Question about Exercise & Fitness
"Notify maintenance" is coming up on the display of my Lifestride 9500HR treadmill. If I was to call out an engineer to fix it, can you possibly suggest the maximum amount it may cost me to get it fixed? Just as a ball park figure as I am wondering if I should just ditch it. Thank you for any advice you can give.
  • 79 Answers
First tell me what else appears after the message "notifies maintenance" if you press the enter key "will show what the error log. it would be easier to help. For details, send me an E-mail to cardiotech_me@hotmail.com
Posted on Sep 11, 2010
  • Mouseyb Oct 11, 2010
    hi outfield502 i have the same problem as the person above but when i press the enter key it does not change anything so i was wondering if you could email me any other information any help would be appreciated my email is benbridgland@hotmail.co.uk
  • IzzyHendrix Nov 25, 2010
    I am also having the same problem. Usually Im able to just unplug or turn off the treadmill and the notify maintence disappears. However now it wont. Ive pressed the enter key and nothing changes. Has anyone figured out why these machines are doing this? And how to fix it?
We have Lifefitness 9500HR Treadmill. I am getting a Bad Controller Error. We have two 9500HR models. I swapped out Controller, with working 9500HR and still get Error. Keeps going into Notify Maintenance....
I would suggest swapping the consoles to see if the problem follows. If this does not help you figure it out, you are more than likely looking at a wiring issue.
Sep 23, 2013 | Life Fitness Exercise & Fitness
I have A Life fitness 9100 treadmill The display shows the message "maintenance notes wax over" how can I remove this error?the treadmill will not turn on HELPPP
see this steps and fix it. .Of course you must read your instr. manual or download from www. iconservice.com
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
  • 2 Press the "ENTER" button three times to access the treadmill's error log.
  • 3 Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
  • 4 To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
  • 5 To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
  • Oct 17, 2012 | Life Fitness Lifestride 9100 HRT...
    Lifestride 9500 treadmil show noilfy maintenance display
    proceed with the instruction manual maintenance, if you do not have go for free download : www. fitness.manualsonline.com or www.iconservice.com
    RUN THE software calibration for diagnose, troubleshooting, and fix it.
    sincerely. God bless you
    May 07, 2012 | Life Fitness Lifestride 9500 Treadmill
    Notify maintenance
    http://fitness.manualsonline.com/manuals/mfg/life_fitness/9700hr.html?idRes=11637493
    GO TO DOWNLOAD THE MANUAL FOR YOUR TREADMILL 9500HR FREE, AND EXECUTE STEP 14-15-16 and Ready.
    sincerely.
    Oct 17, 2011 | Life Fitness 9500HR Next Generation...
    9500hr treadmill said "notify maintenance
    Your treadmill is notifying you that some maintenance operation has to be performed.
    Nov 21, 2017 | Life Fitness 9500HR Treadmill Next...
    Notify maintenance motor controller comm bad
    I own a gym and have 5 9500's...unfortunately it sounds like it the motor controller board which is around $800. National gym supply or sprotsmith has the part.
    Jan 28, 2011 | Life Fitness 9500HR Next Generation...
    Treadmill stop then display an error speed
    If the is a Next Gen unit need to enter Diagnostic menu by pressing and holding pause then press clear twice. Continue to hold pause until until read service menu. press any arrow up and select system test ,then press enter the display will begin to automatically scroll thru available options. press enter to access Main Motor Module the next window will be Speed Automatic.
    Upon entering this test mode you will able to check the drive motor and motor control board. By using the the speed arrows you will be able see the actual speed if functioning if not it could possibly be the speed sensor or wire harness ( SIMPLE CONTINUITY CHECK WILL RULE IN OR OUT THE HARNESS ) and point the problem. Now if their is no belt movement then hit clear and proceed over to SPEED CONTROL ERRORS hit enter this test allows seeing the motor controller conditions that are being displayed on the motor controller display if any of these come up then the controller need s to repair or replaced:
    Max Temperature, Maximum voltage, Fault Line 1 error, Static current trip and dynamic current trip ( this also can a running belt tension this can result in a cannot obtain speed error message ) hit clear to get out of diagnostic once you eliminated the problem. Good Luck!!!
    May 21, 2010 | Life Fitness 9500HR Next Generation...
    Error message notify maintennce motor controller comm bad
    Every time I have gotten this message, I have had to replace the motor controller.
    Mar 16, 2010 | Life Fitness 9500HR Next Generation...
    Exercise & Fitness Logo
    160 people viewed this question
    Top Exercise & Fitness Experts
    Electro Med Services...
    Howard
    Howard
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
