Question about Palm Treo 600 Handheld
Touchscreen does not respond to touch
When i touch my touch screen it does not respond to touch. I performed a hard reset and not i can't complete the reset because i can't get past the screen activation Sprint Treo 650 touch screen won't respond to touch.  Screen comes and displays, however won't allow functions to be accessed.  Have taken battery out and reset with no luck.
There's apparently no known software solution to the dead screen problem. However one can bypass the screen setup step by doing a warm reset. See:
http://www.everythingtreo.com/forum/treo-600/dead-touch-screen-13771.html
Posted on Dec 29, 2008
    Sergeant:
  • 209 Answers
Dear Daunzee
Looking at this problem for how yo have described it, i would suggest to look carefully at the battery and ask yourself how old the entire unit is. It could be likely that the battery (even when fully charged) is not puting out enough power in order for the touch screen facility to work. If you have not already done so, then I reckon to give the phone a good charge and try again on a full battery, if this is still a no hoper, then your two choices are as follows.
1.Replace the battery with a brand spanking new one
2. Query, or at least consider the possibility of a fault with the touch screen itself.
Now should there be a fault with the touch screen itself, then rather try to repair the screen itself, it may just be a whole lot easier to find a replacement unit elsewhere and either fit it or have it fitted by someone in the know.
If you do decide to fit the replacement screen yorself, you will need to acquire some specialist tools, and MAPLINS (united kingdom company) will provide you the tools for about twenty quid (security bit set in a red box, and a ratchet screwdriver with bits), and you can go on the internet to find a nearest store by entering your postcode in the search for store location. Finding the screen is easy enough, either go to a mobile phone outlet that trades from the internet, or go to ebay, and you are sure to get a replacement unit from there. by going to http://www.google.com you will be able to get the disassembly guide for your product and by following the instructions, you will be able to do the job yourself and save a few quid.
Anyway, I can give you more helpful information, but i will need more in depth information relating to your problem, so anything else that you can accurately describe will be of massive benefit. Until then i hope that this is the best fixya for you, and wish you all of the best luck infixing your product,
kind regards and yours sincerely
Oz
Posted on May 11, 2008
My touch screen is all wonky its not responding to anything I'm trying to do with it and its doing things that I'm not doing it's basically made my phone useless at this point
Tf810c Touch screen wont work ' TabletPCReview.com - Tablet PC ...
forum.tabletpcreview.com > Forums > Windows Tablet PCs > Asus
Feb 24, 2013 - 10 posts - ‎4 authors
If it's greyed out, there is no data to reset, and it's not that causing the issue. ... wentall wonky, swipe for charms wont work, can select anything ... I tried the hard reset and low and behold my touchscreen started working again.
Nexus 7 (2013) erratic touchscreen & keyboard - Google Product Forums
productforums.google.com/d/topic/nexus/W0Hfkq8hf-c
GoogleJul 30, 2013 - I've used some touchscreen test apps and "ghost" touches would ... Myoriginal Nexus 7 (2012) didn't do this, nor did my Gnex or any of ... If it's software, I don't mind hanging onto it until a fix is released. ...... I can't believe no one has saidanything about the touchscreen not responding at all to touches I've ...
XPS 9530 touch screen stops responding (how to fix) - General ...
en.community.dell.com/support-forums/laptop/f/3518/t/19534511
Dell
Dec 1, 2013 - 15 posts - ‎7 authors
Dec 16, 2015 | Cell Phones
How to show images on screen
Step 1 Turn the device off, wait a few seconds, and then turn it back on again. This process will clear out any software errors that are causing the touchscreen to malfunction. If the touchscreen still doesn't work, remove the device's battery, if possible, wait ten seconds and then put it back in.
Step 2 Remove both the SIM and memory cards from the device, if the device accepts such cards, and then turn the device off and back on again. Sometimes errors in these cards can cause devices to malfunction.
Step 3 Check your device's documentation to see if there is a way to manually recalibrate the screen. This process will either be done through the "Settings" or "Tools" menus, for those devices that have an alternative method of input, or by holding a combination of buttons while you turn the device on, for those devices that only have the touchscreen for input.
Step 4 Upgrade the device's software to the latest version, if possible. Many devices come with software for your computer that will allow you to connect the device and update the software. Often, this process will resolve existing software errors that may be causing the touchscreen to stop responding.
Step 5 Clean the device's contacts and screen using isopropyl alcohol and a small brush. Turn the device off before you clean it.
Step 6 Perform a hard reset as a last resort. This reset will erase everything you have added to the device and return its software and settings to their factory defaults. Even with an unresponsive touchscreen, most devices will have a way to perform this reset either through PC software or by holding a combination of buttons while turning the device on. Consult your device documentation to determine the exact process for performing a hard reset on your device.
Step 7 Contact the manufacturer for your device if the touchscreen is still unresponsive after your troubleshooting attempts. The manufacturer may have additional steps to take that are specific to your device, and if your device is still under warranty you should be able to get a replacement through their customer service division.
Warnings
  • If you have the right tools and are willing to risk voiding your warranty, you can also open the device and scrub down the control board using the small brush and isopropyl alcohol.
