Question about Compaq d530 CMT PC Desktop
Hi there, I am planning to buy an Ext4ernal USB Hard Disk for my D530 CMT PC. The maximum internal hdd capacity the system can support according to the manual is 160GB only. There is no mention about the maximum capacity of External USB HDD the system can support. Before I buy and run in to an embarrassing situation I would like to know if the system can support 500GB External USB HDD or not. Would look forward to your valable confirmation. Regards Jay
  • 835 Answers
Their is no limit, your system should read it on usb drives.
Posted on Sep 04, 2010
Hitting F8 key repeatedly will not access Safe Mode option for my HP D530
If you getting this error then you won't be able to open computer in safe mood, Because this error message indicate that there is no proper bootable media selected or there is no OS in your Hard drive.
First thing you can do is go to BIOS and check what is your First boot device selected, if it is other then Hard drive then change it Hard drive and save setting and come out of it.
If there is any media, like Pen drive or any CD then remove it and start your computer.
If still you have same problem then I am afraid that your OS is Corrupted.
Aug 20, 2012 | HP Compaq d530 CMT Intel Desktop PC -...
Hi guys, how important is the hard drive caddy? my father bought a presario v5000 from a garage sale. i found out that the hard drive caddy was missing and the hard drive in it was broken as well. will a...
OK look any drive, that's is the format, ie: STA or IDE? and that will fit will work, that 320GB will be OK. Simply install the HDD in the bay, and then use a windows installation disk, or similar to format it, just format it as ONE big partition, that should be fine, IF you find that it will not "See" the HDD, then partition it into smaller partitions. However you should be OK. You need to FIRST test to see if the actual PC is OK, try a HDD before you buy a new one, make sure that it is actually working.
Oct 11, 2011 | Computers & Internet
My HDD will going to corrupt, so i need to buy one, but i don't know that which HDD is compatible with my AMD Athlon XP 2000 PC. Could any one suiggest that how much maximum capacity HDD Support my PC....
Hard Disk upto 500GB capacity can be added to most of the PCs. As regards compatibility, first you have to check the motherboard for SATA Hard Disk interface as newer hard disks are SATA. Adding the hard disk has nothing to do with the processor. However, motherboard should have the connecting port/ option (such as SATA). Some motherboards support both IDE and SATA devices. Please check the motherboard for SATA Port. You may find the motherboard model/ system model and google a bit for its specification. (You have mentioned AMD Athlon XP 2000, which is the Processor not the motherboard)
If SATA is available on your motherboard, you may add Sata drives of 250-500-750GB drives according to you requirements. Otherwise you have to look for IDE hard Disk.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 24, 2011 | AMD Athlon XP 2000+, 1.67 GHz Retail...
How to repair my desktop computer if it failing to start up
Hi check u r hdd and operating system
repaire u r windows from the bootable disk
or formate u r windows from the bootable disk
note:-if formate u r (c)partition drive u r data all delete
Jun 27, 2011 | HP Compaq d530 CMT PC Desktop
HP d530 cmt 2 short 1 long beep. No POST is displayed
You must be using a USB keyboard. I suggest switch back to PS2 keyboard. Moreover, the system board supports dual channel so you should be using matched pairs plus placing them in the correct slots to enable dual channel mode.
Try this and it should work without any trouble.
Regards,
Anirban Mazumdar
Mar 16, 2011 | HP Compaq d530 CMT PC Desktop
HP Compaq d530 CMT Desktop Freezes after a while
Is it like that before? If not then probably, a failing component, a short, most likely RAM card (when you happened to check its rated capacity getting low), connection problem.
Also, too much running applications at the same time, hard drive getting almost full, virus. Or borderline hardware specification for installed application.
Check the easiest first. Is this virus? is hard drive getting full? Borderline specification? Add on card contact dirty? Ailing component?
hope it helps
Apr 06, 2009 | HP Compaq d530 CMT PC Desktop
How to install new hard drive
2 choices for you. Get the external to run the game or 2. Add a larger hdd to the system as a slave drive leaving the smaller drive as the master. If you go the 2nd route just make sure you buy a compatible hdd. Hope this helps & please remember to rate my answer.
Dec 28, 2008 | HP Compaq d530 PC Desktop
No booting
The problem is Operating systems are co-dependent on hardware.
If the motherboards, processors, ram, video adapters, etc don't match you would not be able to swap hard drives and expect to boot.
You could try pressing F8 on boot and try to access safemode.
If it does boot into safemode immediately it will want to reactivate windows.(because of all the hardware changes.
If it still can't boot, you may want to put the 80 gig in as slave to the 40gig and ghost the 40 gg hard drive over to the 80.
If you don't want to lose your data on the 80 gig then reboot with an xppro cd and reinstall windows in the same partition overlaying the installation on top of existing windows directory.
the new windows will have to be activated but all data will still be there.
Apr 15, 2008 | HP PSC 2210 All-In-One InkJet Printer
Compaq d530 CMT PC Desktop Logo
69 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
