The digital box seems to be stuck at the start.Saying "Pls Wait" then "Welcome" but it won't move on to anything. Even if I pull the plug out and start again.The same things happens.Can you help?
  • 456 Answers
The most common problem that causes this to occour is a problem with the power supply. Check for any blown capacitors or shorted resistors, a blown capacitor will look like a cylinder with the top bulging outwards and a shorted resistor often comes with a small burnt out area around the component.
If your tech savvy you can replace the capacitors, or anything else that is blown yourself, otherwise you can take it to the closest repair shop and they may be able to replace for you. I hope this helps.
Posted on Sep 04, 2010
Atlas ocap
use the camera digital or cell cam and with the remote control viewn see if the LED are ON. see the photo attached.
If do not do it. Open the remote control clean the keypads from corrosion, and resolder any colder joint . clean the contacts batteries and try again.
May 30, 2013 | Televison & Video
Elantra won't start and moves when it's in park
I'm going to say something happened to the cable between the shifter and the transmission. There is a switch on the transmission that prevents you from starting the engine in anything other than park or neutral. The transmission is probably in reverse or drive which would allow it to roll.
Someone would need to check the lever on the trans where the shift cable is attached.
Sep 17, 2012 | 2006 Hyundai Elantra
The freeview box listed above will not come on it just keeps saying starting then it says wait please help?
Switch it off............................Pull the plug out of the mains.....pull the aerial plug out......
Now.......wait 3 minutes.......plug back in the aerial ensuring the wiring of the aeriel is okay...plug back the mains.......click menu......retune.........hope this helps.
Mar 19, 2011 | Audio Players & Recorders
VTOUCH is stuck on welcome screen saying please wait
WAIT 4 IT FOR A LITTLE WHILE ND IF IT KEEP SAYING THAT CALL THE PEOLPE ON YOUR MANUAL
Jan 08, 2011 | Visual Land V-Touch Digital Media Player
Vtouch stuck on welcome screen
same problem for me too sir...if u get the solution..pls let me know...my id is mruniverse.mrwhite333@gmail.com
Oct 19, 2009 | Visual Land V-Touch Digital Media Player
V-touch freezes at welcome screen
same problem for me........... the v.toch do not pass from welcome mode
Sep 28, 2009 | Visual Land V-Touch Digital Media Player
Pullstart wont pull
sometimes the float in the carb can stick causing the gas to fill the engine, this will prevent the engine from moving and therefore locking the pull cord. check the oil, is there gas in the oil? remove the spark plug and try to pull the cord again. gas may come out of the plug hole . if this is the problem you must change the oil and fix the carb. the other cause could be that the engine is seized. ouch.
I hope this helps
Sep 01, 2009 | Garden
Problem with my vtouch frozen on welcome screen
return it that is a well known problem and that happens to every 4 out of 10 vtouches just send a note explaining the situation and that you want a new one
May 29, 2009 | Visual Land V-Touch Digital Media Player
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
