Question about Toshiba Satellite M100 Notebook
Toshiba laptop won't wake up from stand by or hibernate
My Toshiba Satellite M100 laptop won't wake up from stand-by or hibernate. When I press the button to wake it up the LEDs light up and the fans turn on but the screen stays black. Eventually I have to shut it down using the power button and restart it. When it starts up again it tells me that Windows has recovered from a serious error. I am running XP.
  • 1 more comment
  • slm92_6 Sep 10, 2008
    When i pressed the power button on my Toshiba notebook...it went into hibernation mode and now that i press the power button all it does is light up and the screen is blank...I tried removing the battery and then placing it back in...but that doesn't seem to be working
  • Anonymous Mar 30, 2014
    laptop does not wake from sleep or hibernate
    how to wake the laptop from sleep or hibernate
  • 5 Answers
I had the same problem on my Toshiba Satellite U305, struggling with it for the past 4 months and having to use Shutdown each time I was done using it. Very frustrating! Toshiba worked with me several weeks, telling me to re-install Vista and all the fixes, which took a lot of work backing up etc and this did not fix the problem. Today they finaly told me to try entering this special command and it fixed my problem. Maybe it will fix yours too.
Create a shortcut on the desktop and to make the shortcut, right click on the desktop, choose Create Shortcut, enter CMD.EXE where it asks you to "Enter the location of the item". This will create an icon on the desktop that looks like a mini-command prompt. Then on the desktop, RIGHT click on the CMD.EXE shortcut/icon you have created and select "Run as administrator". This will open a command prompt window. Here in the black-box with white letter window, enter the command "powercfg -h on" (without the quotes). Reboot and see if the problem is resolved. This fixed my Toshiba Satellite that had this problem.
Posted on Jul 19, 2008
  • 37 Answers
Actually your laptop do wake up. But the problem here is that the back light of your screen won't light up after it is wake up or resumed from hibernation. To confirm this try directing a torch light when this occurs. If the screen is on without the back light, you could see the contents displayed(most probably your logon screen).
To correct this, try reinstalling your display drivers, hotkey drivers and power management utilities.
Posted on May 13, 2008
  • matthewspast May 04, 2011
    Oh my God! Thank you so much for posting this answer. I was having the same problem just a moment ago with my Toshiba Satellite also. I put it into hybernate with about 5 hours of my business's work I forgot to save. I was heading out and bringing the laptop with me. I realized that I should save just in case and when I tried to wake it nothing happened! Then I read this solution of using a light on the camera. As soon as I put my phone up to the camera it woke up right away. Thanks so much! I was having a panic attack over potentially losing my work.
I just fixed my laptop from that problem. I went to the system setup when you restart your computer, in my laptop i press esc and then F1, every computer is different though. In the setup page, there is an option for system restart and my setting was "boot". I changed it to "resume" and saved my changes and restart it my computer. Now, when I am working on the internet, word, etc. I close my laptop come back later, open it and it takes me back to what I was doing. Hopefully this helps you.
Posted on Feb 06, 2009
Well you see...seomtimes the computer doesnt resume from hibernation because hernation gets corrupted...or standby file gets corrupted... so the only way to resume it is by removing the battery...and putting it back on and restarting the computer...However do it only once..... and then try to set your hibernation in place.
Posted on May 14, 2008
Why does my computer say hibernate
you can change it from control panel, that when u press on power button what it will do, u can choose shut down or whatever u want.
control panel - hardware and sound - power options then u can see on left side that "choose what the power button do" then u can choose a **** down or whatever..
good luck
Feb 17, 2013 | Toshiba Satellite M100 Notebook
After my Toshiba laptop wakes up from hibernation, I get Error F3-F100-0010. Can any one help?
What is on the title bar of the error message?
What programs were you running before hibernating?
Were you browsing before you quickly hibernate your machine?
Elaborate.....
Oct 08, 2012 | Toshiba 17.3 Satellite P775-S7320 Laptop -...
Toshiba satellite laptop won't wake up from hibernation even after holding power botton down?!
If pressing down and holding the restart/start button doesn't wake it up you might try Control + ALT + DELETE keys (together) - that will reboot it though. And if that won't work then you might have to pull the battery to reset it.
It seems that some laptops have a problem with vista and sleep mode, in particular, and sometimes hibernate too. You can try going under POWER OPTIONS under Control Panel and setting everything back to default, saving it, then resetting it again. Also it's best to avoid using sleep mode if possible to avoid problems.
If the problem developed after a recent install or updating you may need to go to an older store point to fix the problem. Personally, I just avoid using these settings as much as possible and use regular shut down and a screen saver for times when I need to step away from laptop for short periods of time.
Apr 27, 2011 | Toshiba Satellite Pro L300 Notebook
Not wake from sleep or hibenate
Usually, to wake from sleep pr hibernate, you just need to press the "Power" button of your laptop. It will not turn it off or restart the laptop if it is in the "sleep" or hibernate mode. Pressing any key usually wake it up. The default way is to press the power button as if turning it ON for the first time.
Feb 11, 2010 | Toshiba Satellite Pro M300-S1002X Notebook
I have the same problem with Stand by on my IBM Thinkpad
Try going to performance and maintenance then power options.Make sure the power scheme is set to Portable/Laptop.Make sure all the drop down boxes are set to NEVER.Go to the hibernate tab and uncheck Hibernate.Be sure to push apply.Then reboot.That may stop your problem.
Aug 07, 2009 | Toshiba Satellite M100 Notebook
Computer was in hibernate or sleep mode when the battery drained. Now, will not boot, appears to come out of sleep mode but only shows TOSHIBA splash screen and the hard drive lights do not activate. F8...
Dear! take display properties use tab ans select screen saver then click on power and use tab again select hibernate if it is enable check again it and disable now. After that your computer will not go in sleep or hibernate mode.
Thank You
Jul 26, 2009 | Toshiba Satellite M100 Notebook
Not waking from stand by on windows xp sp3
dont keep doing it, at some point your laptop wont ever comeback to life. so just use shutdown and hibernation
Mar 25, 2009 | HP Compaq nx7300 Notebook
How to turn on toshiba satellite M300 laptop from hibernating mode
hi shirleygty, is that automatic hibernation (the computer hibernates by itself) or manual hibernation (by pressing the hibernate button)? If either applies to your case you might need to update the BIOS information for your computer to fix the power management issues on it. You can get it here. Just run the file, click install & choose Install From Windows. Make sure you don't have any BIOS password or any external devices connected to the computer. When the update completed successfully, your computer will automatically restart, then try hibernating this time (manual or automatic). I do recommend setting the hibernation to 1min. at the control panel > power options > change when to turn off the display. When it hibernates, pressing any keys or the power button should wake up the computer.
Hope this helps.
Oct 05, 2008 | Toshiba Satellite A205-S4617 Notebook
Cant wake up my sony laptop
Hold the power button down until the machine shuts off, then reboot. Several laptops have this issue (standby either works or it doesn't), and I've never been able to resolve the issue on the ones that don't work properly, in the future set the machine so that it never goes into standby.
Jun 28, 2008 | Toshiba Satellite M100 Notebook
Computers & Internet Logo
15,153 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
