Question about Linksys Wireless-G WRT54G Router
WRT54G Router I tried setting it up using the bellsouth disc still wont go out
    Scholar:
  • 72 Answers
Have you tried doing this while connected with an ethernet cable or just over the wireless?
Posted on May 13, 2008
I am trying to connect to the internet using the linksys WRT54G and a motorola modem from AT&T. The computer recognized and connected to the Linksys (set up was very easy), but the internet will not...
The steps will very some depending on the model of the modem and router but these steps should help.
How do I proprly set up a Linksys router for FastAccess DSL? Important Note: Due to some operational issues it is VERY important that you have the latest firmware on your Linksys router. Please go to the Linksys Download Website and ensure you have the newest firmware.
Configuration of a Linksys router depends on the type of broadband service and other equipment connected. This is a generalized Linksys Router FAQ and some firmware, capabilities, and actual screen shots may vary. This initial setup is all that is needed to configure and connect your Linksys based network for FastAccess. Any additional setup for features like WEP, DHCP IP ranges, port triggering, etc is out of the scope of this FAQ. Other FAQs may be more appropriate and provide more specific information:
•If you are using a BellSouth supplied Westell 2100/2200/6100 modem please reference the FAQ here.
•If you are using a BellSouth supplied Motorola/Netopia 2210 modem please reference the FAQ here.
•If you here IFITL (PCData) service please reference the FAQ here.
•Both the modem and router must be reset to default.
•The BellSouth Installation CD and Connection Manager are not required to use this configuration.
•Since BellSouth assigns static IPs via your username the configurations shown are applicable to both dynamic and single static IP customers.
• You will be using the PPPoE client built into the Linksys router for connectivity/authentication. Please delete any other unused PPP clients like Enternet300, RASPPP, or the native XP client.
Section 1 - Linksys Router Configuration
bred.gifStep 1
Verify that your NIC card is set to "Obtain IP Address Automatically". Power down the router and any PCs. Connect one of the router's LAN ports to the computer NIC and power up the router and then the computer. Reset the router to default by pressing the reset button for roughly 25 seconds (exact placement of the button differs per model).
bred.gifStep 2
Important note: The following screen shots are based on a Linksys BEFSR41v.2 router and your screen shots may be different, however the process and configurations are the same. Open a browser session and enter 192.168.1.1 in the address field to access the Linksys Interface. At the Username and Password prompt enter admin (without quotes) in the Password Field.
bred.gifStep 3
On the Linksys Setup page select PPPoE from the WAN Connection Type pull down. Enter your BellSouth Username followed by "@bellsouth.net". Enter your BellSouth Password. Select Keep Alive and enter 180 seconds Redial Period field. Do not enter anything in the Host Name or Domain Name fields. If your model has the ability to adjust MTU size (not shown below) select Enable or Manual and enter 1492 in the Size field. Click on Apply to save the changes. You may get a "Settings are successful" message, click on Continue (if required).
Section 2 - Physical Connections and Power Up
bred.gifStep 4
Power everything down and physically connect the modem, the router, and any computer(s).
Westell 2100 shown. Pictures by Andy Houtz
bred.gifStep 5
Power up the network equipment in this order:
Westell or Motorola Modem (wait for DSL synch)
•Linksys Router
•Computer(s)
•Open a browser session and enter "192.168.1.1" in the address field to access the Linksys Interface. Click on the Status tab from the menu then click on the Connect button to connect to the Internet.
•Go surfing!
bred.gifImportant Additional Information
•The Westell 6100 and Motorola 2210 modems have an "Internet" light that is green whenever there is an active PPPoE session initiated by the Westell. Since you are using the Linksys to establish the PPPoE session the light will stay off. This is normal.
Do not change the Linksys Operating Mode from Gateway Mode (default setting) to Router Mode, or it will not function correctly.
•The Linksys "Auto" MTU capability does not function correctly on some models/firmware. You must manually enable the MTU and adjust the size to 1492 (or less). If you are experiencing slow/erratic speeds, constant disconnects, or receive a "Can not obtain IP address from the server" or "PPPoE negotiation fail" errors click here.
