My LG tromm washer keeps saying LE and no matter what I put in there it continues to say this
    President:
  • Washing Mach... Master
  • 1,932 Answers
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer
Check whether a large load size been used with a gentle wash setting?
Check whether the washer been overloaded
Thank You
Posted on Sep 04, 2010
LG Tromm WM2077CW error code LE
No all you have to do is watch how much and what kind of soap you put in that washer...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Apr 15, 2010 | LG WM-2277HW Front Load Washer
My lg tromm washer is reading LE. why
le is code 4 faulty motor or motor sensor. if u r confident, change sensor first. 95% of the time it is sensor. if u need more help please reply back
Apr 06, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washer say LG what dose that mean
My washer stopped and displayed the LE error code. I turned off the power button and tried again, but after a few seconds it want back to LE. Finally, I unplugged the power cord, plugged it back in, and the washer ran normally.
Dec 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LE Tromm Washing Machine
i think you mean LG Tromm washing machine ... and the error code is LE ... thats a common failure with this machine .. often its cause by a defective " Hall effect sensor" this is used to detect the position of the wash basket ... if you are handy with tools then you can change it yourself at low cost ... but it does require removing a big bolt, the spin basket and several small bolts ... not difficult for a mechanic but probably more than aunt martha would want to tackle .. the URL listed below will give you good information on how to do that job ..
http://www.howtomendit.com/answers.php?id=28214
Aug 18, 2009 | LG WM2688HWM TROMM SteamWasher
My lg tromm washing machine has an error code LE
Empty Washer and unplug. Hold the start button (arrow with two lines) for 10 seconds. Plug back in and put on the Rinse and Spin cycle (right hand side) I went ahead and ran that cylce (31 minutes with some bleach) and all worked well.
If problem persists call CSR. 800-243-0000
Jul 14, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a LG TROMM washer.It is not washing properly.
LE stands for overload in motor. Wait 30 minutes before restarting. If it happens again try again without a load.Good luck. Please rate me so I know how I'm doing. Thanks.
Dec 30, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Trying to wash but le comes on the screen
le code is pretaining to tne motor, overloaded ,too much soap, or bad motor .disconnect power for a minute and try agian if proble presist you'll have to have motor repaired
Dec 20, 2008 | LG WM2688HWM TROMM SteamWasher
WASHER NOT WORKING
You have a motor sensor failure and needs to be replaced.  Call a qualified LG technician to remedy your problem.
Nov 16, 2007 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
573 people viewed this question
Top Washing Machines Experts
