Question about Amana Refrigerators
Hi, I have a refrigirator Amana AS2626. I replaced the water filter and the red light is still on. I drained more than 5 gallons of water already and it is still on. Please advise what can I do.\r\nThank you.
  • 3 more comments
  • aviva261 Sep 04, 2010
    Sorry, but this does not work. After I pressed both buttons at the same time for 4 seconds, all the lights went off (light did not flash) and would not come back. I repeated the same procedure and the lights went on to the same initial situation - the red light is still on.
    Hi, I have a refrigirator Amana AS2626. I replaced the water filter and the red light is still on. I drained more than 5 gallons of water already and it is still on.I pressed and hold the dispenser lock and auto light buttons on the dispenser at the same time for 4 seconds. All the lights went off but they did not come back. I had to press once more just to restore the lights and still, the red light is still on. Please advise what can I do.Thank you.
    Hi Ginko,
    I tried disconnecting and it didn't work. I shall try defrosting tomorrow. Thank you very much for the advice.
    Aviva
    Hi Rotorcrafts,
    Just to confirm that I finally did succeed to fix the problem by pressing the dispenser lock and water buttons at the same time. Somehow I failed to do so on my first attempt. Thank you very much for your assistance, Aviva
  • aviva261 Sep 05, 2010
    Much appreciated. Thank you,
    Aviva
  • Amana Master
  • 19,396 Answers
Normally, to reset the Indicator Light on the fridge, you press and hold the Auto and Dispenser Lock buttons until the water filter indicator light flashes (forget about the 4 secs).
If no luck, disconnect fridge from power for five mins and try again.
If that does not work, either the filter is defective, board is defective, or there is a problem with water inlet sensing due to water frozen somewhere inside the inlet lines.
The first two occurrence are quite uncommon, new filters are rarely defective, and faulty control boards usually cause more than one problem.
If possible do a complete defrost of the unit, that should fix the red light problem. If it does not, then the fridge is defective. In that case call Amana at the number on the user manual.
Regards.
Ginko.
Posted on Sep 04, 2010
  • Ginko
    Ginko Sep 04, 2010
    Hi.
    Try defrosting, first ensure that you are performing the reset procedure correctly.
    Guru:
  • 302 Answers
You need to reset the water filter light. Following is a general procedure for Amana Refrigirators.
Amana - press and hold the dispenser lock and auto light buttons on the dispenser (at the same time) for 4 seconds until the filter status indicator begins to flash, then release the buttons. On some Amana fridges you need to press the dispenser lock and water buttons for 4 seconds until the filter status indicator begins to flash, then release the buttons.
Amana ARSE667BS1 refrigerator chilled water taste bad but ice doesn't.New filter and new reservoir.
Run 3 to 5 gallons of water through the new filter to flush it out and prime jt
Sep 02, 2016 | Amana Refrigerators
Water Filter
The minerals could be built up in all the water lines. The water lines in the refrigerator as well as the one that supplys the refrigerator.
Feb 13, 2014 | Amana ASD2522WRW - 25 cu. ft. Side-by-Side...
How to clean and sanitize a Kentwood water cooler?
Using one cup of bleach Per 5 gallon jug. Find the drain plugs on the bottom of the unit there are two. Drain unit of any water that is in it now. Replaced drain plugs. Place 5 gallon jug on top of unit and allow unit to fill. Be sure that heated water is off. Open spigots and allow a gallon of water to drain. After about 15 minutes open the drain plugs and allow all of the solution to drain out. Proceed to fill the 5 gallon jug with clean Clear filtered water and allow that to drain thru the unit, do this five more times.
Oct 29, 2013 | Hamilton Beach Water Cooler with Storage...
I cant get my refrigerator unlocked
Hi: I don't know if you have the manual, but you have to hold down the lock button down for several seconds to release it. That how it works. I hope this helps and you don't need service. As a last resort unplug the fridge for an hour ( don't open it in the interim) then plug it back in and see if it resets. I hope this helps, Jeff
May 31, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Changed water filter red light stays on
you will wither have to push the light switch button 5 times or push and hold reset button or 2 at a time. Look at the display carefully it usually will tell you what you need to do
May 27, 2009 | Amana ARS2464B Side by Side Refrigerator
How to reset red lite on water filter,on front offrig
Press and hold the lock and water buttons at the same time for 5 seconds the green light will flash 3 times when it is reset. Good luck
Apr 23, 2009 | Amana ARSE66MB Side by Side Refrigerator
Amana refrigerator water dispenser
could be carbon particles from a broken carbon filter cartridge. replace the filter and flush about 5 gallons of water before checking the water again that comes out of the dispenser.
Feb 19, 2008 | Refrigerators
Refrigerators Logo
234 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
