Question about Dryers
How to replace the rear felt seal on a whirlpool electric dryer
    Genius:
  • 1,665 Answers
Http://www.repairclinic.com/SmartSearch/smartsearch.aspx?SearchText=`ADryer
Posted on May 11, 2008
Why does my Whirlpool electric dryer - model SEDS800JQ0, shut off after 2 minutes?
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Aug 09, 2014 | Whirlpool Dryers
Felt seal on back part of drum whirlpool
Felt seal and glue
What I would do is take the dryer apart and remove the old drum seal. Get as much of the old glue off there and install new felt. I tuned upa dryer built like yours not long ago and took some photos.
Roper dryer tuneup
Nov 02, 2011 | Whirlpool WED5300S Electric Dryer
Brown marks left on clothing -- occasionally My dryer is not gas but electric but that wasn't a choice on here.
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dryer only works when the door is open
  • Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
  • Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
  • Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Apr 22, 2010 | Whirlpool LEW0050P Electric Dryer
Brown streaks on flat, thin items like pillow
Hi Witt and welcome to FixYa. I am Kelly.
The brown streaks are most likely rust. There are drum seal replacement kits you can buy to start anew. The streak source need to be identified. If the drum is rusted your going to have to sand and paint it with an enamel appliance paint. However.... if it is the back of the cabinet that is the source of the rust in the felt seal rub area if you do not allow the paint to dry well before reassembly it will end up flaking off on your clothes.
Here is the drum seal with adhesive:
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Rear-drum-felt-seal-with-adhesive--red-thread--item-number-AP3094149.aspx
Once you in there I would replace the belt and inspect the drum rollers.
Belt:
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Whirlpool-Dryer-Belt-item-number-AP2946843.aspx
Rollers:
http://www.appliancepartspros.com/part_details.aspx?part_id=3098345
The belt I would replace... Just make sure if you attempt repair that you NOTE the routing of the dryer belt through the idle pulley to the motor pulley.
If the rollers rotate freely with no teetering froward or aft and do not have any flat spots you do not have to replace them.
Appliance paint by color needed:
http://www.appliancepartspros.com/Appliance-Parts/?keyword=Appliance+paint
Thanks for using FixYa
Kelly
Mar 14, 2010 | Kenmore 62602 Electric Dryer
Whirlpool duet dryer felt seal replacement
The drum may to be removed to install the new felt gasket but the old drum can then be reinstalled. The felt gasket seals the joint where the drum rotates at the inside back panel. It is likely that the inside back panel can be removed when the dryer is placed front-down and the outside back panel is removed. In that case the drum does not have to come out.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My clothes have brown marks on them that look like burn marks. has this been a problem with maytag neptune dryers? if so, what is going on?
Rollers
Rear seal
Front glides
Front seal
Jun 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
I have a whirlpool LET5624BW2 dryer making noise like rock tumble
you will need to replace drum rollers, idler pulley and belt .All three items available in a repair kit thru whirlpool.only replace rear seal if it is torn or frayed
Jun 17, 2009 | Whirlpool LEW0050P Electric Dryer
Brown streaks of clothing from dryer
Check your front and rear felt seals. How old is the dryer and what is the model number?
Eric
May 16, 2009 | Whirlpool LER4634J Electric Dryer
Electric dryer leaving brown marks on clothes
i would asssume that the marks are "crescent moon" in shape??? if so either the front or rear felt has/is going bad and casuing clothes to slip betweent the tub and the seal causing the streaks
Mar 14, 2009 | Whirlpool Dryers
Dryers Logo
181 people viewed this question
Top Dryers Experts
