Resettable circuit breaker on back panel of Curtis Model SPF-4P no longer holds in closed condition. Manually holding the breaker reset button depressed allows energizing Master Switch and through it any other peripheral outlets that are selected ON but only until the reset is released. Checked all internal fuses (3) good. Suspect the installed circuit breaker is failed but is the part available?
  • brigantin540 Sep 06, 2010
    Would possibly have been of use, but had already found the equivalent 15A, 125V resettable breaker in the latest Newark Electronics catalog. At $2.44 plus postage, I'm certain Curtis would not have come close to matching the price.
    Thanks for your interest but this time my catalogs led me to the well.
    Chuckk
  • 490 Answers
Howdy, this is not the final solution, but here is the contact information for Curtis in the mean time. Still working on it:)
http://www.curtisint.com/support/support.asp?brand=CURTIS
Regards, Farmerbear
Posted on Sep 04, 2010
How can I unlock door of front loading LG washing machine
You can try "resetting" the washer. Unplug or trip circuit breaker. Push and hold power button for 10 seconds. Plug back in. Power on and back off. See if that works. If not, try pushing the door in pretty hard and see if tha releases the lock. If all else fails, you can take the top off, the control panel off and reach down with a long screw driver and manually release the lock. Good luck.
Dec 12, 2017 | LG Washing Machines
Why my start button on my control panel won't work?
Ca you please give me the make and the model no. so that i can help you fix it.
Waiting for your reply
Apr 13, 2008 | Kitchen Ranges
How to reset brandt washing machine
Stopped or Won't Start If the washer won't start or has stopped during a load, verify it has power. Plug a nightlight or other device into the power outlet to test it if you can easily access it. Otherwise, check the circuit box for a tripped breaker. Open and close the lid or door of the machine. If the washer stopped during a wash, adjust the load so that it is balanced. Check if the drain hose is clogged, and clear if needed. Turn the machine on with dry hands. If it still won't start, unplug it or turn the circuit breaker off, then back on until the breaker firmly clicks in place and plug the machine into the outlet. Push the restart button. Some machines may require you set the knob to a specific setting for the reset feature to work. On some machines, hold down the button labeled "Start-Pause" or "Stop" for a slow count of five. Turn the washing machine on. Run a rinse and spin cycle to check that washer is working and that the error code, if applicable, cleared.
Washers Without a Reset Button If it isn't possible to access the washing machine's plug to manually reset the washer, turn off the circuit breaker. Leave it off from 30 seconds to 1 minute, depending on the machine model or instructions in the owner's manual. For washers with a knob control, turn the dial clockwise to any cycle other than "Final Spin." With button controls, select any cycle other than "Spin." Check that the water to the washing machine is on. Turn the breaker back on. Turn the washing machine on. Some machines require that you open and close the lid six times after plugging the machine in to reset the motor.
When Reset Doesn't Work In some cases, after using the reset button -- or resetting the washer manually -- nothing happens. Your machine may have a problem or a faulty part that keeps it from operating. Among the most common are problems with door switches, latches or a faulty timer that may require replacement. Authorized technicians can replace parts or service the washing machine as needed. Websites of major manufacturers have replacement parts available to order and some provide schematics or answer your questions. On a recent-model washing machine, check if it's still under warranty.
Aug 14, 2016 | Brandt Washing Machines
Our 7788F keeps going into a ground fault condition. Need help troubleshooting. John
Ground Fault ???
Troubleshooting Ground Fault
Troubleshooting a ground fault circuit interrupt, or GFI, breaker is pretty straightforward. Troubleshooting the circuit itself can be quite time-consuming.
The GFI breaker is designed with a test button incorporated into the breaker itself.
Pushing the test button should trip the breaker.
On GFI-style breakers the neutral wire going into the house's outlets is connected to the breaker's neutral connector, the white neutral that comes out of the breaker is connected to the neutral bus in the panel, isolating the neutral bus from the neutral wire going into the house.
The test button actually shorts the neutral wire feeding the circuit to the neutral bus in the electrical panel creating a ground fault that should trip the breaker.
It is considered a ground fault because the neutral bus in the main electrical panel is actually connected to the ground bus through the panel's metal casing. What to do if the test button isn't tripping the breaker
Push the test button on the GFI breaker.
The breaker should trip.
If the breaker does not trip, then it may be that the breaker has already tripped and just looks like it's on.
The position of the switch may only move slightly from the on position towards the off position when tripped.
Push the switch on the GFI breaker all of the way toward the off position.
It may take some force to get the breaker to reset.
Turn the breaker back to the on position.
When the breaker has been reset properly you should feel some resistance when pushing the switch back on.
3 Push the test button again and the breaker should trip.
If the breaker still doesn't trip then you should test for power at the screw connections inside of the electrical panel.
Remove the screw that holds the dead front covering the breaker's connections.
Remove the dead front cover.
Test for power with your voltmeter set on AC volts on the highest scale.
For a single pole GFI breaker, touch the black lead from the tester to the silver screw on the GFI breaker and touch the red lead from the tester to the brass screw on the GFI breaker.