  • Many manufacturers offer free telephone support, but some will charge for the service. Check your product documentation before you contact support to know if you will be charged for the service.
Required Items
  • Isopropyl alcohol
  • Small brush
References
Sep 29, 2014 | Sound Storm Laboratories SD714MB Car Video...
Just purchased Ematic EDAN XL. I let battery partially charge and continue to have connected to wall electrical outlet. The touchscreen is not responding. I have reset it and it continues to sit until it...
Try cleaning the touch-screen with a tissue or touch-screen cleaning paper, then wash your hands and use a skin moisturizer on your fingertips. If it still doesn't work, something's wrong with the unit. The touch-screen should work down to the discharge limit of the battery.
Note: when you buy a new lithium battery or device that uses one, it is a good idea to charge it completely before using. Some types of battery charge controllers use this first cycle to calibrate battery parameters so you get optimum performance from the battery.
Nov 11, 2017 | Ematic EDAN XL 9 inch Tablet with 8GB...
My v touch pro touch screen wont work
b> The Touch Pro2, manufactured by HTC, is a smartphone designed to be used with the Verizon wireless phone network. This smartphone combines a cell phone, PDA, MP3 player and wireless Internet access into a small, portable device. If the device begins malfunctioning or freezing, you can perform a soft reset. A soft reset does not delete any of your saved information. It shuts the phone down and reboots the phone to the Verizon Today Welcome Screen.
Pull the stylus upward to remove it from the side of the phone. Push the back cover upward using your thumbs until it pops from the back of the Touch Pro2 phone. The back cover can then be lifted away and removed from the phone. Press the "Reset" button, on the upper, left side of the back panel using the stylus tip. The device will now restart and display the Verizon Today screen. Snap the back cover back onto the back of the phone. Touch Screen is Not Working
As most tablet PCs ,Phones and Mp3 players are full touchscreen devices, you use your touchscreen for everything you need to do on your Tablet PC. If the touchscreen stops working, you can't get much use out of your Tablet. Touchscreen issues are caused by hardware or software problems, but check with your manufacturer before attempting a DIY repair.
Hardware Issues Damages to the surface of your Tablet PC can cause the touchscreen to malfunction or stop working entirely. For example, putting pressure on the screen, such as placing the Tablet PC in a bag with other heavy items, can cause cracking along the screen. Exposing the screen to water, even in small amounts, can cause the electrical system within the touchscreen to malfunction. If the electrical system malfunctions, the touchscreen stops working properly. b> Screen Sensitivity b> Pressing the touchscreen on your Tablet PC sends a signal to the internal motherboard. The motherboard then transmits to other components, such as the hard drive. The accuracy of the touchscreen depends on the screen's sensitivity. Many Tablet PCs include a program for calibrating the touchscreen. This program may fix minor responsive issues. Even a small amount of dirt or debris can effect how the touchscreen responds. Cleaning your touchscreen with an electronics cleaner or a microfiber cloth may help improve sensitivity. b> Software Issues b> A driver is a software program that interacts between hardware devices and an operating system, Your Tablet PC needs the right drivers for your OS to work correctly. Outdated or missing drivers can cause the touchscreen to work improperly, or not respond at all. Visit the manufacturer's website to find the right drivers for your Tablet PC. b> Repair b> While you can perform some minor repairs yourself, such as re-calibrating the touchscreen sensitivity or installing drivers, only perform a hardware repair if you have a good working knowledge of electronics, specifically Tablet PCs. Before attempting to repair your device, contact your manufacturer. If your Tablet PC has a warranty, completing an unauthorized repair may make you ineligible for claiming that warranty. Hope this helps
b>
Jan 20, 2013 | Visual Land V-Touch Pro (8 GB) MP3 Player
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
The screen on my Garmin Nuvi 200W won't respond. I tried the recalibration but the screen doesn't respond when I touch the dot. I also tried a hard reset and that didn't help either. Help please!
There is more than one calibration procedure, but for the 200 it is:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
If this doesn't work you have two choices
Buy a new one
Or
Send your in for repair. Go here for this option
http://www8.garmin.com/support/outofwarranty.html
Aug 23, 2009 | Garmin nuvi 200W GPS Receiver
Treo 600
Try running a piece of paper around the edge of the screen. There may be was something stuck in there, pressing the screen slightly and causing it to not respond to the stylus4.gif.
Jan 01, 2008 | Palm Treo 600 Handheld
This is straight from Palm Support...
1.Press and hold the UP button on the front panel of your device.
2.While holding the UP button, use an unfolded paper clip, or the reset tool at the tip of your stylus, to gently press the RESET button inside the hole on the back of your device
3.The Palm Computing Platform screen will appear. Release the UP button when you see it.
Dec 11, 2007 | Palm Treo 600 Handheld
Touch screen
You may have dust accumulation around the edges of your touchscreen, between the screen and the case. Try using a can of compressed air. Gently press down on the edges of the touchscreen to expose the gap between the screen and the case, and shoot the air in there. This worked for me when my Treo 600 touchscreen stopped responding.
May 23, 2007 | Palm Treo 600 Handheld
Palm Treo 600 Handheld Logo
480 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
