Question about AEG L74800 Front Load Washer
Error E50 how can i reset aeg 74800 lavamat. - AEG L74800 Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error E50 indicates motor fault, you’ll have to check the brushes and wiring of the motor and check if it makes a hum sound, if it does and you can see that the motor is not working then it is the motor that should be replaced. If everything else appears to be working fine then it is the PCB that should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 04, 2010
AEG Lavamat 60810 keeps stopping and displaying error E50 and some time E70. What is the problem and how do I fix it?
Family error code E50 means a problem with the washing motor. Family error code E70 means a problem with the NTC sensor. In my experience, E50 is most common fault in worn carbon brushes. But in any case family error code E50 is shown to the customer. In service mode could be: E51,52,53 and 54. The same applies to family E70 error code that will be displayed in service mode as error code E71 or E74.
E50 error code could be: motor winding, power board, tachymetric generator, motor relay on power board, wiring between motor and power board and wiring between tachymetric generator and electronic.
E70 error code could be: faulty NTC sensor, wrong position of NTC sensor or to much limescale on it and finaly wiring between NTC and electronic.
Dado
May 05, 2015 | AEG Washing Machines
E60 Error Code on converted 60Hz outlet
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
Unplug your washer for 1 hour and then plug it back.See if this reset helps.
Aug 06, 2008 | AEG L74800 Front Load Washer
AEG Lavamat 60810 E50 7Beeps Does seem to still work but display shows E50 and some time E70 and 7beeps over and over. Many thanks
E50 does mean problem with motor or tachometer placed on the motor. Could be: worn carbon brushes, motor faulty, wiring, electronic faulty.
E70 does mean problem with heating phase.
Could be: NTC sensor faulty or badly positioned, wiring faulty, electronic faulty.
Dado
AEG Lavamat 62800 keeps stopping and displaying error E50. What is the problem and how do I fix it?
Aug 07, 2011 | Washing Machines
What means error code "C9" ? AEG Lavamat 76669
C9 Indicates Motor Fault. It seems that the Carbon Brushes have Worn out.
Replace it and more likely it would Fix the Problem.Once you replace that, you need to put the machine into Service Mode to Reset the Error.
Steps for Reset the Error Code
1. Press and Hold the Prewash and Soaking Buttons Together.
2. Whilst Holding them, Turn the Dial from Off one Click Anti Clockwise
Note - If problem persists, Check the motor plug for broken wires and check the state of the carbon brushes.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 28, 2010 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 74800 stops part way through the cycle - Error E50
I suggest trying this link. They will help you online.
https://www.justanswer.com/uk-appliance/23fl9-aeg-lavamat-74800-error-50-reported.html
Oct 28, 2017 | AEG Lavamat 72640 Front Load Washer
AEG 74800
We had something like this a whlie back - I'm pretty sure it indicated a water supply problem (we had low water pressure)
Dec 21, 2008 | AEG L74800 Front Load Washer
Error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
Jul 07, 2008 | Zanussi ZWF1440 Front Load Washer
AEG L74800 Front Load Washer Logo
1,192 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
