Question about Panasonic Televison & Video
Hi, before I use to connect my dvd player to my Panasonic TC-42PD1FA tv through S-video input, but now for some reason the S-video option has disappeared in the input list.What do I do to fix that?Thanks
  • 70 Answers
The problem is you s video input is disable in in put list pls go to setup and enable the s-video input again
Posted on Sep 04, 2010
Panasonic TV, TC-P50S2.Yamaha DVD Player DV-C6280.Yamaha Receiver HTR-5450.DVD audio working fine thru receiver. Not sure where to place white/yellow cords to get video feed.
Hello. Usually when you mention white and yellow, there should be a red also, the red and white are right and left audio and the yellow is the video. The audio should be connected to the receiver, and if the receiver has video inputs and outputs, that should be connected to the same receiver input as well, but if the receiver doesn't have video capability, the yellow should be connected to the TV video input. I hope that helps.
Aug 01, 2016 | Panasonic Televison & Video
Where to hook up white/yellow input wires from receiver to panasonic TC-P50S2. HAVE audio no video feed on tv
Usually DVD players have either composite or component video out (unless you are using HDMI connections). That means you need three or five RCA plugs connected between the devices.
The usual pattern when using a receiver would be to connect the Red/White RCA cables between the receiver and the DVD player audio out. Then connect the Yellow (composite) or Red, Green, and Blue (Pb, Pr, Y component) video cables between the TV and the DVD player. Make sure the connections match at each end; with component video, it can be easy to mix them up. Not all receivers have composite or component video outputs available to the TV. The Composite video will go to the yellow connector at Video In 1 on the TV. The Component video would go to Component In 1 or 2.
Since you don't mention the model of the receiver or how that is connected to the TV, I can't be sure why you have no video. If you have an HDMI connection between the TV and the receiver, the receiver won't convert the signal from composite/component video to HDMI.
The alternative method of connecting everything would be to connect the DVD player to the TV (both the audio and video), then use the optical digital audio connection from the TV to the receiver or to a digital to analog audio converter and then to the receiver.
Please add a comment with the rest of your A/V equipment for a more solution.
I hope this helps.
No Sound on my Panasonic TC-L55E50
simple things to do:
Look first to see if have sound when a DVD etc connected to a rear audio/video input has sound, this rules some things out.
Look in menu to see if for some reason the speakers in the set got switched to OFF.
Dec 16, 2012 | Panasonic TC-L55E50 viera tcl55e50 ledlcd...
I'm connecting the following components. TV Panasonic tc-p42c2, Receiver Pioneer vsx 515 game console Sony Playstation DVD player Sony dvp-nc80v Whats the best way connect these?
Usually by looking at their manuals and working out the best compatible options between any two devices. I'm not being sarcastic. READ the manuals.
My personal advice (contrary to any manual) is to take the BEST video from each source directly to the TV if it has multiple inputs; route basic analog audio from the Cable Box to the TV for those times you don't need hi-fi audio; take the BEST digital audio from each source and connect it directly to the Pioneer.
NO signal ever benefits from a detour to or through a device that doesn't excel at processing it; or through excessive lengths or hops of expensive cable on the way TO the best device that handles any particular signal.
Avoid unnecessary or multiple digital-analog or a/d conversions.
My personal rig has no video entering the receiver and no high-end audio entering the TV and NO PROBLEMS.
Jul 09, 2011 | Panasonic Audio Players & Recorders
I just bought Panasonic SC-PT480P-K DVD home theater and TC-P46ST30 TV. I connect DVD HDMI output to TV HDMI input port #1. But when I try to play DVD, I just got sound out to the home theater speakers...
Let us take things step by step.
1) If you have an AV cable ( Yellow /Red/White ) try connecting the DVD players composite out (Y/R/W) to the TV's composite in. Select AV input instead of HDMI on the TV and see if you are getting an image. This is to confirm that the DVD video circuit is OK.
2) If all is OK in step one you can try buying a good HDMI v1.3 cable. You do not need a v1.4 cable which is only good for 3D bluray players.
Revert back for more.
Mar 07, 2011 | Panasonic SCPT480 Theater System
For some reason, my DVD player just started showing up in black and white. Also, when I select the "source" on my TV remote, instead of showing the option "AV" for the DVD player, it...
Select AV as your source and that should cure the problem as long as you have the video and audio cables connected to the right inputs. You could also use an S-Video cable instead of the video cable for better picture quality depending on your TV model (assuming it has a S-video input). Your owners manual(s) will probably have diagrams for you to follow.
Jan 30, 2011 | Panasonic DMR-ES40
HOW TO PLAY DVD PLAYER WITH THE TV
Instructions Things You'll Need:
  • DVD
  • RCA, component, or HDMI cable(s)
  1. Decide what type of connection to use. Look at the back of your DVD player. It should at least have RCA (red, yellow, white) output ports. It may also have component out, S-video out, VGA out, or HDMI out. These connections vary in picture quality and price, HDMI being the most expensive and providing for the highest-quality picture. Whichever type of connection you decide to use, you also need to verify that you have the same connection on your TV. Flat screen TVs typically have more connection options than other types of TVs, so you should at least have component, RCA and HDMI inputs.
  2. Connect the DVD payer to the flat screen TV. Take one end of the cable or cables you decided to use and connect to the output on the DVD player. The other end should be connected to the corresponding input on the TV. Video input connections are usually found on the sides of flat screen TVs. Once the DVD player has been connected, you are ready to use your DVD player.
  3. Check DVD player functionality. Tune your TV to the input that you used for your DVD player by pressing the button on your remote labeled "input," "source," "TV/video," Source select," "TV/AV" or the like. For instance, if you used an HDMI cable plugged into your TV's "HDMI 1" input, press the input selection button until you see HDMI 1 on the screen. Power on the DVD player, insert a DVD into the player and press play and you should now see a feed from your DVD player.
Jan 17, 2011 | Panasonic Televison & Video
We bought a new Panasonic high definition TV TC-L42D2 and we are unable to see a picture when we try to play a DVD on our Panasonic SC-HT650 System. We only get audio on the DVD. We are sure we have the...
So what's different? The TV. Anything else like the video type (s-video, composite, component)?
Perhaps if you described what cable is carrying video and the point-to-point connection to the TC-L42D2 we'd understand what isn't working.
Jan 16, 2011 | Panasonic SC-HT650 System
I have a Toshiba SD-K860SU DVD video player that I have connected to my Panasonic TC-32LX60 LCD TV, but I cannot get the DVD player to work. My TV is connected to my Comcast cable service black box. Should...
You should use the component video input (which ever the TV has), you will get better pictures than the S-video.
As far as the remote control for the DVD, keep using the one that comes with your DVD player, Comcast remote does not always work, beside you get full function using the DVD's remote, that is how I use my DVD, same for the TV, Comcast remote my not be able to send out the signals to the ATV for selecting the input sources on the TV. Comcast remote is not a full functions remote.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 06, 2010 | Televison & Video
Dvd won't send picture/audio to tv
for video, 3ways and any of this should work.
Step1, video out of dvd to video in on top at video1 section on tv. or
Step2, svideo out of dvd to svideo in at video1 section on tv. or
Step3. using component video DVD unit component video out to TV unit component video in at video2 Y to Y input of TV Pb to Pb input of TV Pr to Pr input of TV
for audio, connect left/right audio of dvd to left/right input of tv. Input section of TV is in the middle. on tv back panel from left to right is antenna input, IN section - this is it, use this for all your connections. let us know if you have any issues. thanks.
May 02, 2009 | Panasonic DVD-S27 DVD Player
Televison & Video Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
