Question about Zebra RW 420 Printer
RADIO NON-OPERATIONAL - Zebra RW 420 Printer
I'm trying to find the instruction and operational manual for a radio shack surveyor camera drone
Model Number and manufacturer helps find manuals on the internet.
Is it this one?
https://www.manualslib.com/manual/1221176/Radio-Shack-Zeraxa-6001352.html
Mar 05, 2018 | Radio Shack Radio Communications
Rear speakers dont work
The most common problem is the rear speaker Channel goes out in the radio I suggest buying a aftermarket radio And installing it or going to a junkyard to get a factory radio
Mar 11, 2014 | 2001 Ford Windstar
None of my electric windows work, they are all stuck open and will not go up
Are you sure the window lock switch is in the "operating" position.The drivers window problem is usually a broken wire or a worn out window motor but the other windows can be made non-operational if the window lock switch is in the wrong position...if it is set correctly it may be the Body control module (in the dash behind the radio).
Sep 21, 2012 | 1995 Ford Explorer
Since I purchased my 2009 dodge journey I have had an issue with my radio/cd player ... sporadically the volume goes out, if I turn it off, and on it comes right back on, but will only stay on for 20...
AUDIO Any diagnosis of the Audio system should begin with the use of the scan tool. For information on the use of the scan tool, refer to the appropriate Diagnostic Service information.
For complete circuit diagrams, refer to the appropriate wiring information.
AUDIO SYSTEM DIAGNOSIS
CONDITION
POSSIBLE CAUSES
CORRECTION
NO AUDIO AT ALL SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Amplifier fuse faulty, if equipped. 1. Check and replace fuses, if required. 2. Wiring to amplifier faulty, if equipped. 2. Verify radio on/off input to amplifier and verify battery and ground connections. Repair wiring as necessary. 3. Radio faulty. 3. Refer to appropriate Diagnostic Service Manual. 4. Amplifier faulty, if equipped. 4. Replace amplifier. NO AUDIO AT SOME SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Wiring faulty between amplifier and speaker. 1. Repair wiring as necessary. 2. Wiring faulty between radio and amplifier. 2. Refer to speaker diagnostics. Repair wiring as necessary. 3. Wiring faulty between radio and speaker. 3. Check wiring for open or short, repair wiring as necessary. 4. Speaker(s) faulty. 4. Refer to speaker diagnostics. 5. Amplifier faulty.
5. Replace amplifier. 6. Radio faulty. 6. Refer to appropriate Diagnostic Service Manual. POOR AUDIO AT ALL SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Power/ground wiring to amplifier open or shorted. 1. Repair wiring as necessary. 2. Power/ground wiring open or shorted. 2. Repair wiring as necessary. 3. Amplifier faulty. 3. Replace amplifier. 4. Radio faulty. 4. Refer to appropriate Diagnostic Service Manual. POOR AUDIO AT SOME SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Wiring faulty between amplifier and speaker. 1. Repair wiring as necessary. 2. Wiring faulty between radio and amplifier. 2. Refer to speaker diagnostics. Repair wiring as necessary. 3. Wiring faulty between radio and speaker. 3. Check wiring for open or short, repair wiring as necessary. 4. Speakers faulty. 4. Refer to speaker diagnostics. 5. Amplifier faulty. 5. Replace amplifier. 6. Radio faulty. 6. Refer to appropriate Diagnostic Service Manual. SOUND DISTORTION (VIBRATION FROM SPEAKER AREA, BUZZING - HUMMING) 1. Door trim panel loose or missing fasteners. 1. Inspect door trim panel and correct as necessary. Replace any missing fasteners. 2. Water shield loose or misaligned. 2. Inspect water shield and adjust as required. 3. Items placed in door trim panel map pockets vibrating or moving from side to side. 3. Remove items from door trim panel. Ensure that vibration is no longer present. NO RADIO DISPLAY - AUDIO AND CONTROLS ARE OPERATIONAL 1. Radio faulty. 1. Refer to appropriate Diagnostic Service Manual. NO RADIO DISPLAY - AUDIO AND CONTROLS ARE NOT OPERATIONAL 1. Fuse faulty. 1. Check radio fuse and Ignition-Off Draw (IOD) fuse in Junction Block (JB). Replace fuses, if required. 2. Radio connector faulty. 2. Check for loose or corroded radio connector. Repair, if required. POOR RADIO RECEPTION WITH KEY IN ACCESSORY OR IGNITION ON POSITION 1. Antenna faulty. 1. Replace the antenna. 2. Radio ground faulty. 2. Check for continuity between radio chassis and a known good ground. There should be continuity. Repair ground, if required. 3. Radio noise suppression faulty. 3. Repair or replace ground strap as necessary. 4. Radio faulty. 4. Refer to appropriate Diagnostic Service Manual. 5. Faulty rear window defogger. 5. Verify that the rear defogger grid is functioning properly, repair as necessary (Refer to 08 - Electrical/Heated Glass - Diagnosis and Testing). NO COMPACT DISC OR DVD OPERATION 1. Faulty CD/DVD. 1. Insert known good CD/DVD and test operation. 2. Foreign material on CD/DVD. 2. Clean CD/DVD and test operation. 3. Condensation on CD/DVD or optics. 3. Allow temperature of vehicle interior to stabilize and test operation. 4. Faulty CD/DVD player. 4. Refer to appropriate Diagnostic Service Manual.
Nov 01, 2017 | 2009 Dodge Journey
Hi there, could someone please help me with a code for my Peugeot expert vans' radio. The cd player does not work but the rest is fine, so I don't want to pay the dealer for the code when it;s only half...