You should see 110 volts on the tester. If voltage is seen but the test button won't trip the breaker, then the breaker is bad and should be replaced.
5
Test for power on a two pole breaker by touching the red voltmeter lead to one of screws with a black or red wire connected to it.
Touch the black lead to the other screw with a black or red wire connected to it.
You should read 220 volts or close to it on your voltmeter.
If you read voltage and the test button won't trip, the breaker is bad and needs to be replaced.
What to do if the breaker won't reset and keeps tripping when turned on
6
Unplug everything that is plugged into any of the outlets on the circuit in question.
Try resetting the breaker again by pushing the switch all the way to the off position and then turning it back to the on position.
If it won't reset and trips when the breaker's switch hits the on position, it could be a bad breaker or a problem in the circuit itself.
7
Use your straight-tipped screwdriver to loosen the brass connection screw or screws on the GFI breaker.
Pull the black hot wire, or wires, out of the breaker's connectors.
Loosen the silver screw the white wire is connected to and remove it from the GFI breaker.
8
Push the switch all the way to the off position.
Turn the switch back to the on position.
If the breaker still won't reset, then the problem is the breaker itself and it should be replaced with a new one of the same size, brand and model.
If the breaker resets normally and the test button trips the breaker when pushed, the problem is in the circuit itself and an electrician should be called to find your ground fault.
9
Reconnect the black wire, or wires, to the brass screws on the GFI breaker.
Reconnect the white wire to the silver screw on the GFI breaker.
10
Replace the dead front cover into the breaker panel.
Install the screw or screws that hold the dead front in place.
http://www.hilo-electric.com/blank?pageid=63
Aug 14, 2013 | Computers & Internet
Have Challenger Type C 2100 circuit breaker in residential home electrical panel. Manually turned to off position and now cannot turn back on. Pops back to off position. Also says HACR type and common trip...
First HACR is heating, air conditioning,refrigeration. So in other words you could use it on an electric furnace or air conditioning.
IS this the main breaker for the panel? or for and electric furnace. I'm assuming its for the furnace, perhaps back up heat for heat pump. See if there is another disconenct on the furnace, turn it off and see if the breaker resets. IF so you have a short or overload in the furnace.
If' it IS the main for the panel, turn off all the other breakers in the panel, and try to reset the breaker. If that works, turn the other breakers back on one at a time. IF it "POPS" then it is tripping. Don't keep resetting, find the problem.
Jul 19, 2010 | Challenger Connecticut Electric UBITB-A230...
How do I reset a Eaton breaker with a tester on it?
This is a GFI (Ground Circuit Interrupter) Breaker. So you need to turn off the circuit breaker first. Then you need to reset the GFI (yellow button) by pressing in the button. And then turning the breaker back on. Now, with some GFI's, you need power on to reset them. So if this is the case, reset the circuit breaker by turning it off and then back on. Then press the yellow button in, and it should hold. Then you should have power restored. I hope this works for you. If not, feel free to contact me again. Good Luck!
Mar 27, 2010 | Eaton 20A ARC FAULT BREAKER
Half of the appliances and outlets quit working when hot water tripped . we reset then next day the lights went out in my bedroom (master) the kitchen and the stove as well as the AC no longer work . where...
Go to your electrical panel and check your circuit breakers. You can check each one by turning each breaker off - then back on again. You should get back some of your electricity. Also, you probably have a GFI circuit breaker located in your kitchen (near the sink) and in your bathroom's (near the sink/basin). Make sure to push in the reset button (make sure it holds when you press it in). This will explain why you have some receptacles that are out in other parts of your house.  Why receptacles are wired through GFI's, etc... are to provide extra grounding protection. I hope this works for you. If not, feel free to contact me again with more information. Good Luck to you!
Mar 18, 2010 | Siemens #MP120GF 20A SP GFI Breaker
I have a question
Sounds like the breakers are mis-wired. This is a common mistake with those kind of breakers. The white wire that is permanently attached to the breaker (usually coiled) connects to the neutral bar in the panel. Look closely on the breaker, you will see two terminals. The white (circuit) wire that goes out to load connects ONLY to the neutral terminal _on_ the breaker itself, _not_ to the neutral bar in the panel.
Dec 17, 2009 | Cutler Hammer "CUTLER HAMMER" ARC FAULT...
Is there a reset button on a kitchen aid electric dryer...appears to have over heated and I just cleaned it up. Can I just press a reset button? If so,where is it? EastsideRose
There is no resettable fuse on this model dryer I hate to say. If the thermal fuse blew out, you wont get heat, but dryer will run. If dryer doesnt run at all, you will have to remove the back (if your model # is right) and replace the thermal FUSE (not cutoff). Three screws on either side of the back, three at the top near where the pigtail goes in. You will see a small white fuse with two wires going into it. Very easy to fix, and part very inexpensive.
Jun 11, 2009 | Whirlpool LEN2000PW Dryer
I want to reset my printer defaults and don't remember which buttons to push
Power the printer on, and press and hold the "Online" button to revert back to factory settings
Apr 22, 2009 | HP LaserJet 4 plus Printer
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
