Question about Thetford Porta Potti
Body of electric flush and slide opening is broken can i get this part and put my old parts on same
  • 944 Answers
Yes you can replace the parts and put in your old electric flush.You can see the diagram how to take apart and you can place the order for these parts in the below site.
Placing orders direct link check here
For different model no and parts check here
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 04, 2010
The electric motor wich opens the door is making some clicks while opening and keeps clicking continuously when it reach the end. What can be the problem and how do i fix this?
you must lube and see if there are some parts loose or broken. However you must test the motor for to see if is defective. go to www.aa1car.com get the topic and fix it.
God bless you
Nov 20, 2013 | 1995 Nissan Altima
Sliding shade is stuck and won't slide. Glass is down in 1 corner, not flush with roof
the shade may be related to sunroof not closeing completely, the most common reason is the track is broken , this is the most common reason for when the sun roof doesnt close or jams when opening or closing its always the track breaks, the way to check this is to easy the headliner needs to be dropped and removed and then the glass from sunroof removed then unbolt track and drop down into car and check the track linkage and arms and track and see whats broken, note there are no replacement parts only motor or cable, as far as the parts that always break like an arm on the track this is not replaceable the track needs to be replaced, hope this helps , good luck.
Feb 06, 2011 | 2005 Chrysler 300
The on/off slider is stuck on won't slide to off position
The trimmer/switch is broken. You will need to replace it. You will find the components that you require at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8995-8595-and-8795-body-housing-with-trimmer-p-684.html
To replace the part you will need to remove the 'cap' that surrounds the cord hole on the bottom of the shaver by gently prying it off with a small flat screwdriver or similar object. Once removed, the side grips will easily pull off revealing 4 screws. Remove screws to seperate the front and back case. The inner parts simply lift out and you can put them into the new case
Mar 22, 2010 | Braun Activator 8595 Electric Shaver
Own a used 1997 C5 vetter The drivers inside door panel has come loose from the exterior frame appears to have white plastic inserts that are not staying attached to inner door panel how to fix?
the white clips[panel clips common standard design] probably broke or the ridges wore down most auto stores carry the clips the old one slides out- slide in new and line up hole in door and push panel into place it will click and snap into place dont push to hard just enough that panel is flush and no gap
Feb 10, 2010 | 1997 Chevrolet Corvette
I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Jan 21, 2010 | Maytag MER5775Q Electric Kitchen Range
Speed switch stuck on 2
Suggest you open the drill, and see if the plastic slide for the dual speed switch, is stuck in the body of the drill.
From this, you will know if it's a simple fix of correcting the slide action of that plastic selector slide, or if it is going to require replacement of the switch itself.
The plastic selector slide, slides back and forth in a groove, on either side of the drill body. Could be something simple. Perhaps some dirt, or metal shavings, that can be removed.
Maybe there is a burr on that plastic selector slide. Perhaps a little lubrication will help also.
If it's the switch itself, parts have come loose inside due to breakage. Replacement would be necessary in this case, unless you are really prolific at fixing broken switches.
Aug 19, 2009 | Milwaukee Tool Milwaukee 2601 22 18V Li...
Power sliding door opens part way
Replace the wire track harness in the lower door opening.
May 29, 2009 | 2005 Dodge Caravan
Can't put rear light assembly back on
There is a clip on the outboard forward corner of the light assembly that looks like a spear point. Look at the new assembly and check for the spear point. Now look at the hole in the body that the spear point is supposed to fit into. There may be a broken off spear point still lodged in the hole from the previous broken assembly. You will have to push/pull this old spear point out of the hole so the new spear point clip will fit properly. Also, note that as you line up the new assembly, you will have to push it forward into place---the spear point will snap into the hole in the body and the assembly will be flush fit.
May 04, 2009 | 2007 Honda Odyssey
The LCD only works in a certain position
Flat cable connecting LCD unit to main board broken. Whole "shaft unit" have to be replaced ( LCD hinge with flex cable). Panasonic part #
LSEP8449A1
Nov 14, 2008 | Panasonic SDR-H40 HDD Camcorder
2001 Chrysler Town & Country Sliding Door Harness
you need to remove the old harness and open it up then repair the broken wires this will save the old harness and what the other people are talking about
Nov 12, 2008 | 2006 Chrysler Town & Country
Thetford Porta Potti  Logo
Top Thetford Camping, Backpacking & Hiking Experts
Fredrik Str?hle
Fredrik Str?hle
Level 1 Expert
Tony
Tom Chichester
Are you a Thetford Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
