Question about Microwave Ovens
I have a Panasonic Genius 1100w. I wanted to defrost frozen juice carton, which I now realise is foil lined. The microwave switches itself off and is not heating. Hope you can help. Have guests coming for dinner in a few hours. Loretta
  • loretta612 Sep 05, 2010
    Hi Azraelsrl
    Unfortunately unplugging it from the wall didn't solve the problem. Sounds like the magnetron was damaged. I'm thinking to buy a new microwave.
    Thanks for your suggestions.
  • Microwave Ovens Master
  • 11,800 Answers
The tin foil has acted as a short and overstressed the oven. Unplug it from the wall for 30 minutes, this will allow the capacitors to drain away reseting the unit, and try again. If it's the same then the magnetron (the device that is generating the heat) was damaged and to fix that a repairman is needed - very high voltages inside.
Posted on Sep 04, 2010
  • Azrael SRL Sep 05, 2010
    Ye, probably it will be cheaper in the end to just get a new unit.
Panasonic genius 1100w inverter microwave stops after 23secs.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here:
Support Panasonic
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 05, 2017 | Panasonic Microwave Ovens
Cant open door on panasonic genius 1100w
One of the door opening parts has failed, most likely the lever or the door open button.
See this safety information and these disassembly instructions.
You will need to take the outer cover off the oven, then you can see the door opening parts.
As you try to make the door open, you can see the mechanism and which piece has failed.
You can order Panasonic microwave parts from Encompass here, and for other brands, see this parts ordering page.
For more free DIY and other help & advice, feel free to contact me directly.
Please include FULL model number*, FCC ID number*, + detailed symptom information.
* (on the tag in cooking cavity or around door frame or control frame or on back)
pupista@gmail.com
Jan 29, 2017 | Panasonic Microwave Ovens
Where is nn_sd297 fuse located?
i forget where mine was but it is the first thing the hot side of the power line gets to in the oven. Sometimes in a holder, sometimes wired in.
Jan 25, 2016 | Panasonic 1100w over Range Microwave Ovens...
Panasonic Inverter Genius 1100W NN-ST7805. How do I replace the light?
Depending upon the design, it may be necessary to remove the outer cover to gain access to the light for replacement.
May 21, 2015 | Panasonic Microwave Ovens
Panasonic microwave
I would check the cooking instructions on the side of the pizzas packaging. If microwave cooking is not listed I would not recommend cooking it in a microwave as this could make the food unsafe to eat.
But if you're short of an oven I have found a guide on barbecuing a pizza:
How to Cook Pizza on Barbecue
Mar 20, 2014 | Avanti Microwave Ovens
Whaqt are the dmensions of panasonic genius premier model number nn-s7768a
Here's your answer and then some, in case it helps
Brand: Panasonic
Name: The Genius Premier 1000W
Primary feature: reheating of popular food categories is done automatically (time and power level automatically determined, often time adjusted based on steam sensor). Defrosting also done by entering weight (so time is automatically determined).
Color: black matte top/lateral sides; black gloss front; white back; silver bottom
Style: Counter/table top (label says not for mounting)
Model: NN-S7768A
Manufacture Month/Year: September/1996
Dimensions Exterior: 14"T x 23-3/8"W x 16-1/2D (18 including protruding door handle and back cord plastic clip)
Dimensions Interior: 10-5/8"T x 16-1/4"W x 15-1/4"D
Cubic Feet interior: ~18.28 cu ft (based on three interior dimensions multiplied together and divided by 144 to get from cubic inches to cubic feet)
Note:
I found a manual from a similar model; you'll probably want to pring page 15 as a reference, since each food category button has 2-4 modes based on the type/temperature of the food, e.g. veggies are 1. for potatoes up to a certain quantity and weight each, 2. fresh veggetables of a certain weight, and 3. frozen vegetables of a certain weight. Specific instructions on adding water, covering, etc. are also included. Makes microwaving pretty easy!
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CGAQFjAB&url=http%3A%2F%2Fservice.us.panasonic.com%2FOPERMANPDF%2FNNS696.pdf&ei=BMEnU4-RLaWbygHQ2oCQCg&usg=AFQjCNF2JlFATy7HV-Ltv0BjDUf_LHHi3g&bvm=bv.62922401,d.aWc
Jun 24, 2013 | Panasonic Microwave Ovens
I want to defrost a small frozen food item for 2.5 minutes. How do I do this with my Panasonic Genuine Sensor 1300W Microwave? Thanks! Dan
You can download your Panasonic owner's manual here.
Dec 19, 2008 | Panasonic NN-T990SA Microwave Oven
Panasonic Model NNS768BA Genius Premier 1100W Display works - nothing else comes up H98
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Sep 14, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
