Question about Black & Decker D2020 Iron
Black & Decker D2020 Iron - Burning Smell & Beeping
My Black & Decker D2020 Iron just started beeping continuously while emitting a burning smell. I had to unplug it. This is the first time this has happened. Is there any hope for this iron?
  • amy_curt Jun 29, 2008
    I was ironing and all of a sudden the iron started beeping, the LED light went off and I couldn't do anything but unplug it. Any idea why?
  • Anonymous Jan 19, 2009
    beeping problem & no heat
  • Black & Decker Master
  • 43,501 Answers
The iron is probably junk...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
The steam wheel on black and decker digital advantage is stuck in the no steam position
This problem developed with our iron within the last week. Playing around with it today, I discovered that the dial WOULD respond to "persuasion". I forced it, and it cooperated. Find somebody with a stronger grip and try it.
Aug 03, 2013 | Black & Decker D2020 Iron
Is my steam iron broke?
Get a new one. If it drew enough power to trip off your electricity then there is a problem that is not worth taking a chance on.
May 07, 2017 | Irons
My Black & Decker d2020 iron immediately goes to auto shut off and will not stay on.
test the 1) fuse heat and replace it
2) test the board if there are voltage , if there are the board can be faulty or repair.
3) see your instruc. manual go to the section troubleshooting and see what is wrong.
God bless you
Sep 30, 2012 | Black & Decker D2020 Iron
Lights are on but not heatingup
Here is a tip that I wrote about Electric Irons and why they do not heat....
heatman101
Jan 14, 2011 | Black & Decker D2020 Iron
Iron Blck & Decker: model D2020. I would like to clean my iron because is stared to stain all my clothes. I just open the white plastic parte on the back, but i dont see any other screws or how to get...
No need to dismantle the iron. Just fill it with a 50/50 white vinegar/distilled water solution and allow the iron to expel all of it as steam. Rinse with distilled water and allow to pass as steam. If you use distilled water from now on, you should no longer have staining problems. Hope this helps!
Jul 18, 2010 | Black & Decker D2020 Iron
Good morning, My iron black & decker d2020 overheats, cools down and then goes through the process all over again.
The Thermostat has gone faulty. This can be replaced if you can get the parts. You need to contact, B&D indicate your problem, and exact, make and model, and inquire as to where you can purchase the parts, or if you do not wish to do it yourself, where to send it for repair.
Apr 19, 2010 | Black & Decker D2020 Iron
Burning smell
thermal switch is not working...upon reaching a certain temperature limit it should switch off then switch on again after a moment to maintain the set temperature..what happened here is that your thermal switch didn't switch off so the temperature continue to rise to the extent that the heating element burnt and smell like that..adjust the setting in such a way that it switches off after reaching the desired temperature..
Jun 18, 2009 | Rowenta Irons
How I can fix The Black&Decker digital advantage that does not heat
The iron will probably have to be taken apart.
If you are handy, you can do this when unplugged.
Check for broken connections and anything that is obvious like burned smell etc.
Feb 16, 2008 | Black & Decker AS150 Iron
My iron bahaves very bad
Izula,
We have had two D2020 Black&Decker Irons that did exactly the same thing. I love the iron...but they have both lasted about 2 months before burning!
Dec 02, 2007 | Black & Decker D2020 Iron
Black & Decker D2020 Iron Logo
653 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
