Question about De Dietrich Microwave Ovens
I have a De Dietrich DT1704V induction hob purchased Nov 2009. It won't work - tried switching on & off several times - an error message "d4.4G.22.A3" is displayed on the left hand control rings panel. Can you help please.
2 Suggested Answers
  • 1416 Answers
SOURCE: code e on only two
Hello.
These codes mean that the oven's electronic control hasdetected a condition it needs to check which mean error. When you see a code,follow these steps to solve the problem:
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on.
Thanks.
Posted on Sep 07, 2011
My De Dietrich DME 101XE1/3 microwave oven does not work.
I'd check the door switches first. The primary and secondary ones must go into the closed position when the door is shut.
You might also have an open thermal cut out on the outside of the cavity. There is also one on the magnetron you could check, although it's les likely to cause this problem.
Avoid all high voltage components, as there's likely to be a 4000 volt charge on the high voltage capacitor. Unpleasant to touch, and it could be fatal.
May 12, 2016 | De Dietrich Microwave Ovens
Aeg glass induction hob error code ER 21
reset the microwave. Disconnect the power cord, by 1minutes, and try again,the microcontroller is confuse.
If the problem persist you can be problem with the main controller board, repllace, but read your owner manual section troubleshooting for identi the error. download from www.retrevo.com
God bless you
Oct 27, 2013 | Microwave Ovens
How to reset De Dietrich oven DO410
follow this step and fix it. A power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
God bless you
Jul 20, 2013 | De Dietrich Microwave Ovens
Tried to change time on clock and all the power has gone out of the microwave
The fuse in the microwave has blown, there are any number of reasons for this, one of the door switches has failed, "common problem" or in some cases just the fuse will go.
Mar 25, 2012 | De Dietrich DME101 1000 Watts Convection /...
I have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the...
Dear Sir i have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the problem How Can Solved this Problem This prestige induction cook top model PIC 3.0 Only one week so please do need full
thx... Kundan singh Rana Baddi (H.P.) 09857455945 ranansd@gmail.com
Mar 23, 2011 | Microwave Ovens
The induction cooker when put on it shows E6 after about a minute or so and no heating takes place.
There is a error message there, it indicate a problem with your induction cooker. It cause a defective winding wire or circuit controllers your know induction cooker works similar to the principle of electro magnet induction, it give heat to metal cooking pot. I hope I give you a idea regarding what happen to your unit.
I have a cata ceramic hob. the child lock has been engaged & is restricting operation of any of the 4 hob's
When you turn on the hobs main power, press the the rear left hand element pad at the same time and the lock will come off.
press the centre minus button and the bottom right plus button at the same time it will work if not keep trying
You have to hold down the centre sensor button with the minus on and the sensor which turns on the bottom right ring immediatley after turning the hob on. It should unlock, then press the minus again
the hob switchs off
when you now switch on there will be no lock
Feb 04, 2011 | Microwave Ovens
De Dietrich DME 112 XU2 Turntable not working
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Dec 13, 2008 | De Dietrich DME112X Microwave Oven
Microwave Ovens Logo
130 people viewed this question
Top De Dietrich Microwave Ovens Experts
William Miller
William Miller
ray gallant
Tom Chichester
Are you a De Dietrich Microwave Oven Expert? Answer questions, earn points and help others
