I am getting no sound out of my computer. My speakers are connected, have power and indicate they are alive at boot-up. However, I have no sound. Could you possible help me resolve this issue?
    Scholar:
  • 70 Answers
It is possible that the sound drivers are not installed properly on your computer.
You can try the following:
1) check if the connections are properly placed. Make sure that the sound card is inserted on its slot correctly.
2) check on the device manager if the sound is properly installed
3) If you know the name of sound card, you can try updating the drivers for it. If not, you can try to check the manual of your motherboard if it is built-in. You can also try running the CD for the motherboard because sometimes the drivers are found there too.
I hope this helps you. :)
If you have other questions, just click on the ask button and I'll answer as soon as I can.
Posted on May 11, 2008
I can not get any sound out of the speakers. There is 6 ports (all different colors) I have tried everything. I have had the speakers for a year now. I cleaned the computer and the speakers came unplugged...
first connect both the satallite speakers to line out which is located near to the power switch (speaker out)
Now vertically above these 2 connectors there will be another connector that says remote control (audio input) this is connector that gets connected to your PC.On your PC this should get connected to the green port named as line in.
connect the power cable to mains
switch on th power switch which is situated at the rear of the subwoofer.The power indicator light will be lit up with a blue light
Now adjust the speaker volumes and try to play music
Dec 26, 2010 | Philips SPA2300 2 Speakers
My two speakers are connected and my computer is not muted,plus the plugs are tight but i get no sound. i have a toshiba satellite p305 laptop with windows vista home premium installed.
Make sure that the speakers are getting power.
Get another speaker, head phones or iPod headset and plug in. See if you get sound then, If everything fails this would indicate a problem with the computer or computer settings.
If other speaskers or headset works this would indicate a problem with the JPM-33 speakser.
Oct 06, 2010 | Jensen JMP-33 Computer Speakers
Getting buzzing sound from speaker but can here sound from them.
You could have an earth loop which causes a hum/buzzing sound.
Is your computer and powered speakers plugged into different mains?
Connecting amplifiers and speakers to different power sockets will create earth loop problems
This can be fixed by using a single power board connected to a single mains power socket, then connecting all the computer components and powered speakers into this one power board.
Oct 31, 2009 | Harman Kardon Harmon Kardon SoundStick II...
PC wont start/boot
hello...i think you need to check all socket connection on the board and you need to check the memory or try to reset the Bios.or check the ATX power supply it is good or working..thank you
May 08, 2009 | eMachines D3415 PC Desktop
No audio from nothing cd, flash player etc.
Have you checked your audio settings to see if it was muted by accident?
Also, did it work before, and suddenly stopped? Have you changed anything on the computer?
Did you check to see if the speakers are still connected? (the green out port on the computer) or that the power connection to the speakers is connected and on.
Do you get any sound from the speakers on boot?
Aug 05, 2008 | Acer Aspire™ T180 PC Desktop
My gateway laptop won't come on
for a no power issue there are three major component that can cause it: defective memory, defective motherboard, defective processor.
components that could affect the computer in booting: external devices: remove all
hard drive and optical drive: remove it too
if there are any pci card or any card installed in computer remove it. after removing all component and only the motherboard is left alone you should be getting some behavious which will indicate your computer is still alive: you will get to hear a beeping sound, a display error message that no memory is detected. if it doesnt turn on then the motherboard is dead
Jun 24, 2008 | Gateway 7330GZ Notebook
No power - no boot
no power no boot can be indicative of a motherboard failure or could also be the memory. try removing all the memories, hard drive, the optical drives and all external devices connected to your computer. if you get to hear a beeping sound .. your in luck your motherboard is alive and just need to isolate which among the remaining pieces is causing the no power.
Jun 14, 2008 | HP Pavilion dv1000 Notebook
Sound sticks II
My problem is fixed now. I plugged the speakers into the earphone socket. There was no immediate effect just silence. I twiddled the control on the bass unit, played with the volume controls on the sticks. Then I realised the sound was back with the external speakers not the internal ones. It was as though the Harman Kardon system was re-booting itself. Very weird.
Dec 05, 2007 | Harman Kardon Harmon Kardon SoundStick II...
No Power
Hi, 1)Try replacing the power cord of the speakers. 2)Be sure the wall plug has electricity. 3)Connect to speaker into another plug just to see if the green light come alives.
Dec 30, 2006 | Labtec Spin 45 Computer Speakers
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
