Question about RTO M-D Building Products Carpentry & Construction Box Beam Level 48"
How do I build a frame that goes inside a brick recess to hold a microwave oven an electric oven and drawers below. The ovens are approx wide600mm drawers will be the same. The hole in the kitchen wall has had a large electric oven removed. The hole is 620mm wide x 1010mm high and 620mm deep. I have just removed an oven that was 900mm high and it sat on a simple melanine platform bolted to the bricks. Thanks for any help Jim
  • 490 Answers
I suppose you could build a box in the recess (top, back, and sides) with 3/4 inch plywood and screw cleates to that at the correct levels. This would give you some decent wood to fasten the front trim to as well as provide a robust inner structure for your oven units to mount to. For the drawers, you can make a simple box carcass with the same material to fasten your hardware and slides to. With strength sorted out you can then concentrate on knocking up a pleasant fascia with the wood, tile or laminate of your choice. That's my thought on it. I bet you get a few good answers as that is a good thought provoking project you have there.Regards, Farmerbear
Posted on Sep 04, 2010
Testimonial: "Thank you farmerbear, wyat you have advised is what I'm going to do"
Need to mo we an electrical power point in a brick wall in my apartment
More information is needed.
Brick wall is inside apartment... what is on other side of wall?
Open existing electrical box. Drill through back of box and drill through wall until you come out on other side of wall. Install new box #1 on wall where drill comes out. Run conduit over to another new box#2. Drill through wall again until you come out on inside brick wall where you want to relocate original box. Install new surface-mount box#3 on brick wall. Then run wiring from original box. Original box cannot be bricked over or covered with building materials since it is a junction box where wires connect.
Other option is to install extension ring on top of existing electric box. Run conduit across face of brick wall. Install new box#1 where you need outlet.
Other option is to chisel away the brick and mortar from existing electric box down to floor level (or over to door frame). This will allow recessed conduit that can be concealed with matching mortar. Then run conduit across to new location. Cover conduit along floor with baseboard, or chisel out brick along floorline to accommodate conduit, then mortar over conduit. Or simply paint conduit to match brick. You must use conduit since wires cannot be run openly.
Gene
Aug 04, 2013 | Electrical Supplies
How to remove JMC8127DD from cabinet
The wiring diagram for the microwave shows it is separate and distinct.
Usually slid-in counter top microwaves in this cubbyhole configuration have a trim piece surrounding & covering the front edges of the oven on all sides like a picture frame.
Normally you remove 4 or more screws in the trim frame, pull the frame off, then slide the oven out a little (there may be a locking tab on the cubbyhole's rails for safety) to unplug the cord, and then slide it out the rest of the way.
You can find installation instructions and other literature for this model for free download here.
You can find links to helpful exploded view diagrams and order parts and accessories for it here.
May 22, 2013 | Jenn-Air JMC8127DD Microwave Oven
I have a Miele H147-2mb combi oven. If I start microwave in the 900w mode for a little bottle with milk i see a flame on the topplate of the oven. It's a circle with a diameter of 5 - 10 cm.
Hi there - the cover plate is most likely to be damaged or theres dirt build up behind the cover plate causing it the arc or short to the frame...
Worse case is the microwave cannot be used as it will cause more damage to the oven.. there are a few screws holding the cover plate to the top - remove it gently - if not damaged as its made of fibreglass you may be able to re-use it - inspect the hole/microwave entry for the damage caused by the arc reactions.
Pending on how bad it is - you may just have to use the oven only as one needs to replace the entire casing to overcome the problem which is costly. Wipe the carbon off the oven with a damp cloth - please don't scrap it off as it will enhance the arcing and if the damage is already excessive then reside to using the oven only.
Good luck
Aug 18, 2011 | Miele H147-2MB Electric Single Oven
Oven will not light
Go to partselect.com and look for a ignitor.
When on this site... you will be asked to put in you model # which you will find in the drawer below oven.
This is a very simple project which should be about half hour to replace.
No electrical to turn off, no gas to turn off. Just a screwdriver, and the job is finished
Jul 29, 2010 | Kenmore 80412 Microwave Oven
Top oven glass in door is broken (thermadore).
Your oven model number is usually located on the rim of one of the oven doors or on the frame oaround a door. Some ranges with bottom drawers have the model number on the frame behind the drawer.
Here is a tip that I wrote about replaceing your glass....
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
heatman101
Mar 31, 2010 | Thermador C302U Electric Double Oven
The unit works fine, but the plastic frame around the control pad is broken, just above the door open button. Where can I get a replacement part, and how do you get that frame off of there?
you must take it to a approved Sharp engineers, who will give you aprice for replacement.
This is due to m/waves holding charge inside even when you have unplugged it and may give a electric shock unless you know what you are doing
Oct 03, 2009 | Sharp R-1851A 850 Watts Convection /...
Need to remove this fitted SMEG FME24X Microwave
Thanks for the quick reply. As you said this has been mounted into a recess and surrounded like a picture frame.
I found some screws are very deep inside the recess and it has been obstructed by the grille/frame.
If you have any pics or any illustration, can you please forward it to me.
Thanks
Oct 24, 2008 | Smeg FME24X Microwave Oven
Our Whirlpool 27" Built-in Combination Microwave Oven and thermal Oven won't work after self-cleaning model # RM770px882 Serial # XE1401024 Part # 3185651
This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
Q-- My microwave is completely dead.
A - House fuse has blown or interior fuse inside the microwave has blown ( usually a part inside the microwave makes this fuse blow ) Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section
Q - I burnt something in my microwave and now it is dead...help!
A - The fuse inside the microwave may have blown, but more commonly the flame/oven thermostat has sensed the over cooked food and the flame/oven/cavity thermostat has opened up - Info on that
also look for this electric wiring chart given in this link below just click on the link
http://www.applianceaid.com/image/microflowchart.JPG
thanks.
Oct 13, 2008 | Whirlpool Kitchen Ranges
Door inside and metal vent area smells strongly of fumes
Did you find an answer toyour question?
My microwave smells also of petrol in the same areas.
Jun 05, 2008 | GE JVM1653 Microwave Oven
RTO M-D Building Products Carpentry & Construction Box Beam Level 48" Logo
99 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Tim Venetis
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
