless Network Setup Wizard",
to enable 'WPA' and to set a password/passphrase.
Aug 01, 2010 | Linksys WRT160N Wireless Router
Error 311 no wired adapter detected
For that right click on my computer icon then click on property then hardware-<device manager.
Then you can see all driver list click on network adapter and enable it.
You can configure your router without disk too.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
May 16, 2010 | Linksys Wireless-G WRT54GS Router...
I have a desktop and a laptop (new for xmas) and I want to set up the laptop to the wireless-N Router Model WRT160N. I am set up with internet through a bundle system through our television. Do I plug the...
first a couple of things.
if your router has wireless support your laptop (if new) should have a wireless adapter built in, so basically your destop computer can be wirely plugged into the router and your laptop shoud "connect wirelessly" to your adapter
so this is how your set up should look like
desktop
--cable-- = - cablemodem - = linksys router = ----- wire----- desktop
laptop
--cable-- = - cablemodem - = linksys router = ))wireless))) laptop
you need read up a bit, here are some links that will have info you need
manual for wireless configuration (select the proper revision for your router and check user manual)
configure wireless network for vista
read up and if you have any questions post back.
hope that helps.
Dec 26, 2009 | Computers & Internet
My personal network which i set up about 6 months ago when i purchased this router, will no longer allow me access to the internet. I can however gain access when i switch to other available networks
Connect to the web-interface of the router, and click "reset to factory settings". Then, run the "Wireless Network Setup Wizard" to recreate your personal wireless network.
Nov 06, 2009 | Linksys WRT160N Wireless Router
Linksys WRT160N Wireless Router  Logo
487 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
