SOURCE: Motherboard EG31M
test all leads that attach to your hard drive including electrical extensions IDE SATA the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working also check your computer ram modules and cmos battery to make sure they are dust free and securely seated and the battery has plenty of charge Cmos battery on some motherboards are soldered in
if its a 40 pin ide it will be the first to fail
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty
hope this helps you
SOURCE: I need the motherboard layout for an Acer Aspire
heres a nice reference link,
http://www.newegg.com/Product/Product.aspx?Item=N82E16883103162
but i suggest you run a free program called belarc advisory. it will detect and display a report directly from your pc. just download and run the application.
http://belarc-advisor.software.en.softonic.com/download?gclid=CPbE_Ljw0KYCFce7KgodlFFTJg
heres a nice layout of the system and all its features and dimensions. scroll down to see complete page details
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3860985&CatId=3702
SOURCE: The manual and layout for
Thank you for using FixYa.com.
Click here and when the site loads, click where it says Veriton 7500. It will download an Adobe PDF document which includes all the information you need.
Thank you.
