My sagem digibox has stopped working; when I press the remote after it has been switched off ER07 flashes on the screen, press the remote again and ER01 appears, press again and the timer starts. I can hear the hard drive start up!
  • 12,061 Answers
Er01, Er02 -The upgrade failed. Some information was missed out.
Er07 - Access problem in back-up memory (EEPROM).
That's a fairly major error you have there, this is a memory problem, and or a CPU access problem. In any event this is NOT DIY repairable, in fact most likely this is a fairly terminal condition.
The first error is what one gets after a bad "Flashing" of firmware OR when the unit fails to checksum program codes, it is most likely tied in with the second one, that indicates that the Memory, the EEPROM couldn't be read/written to correctly, so most likely the Micro is involved as well.
If this could be repaired at all, you would have to get it looked at by a Sagem, service center, however, they would most likely just have to replace the main board, and I think that this may not be an economic thing to do, with this in mind, please ask for a 'Quote" before allowing any work to proceed. as cost with these types of things can quickly escalate quickly.
Posted on Sep 04, 2010
Sky box green light on permanent
Sounds as if the software is corrupt. Try a forced software update...
1) Switch the digibox off at the mains power, so no lights are displayed on the unit
2) Press and hold the BACK UP button on the digibox (not the remote control)
3) Whilst holding, switch the digibox back on at the mains power so the red standby light is displayed
4) Wait approximate. 10-20 seconds for the remaining 3 lights to display, at which point you can release the BACK UP button
5) Allow the digibox to download the latest software, which can take 10 minutes before returning to standby
6) Leave 60 seconds then power up as usual
A software update/refresh will leave your recordings intact. You won't lose anything.
If this doesn't solve your problem, then the next step is more drastic. It's a Full System Reset and Planner Rebuild. Be advised though: Your recordings are at risk!
1) Switch your digibox on
2) In sequence, press on your remote 'SERVICES > 4 > 0 > 1 > SELECT' (this will access the hidden menu)
3) Select the relevant option (usually the bottom two) and follow the on-screen prompts (note that it's likely your digibox will reboot between processes)
Applies to Sky+HD Digiboxes only, running latest EPG
1) Press Services on your remote control. 'Options' in the Top Menu will be highlighted in orange.
2) Press the Right arrow once to highlight 'Settings' in the Top Menu.
3) Now press the Down arrow once to highlight the 'settings' tab in the Middle Menu.
4) Press 0, 0,1, Select on your remote in quick succession. The 'Setup' tab will then be highlighted within a hidden menu.
5) Select the relevant option and follow the on-screen prompts (note that its likely your digibox will reboot between processes)
Sky Digibox Planner Rebuild / Full System Reset (if stuck in standby)
Applies to Sky+ and Sky+HD Digiboxes only
Same as above, but applies if your digibox is stuck in standby and you cannot get to the hidden menu:
2) Press and hold the 'right and left arrow' buttons on the digibox (not the remote control)
4) Wait approximate. 30 seconds for the blue Sky+ ring of lights to display, at which point you can release the 'right and left arrow' buttons
5) Press 'SELECT' on the digibox (not the remote control)
6) Now the system will format the hard drive, the blue Sky+ ring of lights should spin backwards
7) Allow the system to format, which can take 10 minutes before returning to standby
8) Try to power up!
Sep 02, 2014 | Televison & Video
How to remove sub titles from Sagem Digibox in UK
Bottom row of buttons, second from the left (Picture of screen with a line at the bottom). Press that and the subtitles will come and go as you wish.
Jan 15, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
Er09 and Er07 black screened
Turn off the unit for 15 mins.
Turn back on with eveything connected except the antenna.
You will get an er 09 on the display.
Press OK on the remote.
With a bit of luck the box will reboot into standby.
Connect antenna and see how you get on.
Jan 07, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
My sagem DVR 6200T UK is now displaying when switched on P603 then it goes to ER07 this started last night.There seems to be no signal to the TV from the set top box and the remote wont work! i have...
Hi I had the same problem P603, er07 and er09, solved it by buying a 12v adaptor, you dont have to use sagem, in fact they are not very helpful, they will only take credit cards and it will cost you £15.00, any 12v adaptor will do. Mine is working perfectly now
Sep 26, 2009 | Televison & Video
I NEED TO KNOW HOW TO GET AND WORK CODE FOR UET609 UNIVERSAL REMO
n these remote controls any device key can operate other device types because coding is by selecting a number from a list ranges for UET609 - tv: 000-268 and 700-758, vcr: 269-370 and 750-758, sat/cbl: 371-523 and 800-883, aux (cd, dvd etc): 524-699.
As there are 800 codes, select the appropriate device before searching for a code! This presets the start position in the search.
To set a code:-
Press and hold [set], press device key - red led lights. Release keys. Enter 3-digit manufacturer's device code from the list. Led goes out and the code is set. If it doesn't work try another or search.
To search for a code:-
Turn on consumer device!
Press and hold [set], press appropriate device key - led lights - release keys - press [set] - led blinks. Press [power] key repeatedly till device is switched to standby - press device key to store the code. If, after releasing the keys, [set] is pressed twice, search runs backward through the list.
Having found the code, it may be useful to write it down, as follows. Press and hold [set] - press [1] and release. Count and record the number of times the led blinks - release [set]!. Repeat for [2] and [3].
Note! The above information is from the manufacturer of the remote controls. In practice, things may be a little different i.e. on the UK Sagem digibox [power] is digit 1 and the power key is [tv/txt]!
These controls can be regarded as old stock and may not contain codes for digiboxes and DVD drives. However, surprising things happen, if a manufacturer is using old codes. The Goodmans GDB3 digibox can use UET609 sat/cbl code 424 and the Sagem ITD59G can use unlisted code 836.
To repeat, the protocols and associated key codes are referred to by a 3-digit control code, taken from a list of 800. You should find the necessary code fairly quickly - within 100 tries, if you select the correct device type.!
There is at least one more remote control in this series and operation should be the same, though the key layout varies between models.
At times, these remote controls can malfunction.
Red Led stays on - Remove the batteries and re-insert them.
Remote Control suddenly stops operating - make sure correct device key is selected. If necessary, re-enter the relevant device code. If this fails leave the batteries out over-night and re-enter the codes.
Codes: 044,054,119,124,196,198,225,227.
If it works vote for me
Aug 17, 2009 | Televison & Video
Error codes er o7, er o9
Had exactly the same problem during Oct 09. Spoke with SAGEM all sorts of solutions no joy. Spoke to currys and tried a new power source and it works fine. Ordered a new source via SAGEM approx £15 and now have a working box. Saved having to buy a replacement and all my recordings are still in tact.
Apr 11, 2009 | Televison & Video
How do i key in code for digibox
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
If after trying this, you still have problems, call your broadcaster's help desk. For your broadcaster's help desk number, select the Telephone Numbers option from the Services screen.
Dec 19, 2008 | Computers & Internet
Sagem digibox connections
I think it´s impossible.
May 29, 2008 | Sagem Televison & Video
Sagem digibox code
which sagem model do you have ?
have you set/changed the parental controls on the remote ?
post back i will try to help you .
J J .
Oct 23, 2007 | Audio Players & Recorders
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Electro Med Services...
