Question about Hotpoint Ultima WF860 Front Load Washer
Not spinning- F5 fault error Hotpoint Ultima
I have a F5 error- I followed your advise and cleared a few hair clips from the ball joint but the fault still occurs.
How do I get to the pump and its filter?
I HAVE A HOTPOINT AQXXD 169 PM WASHING MACHINE WE HAVE A FLASHING MESSAGE F5 WHAT IS F5 AND WHAT DO WE DO. IS IT IN THE INSTRUCTIONS SOMEWHERE??????? WHAT PAGE????
Posted on Sep 10, 2010
The pump is located bottom left as you look at the machine from the back, if you slide the pump to the left it will come loose, unscrew the three screws to look inside the pump and their you will probably find some more debris, remove the debris and the machine should work okay on any wash program. Best of luck Tim17
Posted on May 23, 2008
My washing machine is a hotpoint ultima and it is 4 years old . the drum is not spinning and an error msg f-02 is displayed
fo2 is a motor fault, possibly the motor tacho, brushes, broken wire to the motor or module board is faulty.
Apr 07, 2010 | Hotpoint Washing Machines
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt746 error f-12
Just had F-12 on my Hotpoint Aquarius washing machine. Problem was due to water not draining. Power off. My machine has access plate at bottom on the back. The water drain is held onto the drum via a jubilee clip and when i took it off the drain was clogged with hair, sweet wrappers, money, hair bobbles Once cleared, put back as was - machine now running ok..
Nov 03, 2008 | Washing Machines
Error code f08 on Wt940 ultima.
not sure if this will help but try:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Apr 02, 2008 | Hotpoint Ultima WF860 Front Load Washer
Error code f 05
this worked for me and I made 25p for the trouble:
Mar 16, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt741
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Error codes
Nov 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima (WT960)
this worked for me:
Jul 01, 2007 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN SPEED.
I read that someone has a problem with F-03 on the display. I have seen this for the first time on my hotpoint wf860 1600 spin. I read the manual the only thing I can think of maybe an unbalanced load in the machine. Albeit the manual is not clear about this. P21 automatic features unbalanced load warning.
Sep 04, 2006 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
4,769 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
