Question about KitchenAid Dishwashers
Dishwasher door locked kitchenaid 1998 model opens from front
aborcass
  • 2651 Answers
SOURCE: door handle will not engage with latch to open door.
yea but the trick is the latch acces is behind console not the front panel, you need to unistall the d/w slightly to remove strike plate holding broken latch closed, door needs to be opened to gain access to console screws
Posted on Feb 22, 2008
SOURCE: KitchenAid Dishwasher KUDSO2FRSS
I recently had the same problem. One of the cords that attaches the door to a spring had snapped. I purchased cord replacments at the following URL and completed the repair myself. http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1059756&PPStack=1
Good Luck, Tim K.
Posted on Jul 07, 2008
SOURCE: central locking problem
i had a similar problem on the front doors .after taking it to a garage for a quote £ 180 i read into it and there are micro swithches in the locks so with a gentle tap with the hand the door unlocks . hope this helps it saved me the money
Posted on Aug 29, 2008
  • 7 Answers
SOURCE: KitchenAid Dishwasher Door Pops open during cycle
I have had the same problem since our KitchenAid was new. The only solution so far is to try bending the metal door latch down slightly. You will know when you have bent it too far as the door will no longer close. Just bend it back up slightly. I used to work in the appliance industry and got the service man to admit that the door latch has been an issue and there is no real fix. I have looked at the new KA dishwashers and they have since redesigned the door latch. I am going to see if the new latch can be retrofitted into my Kuds01FLSS6 dishwasher. I will post on here if indeed it works.
Good luck
Tom
Posted on Jan 14, 2009
SOURCE: Where can I buy the cable repair kit for my Kitchenaid dishwasher
OK, pretty easy fix. Look at diagram 10 here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164885
The link (#24) probably broke and the spring (#18) probably shot off and is lying somewhere behind the dishwasher. Just pull out the dishwasher (careful not to disconnect or crimp any of the hoses) and check to see if both springs (one on each side) can be located. Just replace the old links and re-hook the springs and all should be well.
You can order the link replacement (part #8194001) from kitchenaid at 1-800-422-1230.
Posted on Feb 20, 2009
My kitchenaid DW kudc101xwho will not stay on. Runs a few min and shuts off. Is this the control panel or the timer?
May be this is the reasons.
a) May be your door latch is opening due to pressure inside the dishwasher. The door latch opens and the dishwasher will stop. Quite common problem on KITCHENAID. KitchenAid door is a heavier door compared to sister product WHIRLPOOL. If door latch problem then has to change the door lock along with the top latch.
Sep 25, 2014 | KitchenAid Dishwashers
Should the KitchenAid dishwasher #kudio1flbl6 door open automatically?
If it does, it's the first time I've ever heard of a D/W with this feature. But read your manual to be positive.
Aug 02, 2014 | KitchenAid Dishwashers
The latch on my kitchenaid dishwasher is loose or broken and I can't open the door. Any ideas. Model #KUDS24SE
yes remove the top of machine and make sure the power is switcht off.;;;;;on the front of machine with your hand pushed down to the door switch ,not easy but keep trying,you will find the door switch with both hands wrigle until the door opens i know its hard and your hand will suffer but it will open keep trying,this switch needs replaced at all costs,you might have to replace the switch plus the holder .Once door is open unscrew the two screws and the whole latch will be in your hands remove the plug and you will have it in your hand ,replace backwards to what ive said,good luck psthis part/sshould cost 20 dollers.
Dec 04, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
Door will not open on my KitchenAid Superba dishwasher
Hi Karissa (I LOVE your name!)
I took the opportunity of your post to upload a technical service manual for you. The "child lock" feature is only for the control functions (the buttons) and has nothing to do with the door actually locking. Here is the link to the tech manual. I hope you find it useful.
SG
Apr 16, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Apr 14, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Kitchenaid dishwasher door does not stay up in the open position.
On each side of the dishwasher, near the ground, is a nylon cord and pulley apparatus that keeps the door from flopping down when opened. It probably needs some adjustment of the tension on the cord.
Feb 01, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
KitchenAid model KUDS25SH (Stainless) latch has come loose.
Remove the six or seven screws that secure the entire control panel to the door (screws are located inside of door around the top. Pull out the control panel and the door latch mechanism will be right there for you to work on.
Jan 31, 2009 | KitchenAid KUDC25CH Dishwasher
Dishwashers Logo
50 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
