Question about Canon Office Equipment & Supplies
What is meant by 'system error e197' in canon IR2016 MFP?
L'erreur de transfert de donnees entre carte d'alimentation et la carte de commande ou bien le moteur de la partie lazer ne marche pas
Posted on Jan 10, 2011
A system error E197 has displayed on my canon iR1018 copier. how will i solve the error problem?
the error is E197-000 Printer engine communication error
Erroneous communication between the DC controller PCB and image processor PCB was detected.
- Check the connectors of the DC controller PCB and image
processor PCB.
- Replace the DC controller PCB for normal connection.
- Replace the image processor PCB.
The part number for the DC controller PCB is FM2-8365-000.
Best regards,
Marius
Jul 29, 2016 | Canon CART303 Laser Toner - Genuine, Suits...
Canon ir7086 error code E197
Try this link this should give you some answers and resolutions
Canon iR1024 Error Codes
Apr 24, 2012 | Office Equipment & Supplies
How can I Fix System Error E197 for Canon ir2016?
it relates to communication between the boards.remove the rear cover and then remove all the connection of the boards and then reinsert them.then on the machine and go to service mode by pressing * 28 * and then to CLEAR option and clear the ERR. if this not work then u have to change the board.
Sep 08, 2011 | Canon CLC 1140 Copier
Error: System Error E197.Please help us to solve the err.
what machine do you have
E197 Printer engine communication error
PCB and image processor PCB.
connection.
Sep 03, 2009 | Canon Office Equipment & Supplies
System error E808
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540 0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542 0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744 0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
Mar 22, 2009 | Canon CLC 1140 Copier
Printer System Error E197
I have a Canon MF6500 Series and received this System Error E197 error while printing a document from Word. I was low on paper in the tray but not out so I refilled the paper tray and turned the printer off for about 30 seconds and it worked fine after that. I guess I'm lucky.
Aug 11, 2008 | Canon imageCLASS MF8170C All-In-One Laser...
Canon MF6500 Error Code E197
Error
E197 0000 is a Printer engine communication error.
A erroneous comm's error occured between the DC controller PCB and
Prnter needs servicing
Check cabling connections on theDC controller PCB and image
processor PCB.
If still same then you have to replace DC controller pcb.
If still fials then you have to replace the image processor pcb.
Aug 05, 2008 | Canon imageCLASS MF8170C All-In-One Laser...
Canon MF8180c
Issue: ERROR LCD: System Error E197
Solution: Verify/reconnect power cord to fixing assembly
The power cord has been disconnected from the fixing assembly. power_cord_fixing_assembly.gif
Verify/reconnect the power cord to the fixing assembly.
May 28, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Mf8180c error code e 197
I believe a E197 error refers to a power problem relating to the fuser. I would remove any covers to access the fuser, remove it and reseat it and any nearby connectors.
Feb 25, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
509 people viewed this question
old marine
old marine
