Question about Hisense Televison & Video
My tv turns off at 9pm each night and I am unable to locate how to change this time could you direct me as to what buttons on the remote and menu I should use thanks chris It is a hisense lcd and the remote came with it
  • 901 Answers
Pl check your user guide. Go to the MENU using the remote and change the clock settings/ Dy settings.
Posted on Sep 04, 2010
Toshiba tv 40rv525u has started to change channels
My TV 40RV525U changing channels, menus itself for few months ( I use antenna).
my son tried to stop the channel scrolling by enter weird number into the channel to stop it scrolling such as 555, 777..
later, it turn on off by itself and unable to hold on a channel
I call Toshiba customer service and they ask money $25 for troubleshooting but I denied since I do not want to waste money and time.
Now, I found how to fix it myself.
In my case, something was wrong with the signal comes from the button control on the left side of the TV.
What I did
unplug the power cord.
Remove back cover.
Look into the motherboard ( biggest green at the center).
First, I disconnect a connector on the motherboard come from the IR board that receive the wireless signal control ( meaning the remote is disable).
I turn on the TV, press on Menu button on the TV side. Menu is still scrolling.
I turn off TV, disconnect power cord and connect the IR connector back to the motherboard.
I then disconnect the nearby connector that comes from the side control buttons.
Turn on the TV by remote, press menu button on the remote to check. The menu stays.
DONE.
I use electric tape to seal off the connector and let it hanging there.
Close the TV back panel
I have been watching TV for 3 nights without menus/channels scrolling.
NO AVAILABLE red message when watching DVD is no longer existed.
Hope this help someone else.
Jan 20, 2012 | Toshiba 40RV525U 40 in. LCD TV
My 6-month old tv is making intermittent 'buzzing" sounds. It was a Christmas gift and I don't have any paperwork on it but it did come from Costco. What should I do? Thanks so much.
Humming usually begins when the backlight setting is low. For some sets setting the backlight anywhere from 95 to 100 works. Most wok at 100. So turning it up should get rid of the problem. You can follow the 5 steps below to change the backlight setting.
1. Turn the TV on.
2. Press the Menu button on the remote, located right below the channel changing button.
3. Press the down direction button, located at the middle of the remote. Press that button until the backlight is highlighted.
4. Press the right direction button until the backlight is at 100.
5. Press the OK button and then the Exit button until you get back to your picture.
Jun 15, 2011 | Vizio 42 in. LCD TV
My Vizio TV tells me, when I press the menu button, that it's unable to launch com.yahoo.widgets.tv.container. It worked fine last night.
Funny, same thing happened to me about the same time! Took me a while to figure out how to fix it. You have to get to the HDTV Settings menu and hit the Help icon. Do a Clear Memory/(Factory Default) and go thru that process, basically you go through all the settings just as you did the first time you powered up the TV. This will fix your problem.
The challnge is...how to get to the HDTV Settings menu when your VIA button only brings up the error you described? I finally got there like this: Hit the "Input" button on the remote, navigate to "TV" and hit OK (basically just select TV as your input), hit the Menu button on the remote and that will bring up the HDTV Settings menu and then proceed as above
Mar 24, 2011 | Vizio SV472XVT 47 in. LCD HDTV
Hi! My Toshiba 40RV525u TV has a problem, it turns off or on by itself. I checked the auto power off settings, the time is not set (it is 00:00). This happens very randomly. Now I just plug out in the...
My TV 40RV525U changing channels, menus itself for few months.
later, it turn on off by itself and unable to hold on a channel ( I use antenna)
What I did
Remove back cover.
DONE.
Jan 14, 2011 | Toshiba 40RV525U 40 in. LCD TV
Toshiba 40rv525r screen says NOT AVAILABLE
I've had the same issue! This is caused by the control panel telling the TV what to do - does it change channels on its own, too, or turn off or on on its own?
What you need to do (if you've not already done it) is lock the control panel out, which you can do under the LOCK menu.
What may help is running the factory reset on page 54.
Mar 22, 2010 | Toshiba 40RV525U 40 in. LCD TV
My samsung tv is not responding to my remote control, actually even when I go and attempt to change the channel from pressing the up/down buttons on the tv it won't respons, some menu screen would come on...
your turning section is not responding to any input, hence needs to be checked by a technician. every thing you have mentioned are controlled by one ic, with its respective voltages.
Mar 21, 2009 | Samsung Remote Control
Pansat 2700A- V-hold
press "MENU" on remote, then press button directly below the "OK" button on remote 3 times to highlight "USER SETUP", then press the "OK" button on remote, then press the button directly under "OK" button 2 times on remote to highlight "TV TYPE" , then press left or right button directly beside "OK" button on remote to change it to "NTSC" .
Short version:
  • "MENU"
  • "USER SETUP"
  • "TV TYPE" , Change to "NTSC"
Dec 31, 2008 | Universal Remote Control 2700A DTV...
Samsung 40" Full HD LCD
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 22, 2008 | Samsung LN-S2651D 26 in. LCD Television
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Mar 08, 2008 | Televison & Video
Televison & Video Logo
76 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
