Question about Samsung SCX-4300 Monochrome Laser Multifunction Printer
Open head error - Samsung SCX-4300 Monochrome Laser Multifunction Printer
  • 360 Answers
Hello open heat error
unpugged your machine and plug it back after 10 minute sometime your problem is solve.
didnt solve it check your heater unit and replace heater bulb and thermistor
Posted on Sep 04, 2010
Print Head open error but it is not open. Calibration did not work
the flag inside the printer was moved out from sensor, you will have to adjust and tied the screw a litl bit as well.
Feb 26, 2014 | Zebra 105SL Thermal Label Printer
Printer heads errors
switch on the machine wait till error appears on panel, go to the system open internet explorer type IP address enter you can view the entire printer over view.. check which print head showing faulty, ask to replace the head open top cover of the printer open print head cover remove print heads clean print head contact pcb as well as carriage contacts insert print heads back then check for the print head recognition, printer will perform its own priming and all wait till ready mode comes onece ready mode appears.. print heads are OK.. if not replace faulty print head/s.Most of the cases cleaning is enough.
Jan 08, 2012 | HP DESIGNJET T1120 44 Printer
I have a error with a tally 2440 - Park error / Head jam
when the printer is turned on, the head moves to its home position. normally go to left then right & stays at middle. by opening the top cover u will see HEAD. see what object obstructing the movement of head. try to lubricate the shaft where the head moves right-left.
Sep 13, 2011 | Office Equipment & Supplies
Error message "head open" any ideas why please?
Check the microswitch on the leftside of the print head.
Sometimes a part is missing or the print head is not correctly mounted
Jun 15, 2011 | Toshiba TEC B-4700-I/O-QM Thermal Label...
Getting "Error Number : 1403
Not sure what you are asking. You posted the solution?
Jan 24, 2011 | Canon Office Equipment & Supplies
Opened my printer espson dfx 9000 and im getting an error 16 how do i overcome this?
OPENED MY PRINTER EPSON DFX-9000 AM GETTING AN ERROR 16 HOW DO I OVERCOME THIS
Jul 23, 2010 | Epson DFX-9000 Matrix Printer
Our sony dsr 45 is giving us a C:31:41 Error code shortly after tape is inserted.
error cause by drum head, u can try fix by ur self, open the compart then open the black drumhead cap,u can see to screw on the upper head open,then u can see rubber pick it up clean the rubber and the con inside outside head, try again if doesn't work u can change the drum head
Nov 30, 2009 | Sony DSR-45 Mini DV VCR
Error cleared head open
This is not an error, it is a notification that the head has been open and is now closed. If you get Head Open warning when the head is closed check the metal area over the top of the sensors are clean as it is reflective.
Nov 23, 2009 | Zebra Z4M Printer
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
Sep 11, 2009 | Office Equipment & Supplies
Zebra 140xi II error
If you open the case there is a sensor that detects whether the head is opened or not that is connected to the open and close lever. Sometimes the tab that blocks the sensor when it is closed get out of alignment or comes loose or the sensor is jarred loose. Make sure the tab breaks the beam.
Jan 31, 2008 | Zebra Printer 140-751-00000
Samsung SCX-4300 Monochrome Laser Multifunction Printer Logo
267 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
