Question about HP LaserJet M4345 MultiFunction Printer
49.4C02 error is coming on Hp laserjet 4345 printer already latest firware updated.recentely changed printer motherboard also.
  • 1,218 Answers
Printer error 49.4c02 may occur due to corrupted print queue. Just clear the queue and restart the printer and the error may be fixed. This would seem to work for most cases. If none of them are corrupted, check to see if any of them are in an uncommon size. Larger printings tend to result in this error as well. Check if it's the cause by clearing the queue then printing normal-sized documents instead. The error may also be caused due to complicated fonts as they are harder to read, especially if they're in color or written in a pdf format. If this is the cause of the error you can either stop printing such documents and update the drivers or firmware. The drivers may contain bugs which cause the printers to act this way, so updating them will solve the problem. get more information and help Printer Error 49.4c02
Posted on Sep 18, 2010
What Can Cause the 13.03.00 Jam in Tray 2 Error in the HP laserJet 4345
Worn rollers ? Are the feed rollers "shiny" ? If so, replace them. Part number is RM1-0037-000. Easily available.
Aug 08, 2016 | HP LaserJet 4345mfp All-In-One Printer
How to fix Error 60.02 for hp 4345
Easy steps to fix Error Code Clr20r3 occur in HP Computer/Laptop/PC on Windows OS by dialing HP Customer Support Phone Number 1-844-355-5111 (toll-free) with the help of customer support services.
HP Customer Support Phone Number 1 844 355 5111 HP Help
Sep 08, 2015 | HP Office Equipment & Supplies
Where is mfp 4345 scaner driver
You need to specify what are you looking for. Is it the driver it self, for specific platform/OS. Or do you need to locate the driver which is already installed on your computer?
Drivers Software Firmware for HP LaserJet 4345 Multifunction Printer...
Apr 28, 2014 | HP LaserJet 4345mfp Printer
Error code 13.20.00 for hp laserjet m 4345 mfp
Hi!
According to HP service manuals, the error you described is in the category:
JAM INSIDE TOP COVER AREA
and more specific:
The pre-feed sensor, the top-of-page sensor, or the fuser-delivery
Those are the points where some paper pieces or even dust can be stuck.
Hope it helped,
Bogdan
Aug 30, 2011 | HP LaserJet M4345 MultiFunction Printer
We are getting this message on the LCD panel of Hp laserjet 4345 MFP printer. The display shown an error 50.5 fuser I have replaced the fuser but same problem still come. I also turn off the printer for...
That error says that you have the wrong fuser in the printer.
Why did you change the previous fuser?
The part number should be RM1-1043-000CN.
If you installed the correct fuser, then you should be thinking about changing the DC Controller.
May 11, 2011 | Office Equipment & Supplies
Model HP LaserJet M4345 MFP The printer displays
You've done everything but replace the formatter.
Can you look at the Event Log? Look for a 79.xxxx error. That is definately a formatter.
Is this a solid error, meaning does it appear when printer inits?
Remove the DIMMs and flash memory and network cable. And reinstall one by one until error reappears.
Do you have another 4345 that you can "borrow" a formatter from?
Jan 11, 2011 | HP LaserJet M4345 MultiFunction Printer
Have a new Windows 7 system. Trying to install CM1312nfi MFP printer. When trying to print, get PCL XL error IllegalOperatorSequence
Go to the following links.The first will provide your drivers,firmware and software to download.This seems to be a very common problem with the printer.Get the latest drivers,maybe install the latest firware,if it's newer,and a lot of people have fixed it by using the universal driver rather than the 1 specifically for your OS.Let me know if it works out.
Bob
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3562006&lang=en&cc=emea_africa&prodTypeId=18972&prodSeriesId=3558902&taskId=135
Aug 09, 2010 | HP LaserJet CM1312 All-In-One Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
CONTROL PANEL BLOCKED LJ4345
Friend,
Yes, there's a firmware that should fix this. It can be found HERE:
Hopefully this will do the trick.
//Al
Feb 09, 2009 | HP LaserJet 4345mfp Printer
HP LaserJet M4345 MultiFunction Printer Logo
6,318 people viewed this question
Seeker5211
Seeker5211
