Question about Ovens
How do I set the clock on a tecnik oven>>? - Ovens
  • Ovens Expert
  • 414 Answers
Generally, if you press and hold down the second and third buttons from the left and then use the + and - to select correct time. Then press the button with the hand on it, this will set the time. If this does not help, please repost with model number.
All the best.
Posted on Sep 05, 2010
  • chuckalot Jul 15, 2011
    ronidavey, you are saint, you have no idea how long i have been searching for a solution to set the clock. Your advice was spot on. Many many thanks.
I have a new Neff U15E52N3GB oven and I have to reprogram the clock each time I want to use it. Am I missing something on the original set up or is it a Naff Neff?
you are, that sounds like your setting the timer for cooking not the clock.....switch the hole thing off at the wall then put it back on, the clock should flash, then set it, check the manual for button config.
infact i just read it, & its on page 10 2nd paragraph on right hand side...........
You can only change the clock when no other clock function is
active.
ie switch it off & back on at the wall.
1.Press the < > clock function button repeatedly until
the< > O(pic of a clock) and symbols light up.
2. Set the clock using the rotary selector.
The setting is applied automatically
Dec 12, 2014 | Neff Ovens
Tecnik Range dual fuel TKC 1285 (more than 10 years old) The timer clock doesn't work so we cannot set the timer for the oven to come on later in the day + Our oven doesn't work when we...
No you can replace timer or bypass it to make it work. I can source parts for you I and fit if required. David 'The Famous Forry'
Oct 20, 2017 | Tecnik Ovens
Since a power cut yesterday, our Tecnik 8522 oven has flashing 'A' (Auto) on the clock & the bottom oven does not work. I know I have to reset the time to get te A off but no buttons work on the facia...
If you cannot change it from auto. to manual it doesn't mean you need a new oven. The electronic timer can be by-passed fairly easily by joining the active and oven load wire together..
Feb 10, 2011 | Ovens
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
Hi i have no manual and cant get bottom oven working
make sure the clock is set properly. eg not in manual mode
regards
richard saupe
appliance repairman
Mar 14, 2010 | Tecnik TKC8085 Electric Double Oven
Cant reset the clock
Press the cook time & ready time buttons simultaneously and keep the buttons depressed. use the plus and minus buttons to set the time of day. A (Auto) symbol goes out, cookpot symbol comes on.
Jan 06, 2010 | Tecnik TKC8522 Electric Double Oven
Problem with electric single oven Tecnik tkc241/2
Hi, switch off the mains for the cooker, wait for about 15 seconds, switch it on (0:00 flashing) then press the 2 buttons on the left at the same time and hold them, and then press the - or + button to set the time.
Cheers
Feb 19, 2009 | Tecnik TKC215/3 Electric Single Oven
Main Oven Issue??
the clock need to be set to work the main oven
Dec 03, 2007 | Tecnik TKC8525 Double Oven
ONE OF THE OVEN DOESN'T WORK,
Yes the clock needed reset, by pressing down the stop cook and start cook buttons together, then +/- to the 24 hour clock time. then it works!
Sep 10, 2007 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
