Question about Miele Dishwashers
Miele dishwasher G7856 professional, fault code F3E followed by F26. I know F26 is water collection at the base of unit due to a leak. F3E??? We are currently at sea with no alternative than to fix it ourselves. Thanks for your help. Regards Martin Dufton
2 Suggested Answers
  • 70 Answers
SOURCE: Miele G7856, what is error F26? Thanks
The flood protection has activated, tip appliance to remove water, remove base and locate source of water.
Posted on May 24, 2011
I have a Miele g7856 and I just replaced the drain hose now I get a F2E code ?
The F 2E code indicates insufficient water coming into the dishwasher. Thus you should check that the shut-off valves for the incoming water lines are open. Make sure that the incoming water pressure hasn't decreased and that the water lines aren't kinked or blocked. You should also check the water inlet filters (at the screw connection of the hose) and the flow restrictor insert in the waterproof system.
Since the dishwasher was working before the drain hose was replaced, closed shut-off valves and kinked hoses are particularly likely. You may also want to replace the inlet hoses themselves. (Some anti-burst hoses will restrict the water flow if they detect a leak.)
I hope this helps.
Oct 19, 2016 | Miele Dishwashers
F3E error
Check the circulation pump.
Jun 22, 2013 | Miele 24 in. G638 Plus Free-standing...
We have a hoptpoint ultima super silent fdw80 dishwasher, displaying the code AL01, we have already tried the the 2 solutions listed & the fault still shows, any ideas?
You have a leak around the pump area and need to locate and repair this to use this unit. This fault code is to protect you home. This mean your unit is leaking during use and water is collecting in the base pan. You may need to run the unit were you can see the leak to repair. If possible you may also check you drain hose, it that leak it can also drain back into the base pan.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 28, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Drain pump goes ON when ON-OFF button is pressed, even if the know selector is in OFF position and the machine is dry. There is no fault codes and the dishwasher complete the washing cycle OK, but when...
Seems that the drain pump circuit in the main program controller unit power and keeps on as there is no logic feedback to cut off the power. It can be that the drain is clogged and so the water level detect keeps sensing due to a fault. check the sensors , check the drain filters , check the machine LEVEL so that the water drains clearly to the drain pump.
Aug 08, 2011 | Miele G7856 24 in Dishwasher
May 19, 2011 | Miele G7856 24 in Dishwasher
There is no water going into the dishwasher even though the water supply is on.
This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
Jan 24, 2010 | Miele 24 in. G665 Built-in Dishwasher
G7856 showing Fault Code F26. Have cleared filters of all debris, including drain impellar (sp?) cover. Code still not clearing. What do I do next?
Hello there again
I dont know if you got disconnected or just left the chat room but please try this
take out the bottom white basket so you can see the bottom inner of the dishwasher, then take out the centre filter and remove the silver L shaped plate so you can see down into the lower
tbirdfan1 says:
white inners......(may have water in it) on the left you can see a small white double dome with a silver clip going over it.....release the clip and pull off the dome inside you will find a pump wheel check this
tbirdfan1 says:
spins freely by flicking it round with your finger.
tbirdfan1 says:
.if you cant see it due to water then either feel for it or remove the water.........if it does'nt spin...free it...if it does spin easily then put it all back
tbirdfan1 says:
together and do this...... turn the control dial so it points upwards to the Hazard warning shape.........then turn on the power......wait a minute and then turn the control to the water drain
tbirdfan1 says:
symbol (arrow pointing to water) then hit the green start button...all being well you should hear the pump you've just checked spinning and pumping the water out
tbirdfan1 says:
the machine reset button is hidden under the 2 plates at the lower front of the machine but the screws are tricky to get to. try the pump and control part first.
tbirdfan1 says:
im still here hjust to let you know
tbirdfan1 says:
and one other thing that could be causing this is the float switch may have been inavertantly activated
tbirdfan1 says:
this would throw the code that you re getting
Jan 01, 2010 | Miele 24 in. G638 Plus Free-standing...
F70 fault error keeps appearing on my Miele G1220SC full dishwasher - any idea?
it is the float switch in the base of the unit, which registers a water leak. you are probably using too much detergent and it is overflowing into the base.
Oct 31, 2009 | Zanussi 24 in. DE6850 Free-standing...
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
MIELE G7859 DISHWASHER FAULT CODE F26
Hi .....F26 means the flood switch within the base has been activated ..........ya need to rmove base and raise of the floor and test on cycle looking for a water leak.
Apr 23, 2008 | Dishwashers
Dishwashers Logo
1,229 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
