Question about Yamaha RX-V420 Receiver
Input keeps changing during play - Yamaha RX-V420 Receiver
I have a Sharp LCD that keeps changing inputs and will randomly turn itself on.
Sounds like you have another infared source that the LCD is seeing. Put opaque tape over the infared receiver and see if the issue continues. Look for another IR device in the area.
Nov 09, 2014 | Sharp Televison & Video
I get a popping sound when I switch it on or off.... It happens through Trans and Valve Amps - doesn't matter where it is in my pedal chain or if it is on it's own
It sounds like there is a DC bias in the unit. Put a short circuit on the input and then cycle it and listen for the pop when changing state... if it does, then it needs servicing... and POSSIBLY a circuit design change. Looking at typical schematics, about the only problem might be leakage at the input and output coupling capacitors UNLESS you are driving it (playing or having a string sustained during switching). If you have a string still going during switching, you probably will get a discontinuity in the form of a pop.
Sep 17, 2011 | MXR GTOD Pedal Guitar
I lost the remote for my LG DVD receiver model number LHT754 and i cant chance the inputs
If u are trying to change the input from dvd to usb or the other inputs. All you have to do is hold down the play button on the front of the dvd home theater system until it starts to flash then press it again and keep pressing until u find the input u are looking for. It will rotate thru all inputs even the ipod input.
Sep 26, 2010 | LG LH-T754 Theater System
My belking keeps losing connection during games?
If your wireless you probably need to change broadcast channels on the router ( to the last channel) if its hard wired, you probably need to port forward the ip address for the Xbox
Oct 05, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Unusable signal
video inputs do not have channels you must not have it on the right source. Turn your Wii on then change the input untill you find it.
Sep 08, 2009 | RCA F32648 32" TV
How to change resulution when you get input not
Try starting Windows in Safe Mode. During boot, before windows starts loading, just keep tapping F8, until a menu appears in which you can select Safe Mode. In Safe Mode, set the resolution to a safe, low value in the control panel. Then reboot normally, and everything should work fine.
Jun 07, 2009 | Acer AL1916W 19" LCD Monitor
During playing game it freezes up can t even play
man u should  keep ur PS3 COOL and try to make some free space in the HD, but keep it COOL ok
May 17, 2009 | Sony Playstation 3 (PS3) Console
Channel keeps changing to 'Input 2' even when playing DVD
Have you taken the remote control out of the room? Try changing inputs from the TV.
Dec 21, 2008 | Sharp 32F641 TV
Home Theater Systems Sony DAV-HDX465
you will probably have to select you wii int an input on the reciver.sometime the reciver will use an aux secection
Mar 18, 2008 | Televison & Video
No input during Voicemail
Under 'Settings>Initial Setup>DTMF', if it is turned Off, change it to short or long and it might help.
Feb 24, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Yamaha RX-V420 Receiver Logo
21 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
