Question about ASUS P5V800-MX Motherboard
Cmos Cheksum bad - Overclocking failed Cmos Cheksum bad - Overclocking failed Cmos Cheksum bad - Overclocking failed Does anyone know how to solve this problem?? please help me out.. =( =( =(
You can remove the cmos for about 2 mins and put it again if this doesn't work then have a new one.
Posted on Mar 03, 2011
When i start the through error overclocking failed! please enter setup to re configure your system how to solve this problem
If you dont know how to reset your bios settings back to default, maybe you should not be overclocking.
Enter your bios (check google for the key you need if you dont know it)
click default settings
Jul 25, 2010 | Computers & Internet
My motherboard ringing long
can you tell me after beeping and cheksum error did boot your system or is stoping there?
if is stoping there see on the end of monitor a message lke pres f1 to continue.
presit and see is booting your operating system or not?
if yes all to do is to change your cmos bios onboard batery with new one.
if no then you have problem with your bios , try to flashit with new release of your bios.
Apr 09, 2009 | Biostar U8668 (U8668DV7) Motherboard
System fail due to cpu overclocking, voice message on reboot, after turning the adaptive overclocking feature on in the bios. I cannot clear cmos and get back into bios to turn it off again. I have tried...
Disconnect the power cable, press and hold the power button. Open the case, remove the cmos battery and short the cmos battery connectors (just touch both the metal tabs center and edge at the same time) with a screwdriver. Replace cmos battery, reconnect the power and power on. This should reset the BIOS to default settings.
Apr 01, 2009 | ASUS A8V Deluxe Motherboard
Cmos cheksum bad
From your problem description, it sounds like a corrupt BIOS and or a failing motherboard.
Due to the system age, I'd say cut your losses, salvage what drives are usable, and get a new (or newer) system
Dec 07, 2008 | Computers & Internet
OVERCLOCKING FAIL/CPU FAN ERROR
First approach shold be the CMOS utility, check in FAILSAFE DEFAULTS that the error settings for shutdown are either null for overclocking or disabled if you don't have the failsafe defaults on your CMOS utility then set your settings to best performance (should be found on the main page of the CMOS utility). If you are unsure of touching the CMOs then you could try to remove the CMOS battery (small 3 volt battery about the size of a 20 cent coin) located on the motherboard this should reset the CMOS and fix the problem. hope i could help,thanks:)
Aug 11, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Motherboard with mistake in the initialization
after changing the battery the problem is suppose to stop but since it continues i think u have to set the date and then save the changes made after saving cos is not all about changing batteries most times too the new batteries u just bought may be bad as well. so set the date and time then save changes i think it shoukld work well.
thank u
May 29, 2008 | ASUS P4V8X-X Motherboard
Just bought new memory still overcloking failed
hi
set your bios jumper setting clear it.
load default bios setup take away the cmos cell for 15 minutes and then put it in case.
after 15 minutes your problem is solved
best og luck.
notify me this solution is right or rong
Mar 22, 2008 | ASUS P4S800D-X Motherboard
Overclocking failed
Hi, If you have overclocked: 1. CPU or motherboard not up to it - run at default speed; or 2. Memory - try using other memory; or 3. Video Card - see if you can run the Video card at default speed and not with overclock speed; or 4. You may need to up the CPU B+ a bit. If not overclocked: a. Set BIOS/CMOS to default settings; or b. Disable any overclocking feature (even if not used); or c. Lower you CAS latency. Hope this be of some help/idea. ood luck and kind regards.
Sep 01, 2007 | ASUS P5RD1-VM Motherboard
ASUS P5V800-MX Motherboard Logo
369 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
