Wiring diagram for portable air conditioner
I need a wiring diagram for a Cool 438656 portable air conditioning unit.
I think the wiring diagram is on a printed sticker on the side of the water collector, just pull it out of the right side as you look at it. There should be one on there hope this helps as i have the same unit in the other room. regards Richard
Posted on May 29, 2009
Unit exhaust air is cool
Is this in a commercial application and happen to be an economizer which I'm restaurants mostly they work by giving the hot building "free air conditioning" from colder outside air to save power.
May 28, 2016 | Haier HPR09XC7 Portable Air Conditioner
Tip
Portable Air Conditioning great portable air cooling
Portable air conditioning offers you the convenience of mobility. All you have to do is roll the portable air conditioner to the room in which it's needed. Install an exhaust hose out a window or other opening (everything you need is provided) and turn it on. The installation process for these units is very simple. These portable air conditioning units are built small enough to be very mobile and are supplied with wheels for easy movement. A portable air conditioner will also work very well in apartment situations where you will often find a window unit is unacceptable.
Portable air conditioners are very unique in that they are portable and can be easily moved to different locations in your home or business. They can be a highly effective way to either help out an existing HVAC system in one room or cool a single room entirely. They are also one of the best ways to cool a room or area without having to install a window mounted unit.
These air conditioners use a compressor and Freon to cool just like normal air conditioning. They are very effective in cooling rooms and to keep the humidity low. Like normal air conditioners portable units extract hot air that must be vented. That is why they need to have the exhaust hose to the outside. These units can cool air as well as air conditioning done with window air conditioners. However they do not require installation like conventional window air conditioners this makes them very convenient for seniors or physically challenged people. Most portable air conditioners are supplied with a window kit. This kit contains exhaust hoses that will work in any window: double-hung, casement, awning or slider. Because they vent through an opening like a window they require no permanent mounting like window air conditioning.
Portable air conditioners are a very good cooling option for those who can't use the more conventional air conditioning methods. Remember though that this type of unit is not as efficient as most window units or conventional air. So while they may make your environment cooler, it won’t turn your tent into a room at the local hotel.
So as you can see these air conditioning units have some great advantages over other types of air conditioning. They are a great alternative for unique applications where central air or conventional window units are either unfeasible or too expensive. During special events, portable air conditioning can also be a great way to keep guests or equipment cool and comfortable. Always be aware though that because portable air conditioning will remove moisture from the air, they will also need to be drained occasionally similar to a dehumidifier.
Does your application warrant a permanent air conditioner of some form or should you just use a portable one? There are some interesting things to consider when making that choice. Weigh out all of the different options and make that decision based on what will best suit your needs.
on Dec 13, 2009 | Heating & Cooling
When set to heat it blows out cool air.
Chances are your portable unit is a reverse cycle unit...If so, the leaving air temp in heating mode is not usually much warmer than room temp with 85 degrees F just about the maximum under PERFECT design conditions. A small portable in a large cold room may only be discharging 75 degree air, which is going to feel cold.
If your unit is NOT a reverse cycle unit, the heating source (probably electric resistance) is either not coming on at all or a portion of it is not coming on due to a defective element, burnt wire or a control issue.
Jan 08, 2015 | Amcor AL10000EH Portable Air Conditioner
I have a portable roam air condition i dont know where to add the water
You don't account unit takes out humanity in th he air to cool house or rooms you need to drain the water to outside
Apr 12, 2014 | Amcor PLM-14000E Portable Air Conditioner
Wiring diagram
Have a look on the inside covers, often a wiring diagram sticker is placed on it.
Sep 21, 2013 | General Electric APE08AK Portable Air...
No manual for a cool 438656
Recent Carrier Xhb123d Xy Series Heatcool Air Conditioner ...
domecrel.com/recent-carrier-xhb123d-xy-series-heatcool-air-conditioner/
Download Your Carrier Manual - Oge. Recent carrier xhb123d xy series heatcool air conditioner Heat ?^' enables the heating equipment to operate as needed.
Jan 05, 2012 | Carrier XHB123D X/Y Series Heat/Cool Air...
Info ob use of this product
window ac unit,,,,,,,not much to do with them turn it on if it cools ure good if it dont check the filter,,,,,,,,,unfurtunately with the labor costs and prices of freon the window units pretty much a not worth the service fee item just dispose of it and buy a new one when it craps out as for disposal a sighn on it at the end of the driveway saying free scrap metal will usually get the attention of some junk removel scrap guy xxxejxxx
Sep 27, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Portable Room Air conditioner will not cool
You need to call for for a qualified technician oil residue is a sign that your unit have leaking, your unit is out of refrigerant.
Nov 12, 2007 | GE APN10AA Portable Air Conditioner
Heating & Cooling Logo
716 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