•You should check your tweak settings to optimize your new network. Reminder: If you change your MTU, make sure that it is set identically on all equipment (PCs and routers) in the network.
I hope this was helpful,
Shawn
Jan 29, 2011 | Linksys Wireless-G WRT54G Router
I lost the start up disc to the router. Is there anyway to get another one or have someone walk me through setting it up again without the disc?
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Dec 06, 2010 | Linksys Wireless-G WRT54G Router
How do I setup my wireless router to my westell bellsouth modem and ensure it works?
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Sep 14, 2010 | Linksys Wireless-G WRT54G Router
Linksys wrt54g, need console on pc but dont have disc
Are you trying to connect the Xbox to the wireless network?
If yes then you will need to check the wireless settings of the router.
is there any computer on line using the router ?
on that computer you can open the setup page of the router. check the wireless ettings and the security settings then try to connect to the wireless network on the Xbox.
See if that works.
Click here for more information
Jun 17, 2010 | Linksys Wireless-G WRT54G Router
Hi please help me my linksys wrt54g router is only giving me signal to the computer it is plugged into.
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Mar 19, 2010 | Linksys Wireless-G WRT54G Router
Error 322
When you try to set up the router using the set up Disc, sometimes you will get this error 322. This error says that there is hardwired connection between the router and the computer. Even if you connect the cable between the router and the computer , you will get this error message.
You can try to set up the router manually. It is easy.
Click Here for step by step solution
Nov 01, 2009 | Linksys Wireless-G WRT54G Router
My cd rom wont read the disc
Here is a link to Linksys's section (with downloads) on that particular router. http://www.linksysbycisco.com/US/en/support/WRT54G/ <br> If you are just trying to modify the settings of the router, you do not need software to do that other than a web browser. Start your internet browser of choice and type in the URL box 192.168.100.1 which should bring up your modem's settings.
Jul 15, 2009 | Linksys Wireless-G WRT54G Router
Set to work with centurytel instead of bell south
Howdy - You may have a two fold problem here. First of all the Westell wireless modem/router 327w has the access IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. That problem solved...
Now, from what I understand, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
This is the page link:
http://www.dslreports.com/faq/bellsouth/3.141_Westell_327W__wireless__Info#13772
This is the relevant quote:
"The BellSouth supplied 327W (model C90-327W30-06) is made exclusively for BellSouth FastAccess. They are functionally different from retail Westells (or any model designed for use with other ISPs) and the firmware between them are not compatible and can not be interchanged."
That being said, you still might attempt to use this 327W with centurytel but I do not know if it will work. I use the Bellsouth 327W and it is GREAT. Good luck.
P.S. - Please be advised that Westell does manufacture an identical 327W that does NOT have the Bellsouth/ATT firmware.installed. This is the "generic" version I suppose but I have no experience with this one. If you need more just ask. :)
May 29, 2009 | Westell Wirespeed VersaLink...
I need the driver disc for a Linksys BEFCMU10 version 4 and a disc for a Linksys WRT54G version 2.
you don't have to use a CD to setup these routers. you can set them up by accessing the router setup page.
for other questions on how to setup the BEFCMU10 modem and the WRT54G router, you can go to www.linksys.com/kb
Feb 25, 2009 | Linksys Befcmu10 Cable Modem W/usb & E-net...
I have a model WRT54G model that belonged to my niece and has been registered.She tried to download and set this up on my computer but could not get it to work.I am now onfast ascess dsl and I cannot get...
To reset your router, use the following steps (you will have to re-setup your router:
Press the reset button for 30 seconds.
The settings should now be returned to the factory default settings, meaning any changes you had made would be deleted.
Open up your Web browser and enter 192.168.1.1 in the address bar.
For the login, leave a blank ID and enter admin as the password.
The router has now been reset. Follow the steps in Securing Linksys WRT54G Wireless Router to secure your router
Apr 05, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
20 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
