For that access your wireless router settings make sure vpn is configured properly there. You can access your router with below method make sure port is open for vpn and ip of remote destination is perfect. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Let me know if you need further assistance. Thanks for using FixYa.
Verify the vpn driver again ..and be sure the driver is ok ..cause sometimes the auto updates messes with them ..also check the settings in the remote machine not to be changed..or fire-walled..(in your computer also ..(Im not sure how its called for mac..)
If the settings are the same on the remote machine ..(be sure they were not reinstalled or the values changed..for the IP or ..anything else required..) and if the prove to be the same ..restore your computer to an earlier stage ..or reinstall the VPN protocol ..
I have not changed anything. Yesterday I used my sons wireless network, with the same router, and everything worked ok.
So VPN Tracker should be ok.
Is there anything in the router that I should change, VPN Tracker says that iPsec passthrough is not working.
To solve this problem, just go into the router and turn off iPSEC, reboot and then turn iPSEC on again.
This solved my problem at least!