Unfortunately this is a Clarion Radio and there are no codes widely available for these. There are codes available for a limited number of serials and yours is not one of them.
If you want to get this radio operational again then a dealer is your only option which is likely to be costly given the unit is only part working. Your money would be better spent on an aftermarket unit that you can take out and use again in another car or van when you sell this one.
Thanks for using FixYa.
Mar 19, 2011 | Clarion ARX6670Z Cassette Player
I was given an acer travelmate 4230 which used to have vista but now has xp pro. I installed acer bluetooth drivers and software, but a popup tells me that the hardware could not be found. where in the...
On the Acer site, the list does not show a bluetooth.
TravelMate 4230 Series Specifications Part Number: TravelMate4230 TravelMate 4230
Feature Description Model PN CPU RAM HDD Optical LCD LAN OS TM4230-6128 LX.TES06.008 C2DT5500 2*512 120 8X Supermulti. 15.4 802.11abg XPP PT TM4230-6240 LX.TES06.012 C2DT5500 2*1G 160 8X Supermulti. 15.4 802.11abg XPP FR TM4230-6254 LX.TES06.006 C2DT5500 2*512 120 8X Supermulti. 15.4 802.11abg XPP FR TM4230-6327 LX.TES06.036 C2DT5200 2*512 120 8X Supermulti. 15.4 802.11abg XPP ES TM4230-6433 LX.TES06.005 C2DT5500 2*512 120 8X Supermulti. 15.4 802.11abg XPP EN TM4230-6434 LX.TES06.011 C2DT5500 2*1G 160 8X Supermulti. 15.4 802.11abg XPP EN TM4230-6704 LX.TFF06.089 C2DT5200 2*512 120 8X Supermulti. 15.4 802.11abg XPP EN TM4230-6760 LX.TES06.007 C2DT5500 2*512 120 8X Supermulti. 15.4 802.11abg XPP ES TM4230-6822 LX.TES06.030 C2DT5200 2*512 120 8X Supermulti. 15.4 802.11abg XPP PT TM4230-6909 LX.TES06.034 C2DT5200 1*512 120 8X Supermulti. 15.4 802.11abg XPP PT Part Number See models above Processor / Speed Intel® Core™2 Duo processor with Intel® EM64T support:
T7200/T7400/T7600 with (4 MB L2 cache, 2/2.16/2.33 GHz, 667 MHz FSB) or
T5500/T5600 with (2 MB L2 cache, 1.66/1.83 GHz, 667 MHz FSB) Core Logic Chipset Intel® 945PM/GM Express System Bus Speed 667 FSB RAM / Max RAM 512 MB of DDR2 533/667 MHz memory, upgradeable to 4 GB using two soDIMM modules (dual-channel support) Video Subsystem Intel® Graphics Media Accelerator (GMA) 950 with up to 224 MB of shared system memory, supporting Microsoft® DirectX® 9.0, PCI Express® LCD Properties 15.4" WXGA TFT LCD, 1280 x 800 pixel resolution Hard Disk Drive 80GB or higher CD-ROM Drive 8X DVD-Super Multi double-layer drive Battery, Primary 44W 4000 mAh Li-ion battery pack (6-cell) with up to
2.5-hour battery life or
71W 4800 mAh Li-ion battery pack (8-cell) with up to
4.5-hour battery life
(varies by model) Sound Subsystem Intel® High Definition audio support
Two built-in Acer 3DSonic stereo speakers
Built-in microphone
Sound Blaster Pro™ and MS Sound compatible PCCard Support 1Type II PCCard slot Pointing Device Touchpad Peripheral Subsystem 4 USB 2.0 ports, 1 VGA port
Headphones/speaker/line-out jack, Microphone/Line-in jack
5-in-1 card reader (SD, MMC, MS, MS PRO, xD)
Acer OrbiCam™ integrated 1.3 megapixel CMOS
(selected models) Modem 56K ITU V.92 PPT approved, Wake-on-Ring ready Ethernet 10/100 Fast Ethernet, Wake-on-LAN ready
Intel® PRO/Wireless 3945ABG (dual-band tri-mode 802.11a/b/g) Dimensions / Weight 14.09" x 10.43" x 1.15/1.41"
6.09 lbs (with primary battery) AC Power 100-240V AC AutoSensing Adapter
Environment
    Shock
    Operational/Non-Operational
5 G max. pulse / 40 G max. pulse
    Vibration
    Non-Operational
5-27HZ, 0.16" p-p, 2g peak, 27-500HZ
    Temperature
+5ºC - +35ºC / -20ºC - +50ºC
    Humidity
10% - 90% / 10% - 90%
    Altitude
10,000 ft / 40,000 ft Operating System Windows XP Professional with Service Pack 2
Windows XP Home with Service Pack 2
(varies by model)
Apr 07, 2010 | Acer TravelMate 4230-6499 Notebook
Stovetop burners won't ignite. Piezoelectric non-operational
each ignitor is seperat, but it does not take much water to get them to not ignite
Nov 17, 2009 | Kitchen Ranges
1996 Jaguar XJ6 - fuse box locations
check your fuses and module that control those function on the vehicle
Jul 01, 2009 | 1994 Jaguar XJ6
Non working haogen wall heater
First, you'll need to check all connections going to the unit.  Often, a poor connection will blow bulbs and not allow enough current to pass for heating.  Also, check any switch external to the unit.  Use a good meter to check for resistance.  It should be nearly nil.  Be sure to do all checks with the breaker off!
Nov 14, 2008 | Fujitronic FH747RI Halogen Compact Heater
Zebra RW 420  Printer Logo
208 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
