Question about KitchenAid KWVU265YBA Kitchen Hood
I cannot turn off the fan. All speeds work just fine except "off" by using the front panel buttons. All LED's light up properly. Even when I close the hood, the fan does not turn off. The light works normally - its front panel switch works fine and closing the hood turns the light off. I manually pressed down on the front-most micro-switch used for detecting hood closure by using an extremely long screwdriver, but nothing changes - the light stays on and the fan stays on. When I press the rearmost micro-switch, the light successfully turns off, but the fan still stays on. Thanks for your help! Email joopblog@att.net if you can.
  • 833 Answers
SOURCE: kitchen aid stove problem
Peter,
First...be sure you cut power to the stove before you do anything. This is 220 volts and it can kill you. 220 Volts is based on two different lines of power coming to the stove, each of which is 110 volts...but opposite each other in phase. This may mean that some power to the stove is on and some is not. Let's go on.
I suspect a few things: First, the coil control for the burner is probably finished. What I also suspect is that it opened one of the two breakers (they are usually tied together in the panel and are either 40/50/60 amp units) causing some lights but no action.
What to do: Reset the breakers as a pair by turning them off and on. If one snaps off, you have a problem at the stove. If not,...which I doubt...you're in business.
Let's look at replacing the control. Shut the breakers. Now, take the burned control and remove it. Note the wiring positions if they are not on a plug. If they are terminals, tape the ends. Now, reset those breakers. If the other burners work, replace the control. Take the old one to the parts store. If it doesn't work, look around the burned area for broken wires. Repair and tape them up. Try again. Oh, and don't let anyone touch the stove while you're working with those breakers.
Posted on Dec 03, 2007
hotuna
  • 288 Answers
SOURCE: Kitchenaid downdraft retractable vent
check for power going into the switch. (you need a meter) If the switch is set to "on" there should be power going in and out. Find a good ground or use the white wire to test. If there is, just follow the path of electricity. If you do not have a meter this is next to impossible to do.
Posted on Mar 06, 2008
SOURCE: KitchenAid KWVU265YBA
had same problem. microcomputer part # 4360092 and micro switch part # 4360362 needed to be replaced. cost 255.95 and 23.59 for parts respectively.
Posted on Apr 30, 2008
  • 93 Answers
SOURCE: setting the clock
Remove the plug from the socket for a few minutes. Then plug it back. Does the clock control blicking? look at the pictures on the control as a whole.
Do you see anything like a table clock? press it once, then press the numeric pad or up and down arrow button depending on the model you have. press enter or start if set correctly.
Posted on Jul 24, 2008
  • 171 Answers
SOURCE: light and blower speeds malfunctioning
Hi mutt750,
I'm Harvey the Master Plumber.
I agree. It sounds like your neighbor is doing well. I would replace the control board too. Sounds like a nice guy. Time to invite him over for a bbq?
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Nov 21, 2013 | Hampton Bay Ceiling Fan. Chateau Deville...
There was no beeep sound heard at the beginning Delay in turn fan power supply the Power LED on the front panel of the computer doesnt light the HDD LED on the front panel of the computer doesn't...
as i always say:
intercept all of cables of your PC case and even power cable of your monitor.
evolve battery of bios then wait for 25 minutes then connect all of cables and try turning on your PC:
1- with battery of bios
2- without battery of bios
it should work.
(this works cause the motherboard reset it's bios and start correctly again).
Jan 13, 2011 | Biostar TF7100P-M7 Motherboard
Start and speed controls not working properly
do you have the magnet in place on the cut-off sensor? it sound like this is missing, as the treadmill will not turn the belt without it.
Apr 18, 2009 | Computers & Internet
Pc won't power up
if you've tried other power supply's and are positive that the power button is connected properly and are getting nothing, no beep no lights no fans, then you got yourself a bad board.
Jan 23, 2009 | Intel Motherboard
Thinkcentre M55 8806 power on off problem
May be your computer motherboard wires connection get loose or getting moisture in wires. Or there may be some earthing problem in ur power switch. First, check the wires connection & tighten up properly. if problem persists, check the earthing by power tester. Check you RAM if it is properly tight in the jack.
Dec 26, 2008 | Computers & Internet
Power PC G5 Dual 2.5 sudden shutdown and no reboot
In G5 always the cover should be closed properly if not it will start the fan very fast like a blower and the red leds will be on showing that the heat is over so please check that the cover is closed and locked from behind so itworks smooth and the power supply is standard or normal
u should always use genune parts with mac..
thanks
Dec 19, 2008 | Apple Power Mac G5 Desktop
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
KitchenAid KWVU265YBA Kitchen Hood Logo
49 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
