Question about IBM Lenovo ThinkPad T61 Notebook
When booting I get an Error 0210: Stuck Key 01 Lenovo Thinkpad t61
5 Suggested Answers
SOURCE: i have error 0210 stuck key 01 on an IBM
My key R is stuck. And some some letter keys become numbers once I press them
Posted on Jan 28, 2010
  • 111 Answers
SOURCE: error 0210: stuck key 01
I assume its a laptop. laptops some times get stuck keys, meaning one of the keys has not fully released after it was depressed. I recommend getting some compressed air in a can and give it a good cleaning. there might be something stopping git from popping back up. then give the keys a little work out. just mash the keys a bit. then turn it back on. if you still have an error, then you might want to consider replacing the keyboard. if you don't, it will not harm you pc in anyway...good luck
Posted on May 04, 2010
tagmonkey2k
  • 117 Answers
SOURCE: Error 0210: Stuck Key 01
This is a system board POST/BIOS error code (nothing todo with Windows). The ERROR 210: is a standard POST (Power On Self Test) errormessage that indicates an error with the keyboard. The error condition is thata keyboard scan code was received from the keyboard when none was expected,after the keyboard was reset. If this occurs most of the time when you power on yoursystem, then it indicates that a key is sticking down or the key mechanical orelectrical parts are broken. Sometimes blowing out and cleaning out around thekeys will resolve this problem. Otherwise, you need to replace your keyboardwith a new (or at least a working) one.
Posted on Apr 19, 2011
aaron_gomm
SOURCE: ibm thinkpad error code 0210 stuck key 0f
check that you haven't screwed in a screw that is to long in the bottom of your thinkpad if so you may have ******** up your motherboard
Posted on Apr 14, 2012
Lenovo R400 Error 0210 stuck key 5b
Stuck key error means that one or more keys on the keyboard are stuck. It's possible that a liquid spill can also cause one or more keys to electrically "short" causing the error. Inspect the keyboard and check if any keys are mechanically stuck.
If you're mechanically handy you can remove the keyboard, inspect any chances of damage or corrosion. Plug it back and see if error is still occurring.
Reset BIOS to default settings. Perform Flee Power - remove the battery and any other peripheral device connected to the computer. Hold the power button for 10-15 seconds and then connect only the AC Adapter and turn ON the computer.
Aug 19, 2016 | Lenovo ThinkPad R400 Notebook
T500 - error 0210 key stuck 3C
It sounds like a stuck key on your keyboard. You can try dusting off the keyboard with compressed air. If you see any dirt or debris you can try to remove it gently from the keyboard. You may have to replace the keyboard. If that is the case you can replace it yourself or have someone competent do it for you.
Jul 16, 2014 | Lenovo ThinkPad T500
ERROR 0210: Stuck key 7B Press F1 to setup . Please help me out of this problem.
There are issues with the ThinkVantage Button at boot as it doesn't do what its suppose to. Just use the F1(BIOS Setup), F11(pre-boot/recovery area) and F12(boot device selection).
Just a reminder to practice press and release when pressing a button. We sometimes get impatient and do a key hold down for a while rather than multiple press and release.
I hope this would resolves your ERROR 0210: Stuck key
Jul 20, 2011 | IBM Lenovo ThinkPad T61 Notebook
ERROR 0210: Stuck key 7B, what do with this?
if this Problem before windows you need to reset keyboard cable anf if the Problem still you need to replace the keyboard
else if the Problem after windows just repair the Windows
Jul 11, 2011 | IBM Lenovo ThinkPad T61 Notebook
I have error 0210 stuck key 01 on an IBM
Nov 17, 2009 | IBM ThinkPad 390X 2626 Notebook
Oct 17, 2009 | Lenovo ThinkPad R61i Laptop
ERROR CODE "0210:KEY STUCK 39
I got the 0210 stuck key error on a Lenovo Thinkpad T61, pc would not bootup, made sure keyboard was connected and cleaned with aircan and then went into bios and via F1 on startup, then went to CONFIG then to Keyboard/Mouse then I disabled the TrackPoint. Boots up fine now but the red nipple mouse is disabled due to action mentioned above. Looks like a warranty fix for Lenovo since this is a newer laptop. If it was out of warranty i would just skip using it and leave it disabled. The trackpad works fine.
Apr 27, 2009 | Compaq Presario 1200XL111 Notebook
Problem .......x61 tablet help !!!!!!!
Hello snapshots,
I have an x61, and you may want to check that all of the keys on your keyboard are not damaged, and that none of them are stuck in the pressed position. That is what the "stuck key" message typically means. If you check out the keyboard, and all the keys are fine, and if you are still receiving this message, try calling Lenovo support. There is an off chance that your keyboard (or other components) may be slightly defective.
Here is the link to the Lenovo site: http://lenovo.com/planetwide/select/selector.html
Hope this helps!
Jeff
Feb 27, 2009 | Lenovo ThinkPad X61 Tablet PC
Open Questions:
See all IBM Lenovo ThinkPad T61 Notebook Questions
IBM Lenovo ThinkPad T61 Notebook Logo
545 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
