Question about Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR
Just had a 18-135mm Nikon DX G lens Was fine until suddenly its auto focus was not sharp and keeps hunting with a whinning noise at low-moderate light and at longer focal lengths 130-135mm. Motor in lens cranks back and forth, unable to focus and if it does,its out of focused. Camera is ok,what shall I do to get it back to normal operation.Works fine on Manual focus. wooitimothy@gmail.com Malaysia
  • Nikon Master
  • 5,412 Answers
At longer focal lengths, when the aperture is smaller, and in low light, many A/F zoom lenses struggle. Is it OK outdoors in daylight ? If so, lens is OK.
Posted on Jul 31, 2017
  • 37 Answers
SOURCE: Nikon TC-17E II with Nikon 70-200mm f/2.8
You may have a dirty contact on the tc cpu pins. Try cleaning the pins with a clean pencil eraser or some methanol. You could also have a loose connection between the tc and the lens or body. Try applying a rotational force in both directions...see if you notice any change in behavior. If you have a local shop, see if you can try another copy on your lens.
The 17e may have slow-ish performance in low light, but it should still be usable. If neither of these issues is apparent then it may need to be exchanged or serviced.
Posted on Jan 25, 2008
SAGHA
  • 28 Answers
SOURCE: I have a Nikon 18-70 DX kit lens as well and it
HI I AM SAGHA FROM MUMBAI I AM A REPAIRER AND I THINK UR PROBLEM IS NOT SOLVABLE BY YOURSELF YOU HAVE TO TAKE THE LENS TO EXPERT THERE YOU HAVE TO GET THE AF SENSOR CHANGED.THIS WILL SOLVE YOUR PROBLEM DON'T TRY ANY MORE ADJUSTMENTS WITH CAMERA IT MAY CONFUSE YOU MORE.
Posted on May 17, 2009
  • 3 Answers
SOURCE: Nikon DX 55-200mm lens
Hi, I had this problem and found that the level inside the camera for the exposure shutter was bent inwards. This was preventing the lens from adjusting the exposure and also from autofocusing. To fix I just bent it back outwards
Posted on May 29, 2009
lifebyguitar
  • 57 Answers
SOURCE: Lens will not auto focus any more.
Hi there!
I experienced the exact same problem with my 100-300mm lens and I was never able to get it to work correctly again. In fact, attempting to use it further seemed to exacerbate the problem.
The further you zoom, the wider the aperture opens allowing more light for the camera to focus properly. If the aperture mechanism is damaged, the auto-focus process may not work as it should; which would explain why the auto-focus feature works only when at 18mm.
Regardless, I strongly recommend you discontinue use of the lens until a professional technician can examine the lens and figure out what's going on. I'm sure you can contact the manufacturer to open a support case or you can find a camera store that offers repair services.
I hope this helps!
Posted on Aug 30, 2009
Testimonial: "Thanks, I'll check with Nikon. I appreciate the help! Don "
SOURCE: squeaking when try to focus. will not focus
I had the exact same problem, took it to a repair shop, and they said the motor had to be replaced completely for $140! The lens is only 18 months old and was not used THAT much! Argh.
Posted on Sep 09, 2009
Nikon DX AF-SNIKKOR 18-55MM 1:3.5-5.6G11 ED auto focus don't work
If you're looking at the camera without a lens on it, there should be a little flat protrusion in the lower left. Make sure that it is protruding and not obstructed.
Dec 19, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
I have never been able to auto focus with my Nikon DX 18-70mm
Sure there's a cure! Auto focus on the 18-70 and a D70 has a few switches and menu settings that help to set it up. The switches are on the lens (I'm going to guess this is the one you're missing) and the side of the camera body. If you only have problems with this lens and other lenses auto focus fine, this is really the only thing that could make it not focus. The switch has two settings, M/A and M. It must be in M/A in order to auto focus. Older auto focus lenses don't have this switch.
The other switches and settings would result in auto focus not working with any lens you put on.
If you have problems with other lenses, or if the 18-70 is your only lens, drop a note here and I'll go into more detail on the other settings.
Jul 29, 2009 | Nikon D70s Digital Camera
Low light no focus
The Nikon D100 custom settings option 22 - AF Assist, controls the AF Assist light.
Check if this has been turned off.
This option controls whether the auto-focus assist light comes on in low light to help autofocus
latch onto the subject.
Jul 15, 2009 | Nikon D100 Digital Camera
I have a Nikon 18-70 DX kit lens as well and it cannot focus either. It will quickly hunts from infinity to close range while making screaching sound. I found that if I point the focus point at a lamp,...
May 13, 2009 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Manual Focus won't work
Which camera are you using? If the body has AF/MF switch, put that also to MF.If this fails to help, take out the lens and try to change it to MF.
Feb 05, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Nikon D80 Autofocus problem
sir, replace ur lens image reading sensor
Apr 06, 2008 | Nikon D50 Digital Camera
Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR Logo
61 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
