Question about Toshiba Satellite Pro 490CDT Notebook
No acces to hard drive , there is no cdrom. and no floppy drive , only one usb port, with no bootacces,how can i acces the hd?
3 Suggested Answers
  • 3940 Answers
SOURCE: Primary Hard Disk Drive Not Found, Fixed Optical drive Not found
Reseat both the Hard Drive and Optical drive and see if they detect. If they do not, then a HDD failure is most likely. The I8000 is quirky in that if the HDD fails, the Optical drive will not work.
If reseating doesn't resolve, Replace the HDD and the optical drive should work. (Controller is a serial design and neither drive will function if the other fails)
Posted on Jan 22, 2009
JaxPlanet
  • 921 Answers
SOURCE: usb does not recognise external hard drive
Your drive is being recognized. However, your computer only has USB 1.1 so you are being notified that USB 2.0 is faster. This message is FYI and will not prevent you from accessing the drive.
After you see that message you should see your external drive in "My Computer" If you don't see the drive you probably need to assign an available drive letter to drive.
Open Windows Help and Support.
Search for "drive letters" and find "assigning drive letters"
This will walk you through the process.
If this helps, please vote for my solution.
Posted on Oct 05, 2009
NewerTechnology uDriveSmartDisk USB Floppy Drive (model FDUSB-M, Color Kit Edition, formerly VST)
Verbatim continues to offer support on select SmartDisk products:
CrossFire USB & FireWire Desktop Hard DrivesSOHO NAS Desktop Hard DrivesFireLite USB & FireWire Portable Hard DrivesFireLite XPress Portable Hard DrivePhotoBankUSB External Floppy DriveSelect models of CameraMate Card Readers
For online support click here:
http://www.verbatim.com/contact-login.cfm
or call technical support at 646-537-3411, Monday-Friday, 8 a.m. to 9 p.m. Eastern Time.
Verbatim Acquires SmartDisk External Hard
Disk Drive Business
Verbatim Acquires SmartDisk External Hard Disk Drive
TOKYO, (July 5, 2007) - Verbatim® Corporation and its parent company Mitsubishi Kagaku Media (MKM), announced today the purchase of substantially all of the assets of SmartDisk® Corporation\'s external hard drive (HD) and digital imaging business.
The acquisition, which includes physical assets, patents, trademarks, technology, engineering and marketing expertise, was effective on June 30, 2007.
Feb 12, 2013 | SmartDisk USB Floppy Drive Titanium...
Compaq f700 laptop will not boot. Power lights come on but no boot. Get msg. "No OS found." Am able to boot system from Ubuntu CDROM and then access hard drive data using a usb enclosure for the SATA HD...
This is not a problem with the hard drive but rather with your OS installation. Please do a repair installation of the OS using the original US disks.
Good Luck!
Jesse
Jan 04, 2010 | Compaq Computers & Internet
Can't boot from USB (No CD Drive) for fresh install
Tricky one, ive you have a external usb cdrom drive , maybe, or if you can take hardrive out and set it up on another laptop install your xp and also place copy of all drivers required onto it, then put back into the toshiba., dont know what else could help you here. hope this helps in some way.
Dec 05, 2009 | Toshiba Portege 7100 Notebook
Portege 3505
pls get ur cdrom service & try again but prior to that pls check ur data cable which is connected to ur pc
Jan 12, 2009 | Toshiba Portege 3505 Tablet PC
Dell Latitude D600 with new Hitachi 30GB Drive Not Recognizing
XP install is not detecting any hard disk.
No jumpers are required for laptops, can only have one hard drive in a laptop.
Check the BIOS for the hard disk configuration, make sure that it is set on Auto (detect).
You may have a faulty hard disk, you can check it by booting up with a floppy DOS boot disk, run fdisk to see if it detects the hard disk, OR connect this hard drive to a USB hard disk adapter and connect it to a working computer's USB port and if it detects it as an external drive the it is OK.
Nov 30, 2008 | Dell Latitude D600 Notebook
HP DW022A
Hi ,
Try to cutdown power usage. unplug the floppy power and cdrom power and try again.
If it works , then it is power issue.
Use external devices that have their own power (not drawn from usb).
Also try to change the usb cable and retry.
Also try other usb ports (surely you have more than one).
If other ports work (use a usb hub).
Good luck with your issue,
David
Jun 05, 2008 | Computers & Internet
IE DATA 702 fdd
Hello
I beleave it uses a HD/DD type of disk
Abbr.
Floppy Disk Type
Capacity
Info
SS/SD or 1S/1D
Single Sided, Single Density
100 K
First generation. Capacity varies
SS/DD or 1S/2D
5-1/4 inch Single Sided, Double Density
180 K
DD/DD or 2D/2D
5-1/4 inch Double Sided, Double Density
360 K
Most common type in the early 1980's
DD/HD or 2D/HD
5-1/4 inch Double Sided, High Density
1.2 Mb
DD
3.5 inch Micro Floppy, Double Density
720 K
Hard plastic case
HD
3.5 inch Micro Floppy, High Density
1.44 Mb or
2.88 Mb
Hard plastic case
May 05, 2008 | Ye Data YD-702D (850416000107) Internal...
Motherboard fails to see Hard Drive...please help
Sounds like you lost an ide channel, swap the ide cables around, primary to secondary and secondary to primary. and see if it recognizes the hard drives and not the cdrom.
I lost an IDE channel and had to install a sata hard drive or run the hard drive and cdrom on the same ribbon. If you run HD and CDROM on same ribbon set both to CS (cable select)
Mar 23, 2008 | Dell Dimension 4600 PC Desktop
Drive cable connection
Its easy to connect. Try the followings:
1) See the IDE0 port on your mother board and make connection for your hardisk to this port.
2) See the IDE1 port on your mother board and make connection for your CD-ROM to this port.
3) The IDE for floppy is much smaller than IDE0 and IDE1 so you can easily figure out that port and connect your Floppy Drive to that port.
Note: If you are newbiz then keep attention when connecting the cable to the device. Please push gently and firmly. If it got set easily then you are on right way, otherwise try in other direction.
Thanks
Iqbal
Mar 09, 2008 | Compaq Presario 5000 PC Desktop
Hd install
Enter BIOS, at start up press Delete key every couple of seconds. PC vary, some require pressing the F1 key or F2 and others reqire F10. Once in the BIOS you'll need change your boot order. Again PC's BIOS's vary. Usually Floppy is first, CDROM second and Hd 3'rd. Save Bios and restart. If you boot media is a floppy disk your PC will go there 1'st, than to the CDROM. If boot media still is not seen. Check connectors to the floppy and or CD make sure cables and power connectors are tight.
Dec 16, 2007 | Computers & Internet
Toshiba Satellite Pro 490CDT Notebook Logo
21 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
