Question about HP Computers & Internet
My hp ppp012h-s pc laptop power supply fails to recharge my pavillion dv6 laptop battery pack. It ommits a frequent beeping sound once plugged in, but battery charge light does not turn on. Laptop does turn on. I have tried moving the power pack to different wall sockets and that does not resolve the problem. Please reply whenever free. Thank you
The Machine
  • 788 Answers
SOURCE: Dell Power Supply
You can test the power supply using a multimeter. I use a paper clip to get in the middle if my multimeter probe is too large. If there isn't any power but the light on the power brick is on (if there is one) then there is most likely a break in the cable. In any case turn to eBay for a replacement, should be quite easy and inexpensive to find. Or you could pay more and get one from Dell. Companies like APC and Targus make usniversal adapters but they're expensive and not optimal.
Posted on Jul 14, 2008
SOURCE: DELL XPS M140 POWER ISSUE
Hi brendanram!
I am claudus_07 and i was a Dell - XPS Technical Support Specialist before so i will be glad to assist you with your concern.
As you said into your post, you tried plugging the AC Adapter to the power source without plugging the other end into the XPS laptop and the Green Light on the adapter is lit. But when you plug the jack on the laptop, the Green light is out. As for my experience on your laptop, there could be a problem with the power supply or the motherboard of your XPS laptop. Because everytime you plug the adapter to the laptop, the green light is going out so it means that the laptop or the adapter is grounded.
Here's what you need you to:
Step 1: Call Dell XPS Technical Support 1-800-624-9896
Step 2: Tell them the issue and the things that youve done.
Step 3: At the end of the troubleshooting, i know that the Technician will either replace the Power Supply, Motherboard, or the Adapter. (if you have a friend that has a Adapter same as yours, you may try to use it just to isolate the issue the Technician will choose from the Power Supply or the motherboard)
Step 4: If the Technician replaces the power supply and the issue still persists, call technical support again and ask them to replace the motherboard, no need to repeat the troubleshooting steps anymore just tell them that youre already done with it. (Dont ask for a system exchange, because i know that they will not give what you want.)
Thanks!
I know it will work. Be Positive!
Your good rating will be very much appreciated.
Good luck and thank you!
- claudus_07™
romaragregado@gmail.com
www.romaragregado.tk
Posted on Jul 27, 2008
  • 15 Answers
SOURCE: Mac Ibook Power supply problem
On Mac iBooks the orange light comes on when it charges the battery. Once the battery is charged it turns green. Im guessing the other powersupply was aftermarket or broken. EIther way, if it starts out green - recognizes the battery isnt full - turns orange for a while - then turns green when the battery is full, then the computer and powersupply are working perfectly. Enjoy your iBook!
Posted on Mar 01, 2009
SOURCE: Packard bell R1004 does not charge
Hey there i have the same problem, found the power connector on ebay for £4, not sure if this will solve the problem but search for the model. good luck
Posted on Mar 30, 2009
SOURCE: not charging
I found out how to solve this problem...first power down your computer. Then take out the battery, remove the power supply, and then hold down the power button for 30 secs. Put the power supply in only (not the battery). Start your computer after everything is done loading up put the battery back in. Give it a min. and then you should be able to roll your cursor over the battery life indicator in the lower right corner of you computer and is should say charging. I have found that other people have had this problem and it has worked for myself and for them.
Posted on Apr 07, 2009
Hp pavillion dv6 on but dark screen
sounds like the black screen of death
a lot of dv hp laptop have this problem the gpu has to reflowed are your keys also blinking. if they are count the number of blinks it will point to problem
HP DV7 Laptop Graphics Fix Black Screen of Death
would not fix it his way
Jul 04, 2015 | HP Pavillion DV6-1355DX Notebook PC -...
Hp pavillion dv6 how to disable administrator and power up passwords
Hi, there is a small "watch battery" inside your pc that retains your Bios settings. !!Unplug your PC and hold down the power button for 10 seconds before opening your tower!!! Remove the side panel, locate the battery that's roughly the size of a quarter, remove it for 30 seconds or so, push the power button with it still unplugged and the battery removed. that should remove your troublesome password.
Replace your battery and side panel, plug it back in, and power up... I believe you can access your Bios options for an HP by pressing F11 prior to Windows boot.
Mar 24, 2013 | Computers & Internet
4 beeps on my Hp pavillion dv6000, blank screen
No Screen on Pavilion DV2000T
I had this problem before. Tere is a good chance this may work.
First of all remove the ram memory.
-remove battery pack and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DONT PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILL START. ONCE YOUR SYSTEM IS READY SHUT IT DOWN PUT THE RAM AND BATTERY PACK BACK AND CONTINUE TO USE YOUR LAPTOP.
It hope fully will work as if you get one or more beeps, the POST is completing alright.
Hope that helps.
Dec 10, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp pavillion dv6 laptop no power
1. Check the adapter
2. Check the processor
3. Check the motherboard if defective replace new one.
Note: You need to know the right spare part number of your motherboard e.i 443776-001. Here's a sample video
May 04, 2010 | HP Pavilion DV6500Z Notebook
My hp pavillion dv5t-1000 power cord not working
Test your voltage on your power supply...There should be a voltage amount on the sticker on your power supply telling the output.Make sure yours is putting out the right amount.If this test good,your probally looking at a bad dc jack.Jacks need to be checked by a certified repair person.....Goodluck......If this is helpful ...Be so kind as to give a testimonial.....Thank you
Apr 09, 2010 | HP Pavillion DV6227 Notebook
HP Pavillion DV6700 is shittung down
This could be numerous things. It could be an over heating problem, a virus, a power supply failing or something wrong in the power adapter on the motherboard where the power plug plugs into the laptop. If you plug in the laptop and see the battery charge light come on then the problem is most likely an overheating problem or a virus. If the battery charge light comes on then I would recommend taking it to a reputable repair facility to have them diagnose the problem.
Jan 01, 2010 | Computers & Internet
Computers & Internet Logo
176 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
